Setting normal gradient of each face of patch
Like Tree3Likes
  • 2 Post By Dozer_94
  • 1 Post By einstein_zee
Old   July 16, 2019, 10:36
Default Setting normal gradient of each face of patch
Dozer_94 is on a distinguished road
Hi all,
In my simulation, I have to reset the fixed gradient of a scalar field "s" as a BC on a patch each time step.
Now, I am aware that if all faces of a patch get the same value, you can use
    label BCID = mesh.boundaryMesh().findPatchID("part0");
    if(s.boundaryField()[BCID].type() == fixedGradientFvPatchScalarField::typeName)
        fixedGradientFvPatchScalarField& spatch = refCast<fixedGradientFvPatchScalarField>(s.boundaryFieldRef()[BCID]);
        spatch.gradient() = dp;
See this thread: Updating Boundary Conditions Each Iteration
This will set the normal gradient of scalar "s" on all faces of patch "part0" to value "dp". Which works perfectly. But what if I want to give each face a different value? Say something like this:
        forAll (spatch, faceI)
            spatch[faceI].gradient() = dp[faceI];
In which "dp" is now not a float, but a list of floats. This does not work, as OF throws the following error:
   sBC.H:32:18: error: request for member ‘gradient’ in
‘(& spatch)->Foam::fixedGradientFvPatchField<double>::
 <anonymous>.Foam::fvPatchField<double>::<anonymous>.Foam::Field<double>::
  <anonymous>.Foam::List<double>::<anonymous>.Foam::UList<double>::operator[](faceI)’,
which is of non-class type ‘double’
Anyone ideas on what is going wrong here?
Thanks in advance,
arashn18 and ssc0109 like this.
Dozer_94 is offline   Reply With Quote
Old   July 16, 2019, 11:00
Hosein
einstein_zee is on a distinguished road
Originally Posted by Dozer_94 View Post
Hi all,
Thanks in advance,
Hey there,
have you tried it this way: spatch.gradient()[faceI] = dp[faceI]
ssc0109 likes this.
einstein_zee is offline   Reply With Quote
Old   July 16, 2019, 11:08
Oh my... Not my brightest moment. Thanks a lot for the superfast reply!
boudary condition, patch gradient
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
