How does "fvm::SuSp" work ?
Like Tree7Likes
  • 1 Post By mAlletto
  • 1 Post By snak
  • 2 Post By mAlletto
  • 1 Post By snak
Old   June 20, 2019, 12:35
Default How does "fvm::SuSp" work ?
K
mkhm is on a distinguished road
Dear foamers,
I want to add source terms to my equations by using fvm::SuSp. However, whatever combination that I make fails. I have "no matching function for call" error*.
How we can have a source terms as following :
fvm::SuSp(VolScalarField, SurfaceScalarField)
fvm::SuSp(VolScalarField, SurfaceVectorField)
Thanks in advance for your help,
Mary
* For instance, one of the error is the following :
error: no matching function for call to ‘SuSp(Foam::volScalarField&, Foam::surfaceScalarField&)’
                   - fvc::SuSp(A,phi)
I know that we cannot multiply a surfaceScalarfield with volScalarField. I used also many combination of fvc::reconstruct and fvc::interpolate but I cannot make fvc::SuSp(A,B) works.
mkhm is offline   Reply With Quote
Old   June 23, 2019, 06:58
K
No one can help me ?
Old   June 24, 2019, 06:47
Michael Alletto
mAlletto will become famous soon enough
Looking at the programmer guide fvm::susp takes only volumetric fields as arguments. So you have to tranform your surfacefied in a volumetric field
rarnaunot likes this.
mAlletto is offline   Reply With Quote
Old   June 25, 2019, 06:24
K
Thanks Michael for your reply. To transform surfacefied to volumetric field, we need to use fvc::reconstruct. So, I did :
fvm::SuSp(c1,fvc::reconstructMag(phi)) where c1 is a volScalarField and phi is surfaceScalarfied. However, I had the error :
 error: no matching function for call to ‘SuSp(const volScalarField&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >)’
                  - fvm::SuSp(c1,fvc::reconstructMag(phi))
Therefore, I dont really see how this conversion from surfacefied to volumetric field within the use of fvm::SuSp should be done to avoid such an error.
Thanks for helping me.
Old   June 25, 2019, 07:06
Michael Alletto
Can you try to contruct your field first and then pass it to the function. I think the Problem is the tmp template.
Something like this:
volScalarField phi1(fvc::reconstructMag(phi);
fvm::SuSp(c1,phi1);
mkhm likes this.
Old   June 27, 2019, 07:39
shinji nakagawa
snak is on a distinguished road
What equation do you want to solve?
The second argument in the SuSp will be the variable which is solved in the equation. For example, epsilon_ is the second argument in SuSp of epsilon equation.
https://github.com/OpenFOAM/OpenFOAM...Epsilon.C#L262
https://github.com/OpenFOAM/OpenFOAM...Epsilon.C#L283
SuSp function sets both the diag and source components of the matrices.
https://github.com/OpenFOAM/OpenFOAM.../fvmSup.C#L210
mkhm likes this.
snak is offline   Reply With Quote
Old   June 27, 2019, 13:33
Michael Alletto
maybe the there are some misunderstandings how to uses fvm::susp(A,phi)
A... a volscalarphield
phi... is the variable you are solving for in the Matrix (can be a volScalarField, volVectorField or volTensorField)
so if youre unkown field is c1 and phi is you mass flux (it is per Definition a surfaceField) you can write:
fvm::SuSp(fvc::reconstructMag(phi),c1)
rarnaunot and SHUBHAM9595 like this.
Old   June 28, 2019, 13:48
K
Hi Michael, Hi Shinji,
Thanks to both of you to answer me. I am solving the density, momentum and energy equation. I add to all 3 a different term. I did it with fvc and the compilation was fine. However, the subsonic part of the solution was not converging. So, I though maybe I should add this term in another way where the sign of the latter is considered and based on the sign, the source term is treated explicitly or implicitly (please see Understanding fvm::Sp() ). By the way, I am not sure that the use of fvm::SuSp will solve the problem.
