Problem while reading header for object fvSolution
Like Tree1Likes
  • 1 Post By ingraban
Old   June 21, 2019, 08:39
Default Problem while reading header for object fvSolution
Aaron Pumnul
aaron99 is on a distinguished road
How can I solve this kind of problem ?
For me it occurs randomly, from the source code I saw
it might be the case that the stream is bad ? if so, then why ?
[0] --> FOAM FATAL IO ERROR:
[0] problem while reading header for object fvSolution
[0]
[0] file: /srvtc/job-data/807938a0-9a7e-404d-a55c-6cfd57157472/system/A1_I4_A2_I9_B3_TE16880/fvSolution at line 1.
[0]
[0]     From function regIOobject::readStream()
[0]     in file db/regIOobject/regIOobjectRead.C at line 95.
[0]
FOAM parallel run exiting
[0]
https://github.com/OpenFOAM/OpenFOAM...IOobjectRead.C
https://github.com/OpenFOAM/OpenFOAM...ctReadHeader.C
aaron99 is offline   Reply With Quote
Old   June 21, 2019, 09:27
Charlie
shackman287 is on a distinguished road
Why is your fvSolution file located there? Shouldn't it be in your system folder, within the case files?
shackman287 is offline   Reply With Quote
Old   June 21, 2019, 09:30
Aaron Pumnul
sorry, I removed some bits of the path because I thought it would be too long for this post.
Now I reedited and it's same as the original error.
Old   June 21, 2019, 09:32
ingraban's Avatar
Ingo Riess
ingraban is on a distinguished road
I think your link to the source points to the wrong file. It should be
It appears that the file fvSolution was found, but the error appears while reading the header of fvSolution. A typo in the file somewhere above the keyword "FoamFile"? Everything above should be a comment, only.
aaron99 likes this.
ingraban is offline   Reply With Quote
Old   June 21, 2019, 09:39
Aaron Pumnul
Thanks I added the other link.
I'll check its header then.
Old   June 21, 2019, 11:25
Aaron Pumnul
The structure of fvSolution file seems fine...
Old   June 24, 2019, 13:05
Aaron Pumnul
Do these fvSolution files look normal ?
fvsolutions
--> FOAM FATAL IO ERROR: problem while reading header for object U Bdew8556 OpenFOAM Running, Solving & CFD 1 November 25, 2021 09:44
cgns grid problem praveen SU2 20 March 10, 2014 15:09
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam jlpelerin OpenFOAM Meshing & Mesh Conversion 4 April 25, 2011 17:56
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 07:28