So, for instance I have the density equation :
        // --- Solve density
        solve(fvm::ddt(rho) + fvc::div(phi) //native OF+
       - fvc::reconstructMag(phi*fvc::interpolate(A)) //added and works
Where Phi is Surface Scalar Field and is basically rho*velocity and A is a Vol scalar field (positive in supersonic part or negative in subsonic part). This modified version of solver is working (no compilation error and runs well). However, I have some issues for some subsonic cases. So, I wanted to try this fvm::SuSp. I have the following version based on Michael's suggestion :
volScalarField phi1 // construct your field first and then pass it to the function.
            fvc::reconstructMag(phi) // fvc::reconstruct(surfScaField)
           - fvm::SuSp(A,phi1) //added and works
This version of solver compiles well but after when I run on my case study, I have the following error :
--> FOAM FATAL ERROR:
incompatible fields for operation
    [rho] == [reconstruct(phi)]
I tried as well another version based on Michael's last comment as following :
       - fvm::SuSp(fvc::reconstructMag(phi),A)
This version does not seem correct to me as I am somehow solving the rho related field. And if I look at Shinji examples, the field that you solve is the second argument of fvm::SuSp (correct me if I am saying wrong stuffs).
This version compiles fine as well but when I run it, I have the following error:
    [rho] == [A]
Could you see what is wrong and did you have any experience to solve instability of your solvers by using fvm::SuSp ?
Thanks a lot for your help,
Best regards
Old   June 28, 2019, 15:04
Michael Alletto
The second argument to fvm::susp should be your unknown variable rho. This would work fvm::susp(A,rho)
Old   June 28, 2019, 15:24
K
But the term to be added to this equation is A*phi and not A*rho. You mean that I should separate the velocity from the density and instead of using their multiplication which is in phi, I should do something like : fvm::susp(A*velocity,rho)?
Old   June 28, 2019, 15:29
Michael Alletto
Yes this should compile and run
Old   June 28, 2019, 15:34
Michael Alletto
A no take the magnitude of the velocity otherwise you Java a volVectorField on the left side
mkhm likes this.
Old   July 1, 2019, 08:08
K
Thanks Michael for your prompt response.
In this case, what about the energy equation ? :
solve
            fvm::ddt(rhoE) //native OF
          + fvc::div(phiEp) //native OF
          - fvc::div(sigmaDotU) //native OF
            - fvm::SuSp(A,phiEp)
In this case the term to be added is A*phiEp. So again, I have the same problem. If I add something like :
volScalarField phiEp1 // construct your field first and then pass it to the function.
            fvc::reconstructMag(phiEp) // fvc::reconstruct(surfScaField)
this - fvm::SuSp(A,phiEp1) compiles without errors but when it is applied to my test cases, I have the following error:
    [rhoE] == [reconstruct(phiEp)]
With your comment, I conclude that I should do something like :
- fvm::SuSp(A*something,rhoE)
However, this is not straightforward. We might need something like
  fvm::SuSp(A,rhoE)+  fvc::reconstructMag(phiEp*fvc::interpolate(A))-
  fvm::SuSp(A,rhoE)
Which could be shortened to what I had before fvc::reconstructMag(phiEp*fvc::interpolate(A)). However, my purpose is to use fvm::SuSp to see if the stability problem could be solved.
Do you have any idea how to treat this issue ?
Best regards,
Mary
Old   July 1, 2019, 09:26
shinji nakagawa
Hi Mary,
I'm not familiar with the rhoCentralFoam or other compressible solvers.
So, I don't understand physics, just looking the code...
If what you want to add is A*phiEp, then I guess the addition of something like the following will be work. Here, phiv is something similar to phiv_pos or phiv_neg. (or phiEp / rhoE)
+fvm::SuSp(fvc::reconstructMag(phiv*fvc::interpolate(A)), rhoE)
This will not be an exact expression.
mkhm likes this.
Old   July 1, 2019, 12:19
K
Originally Posted by snak View Post
Hi Mary,
Thanks Shinji for your reply. It works.
fvm::susp, implicit/explicit, sources
RP_Set_Integer does not work in parallel 86lolo Fluent UDF and Scheme Programming 2 July 3, 2014 12:37
Does CX_Interpret_String work in parallel? 86lolo Fluent UDF and Scheme Programming 2 June 30, 2014 05:36
Companies that lease software & hardware for cloud-based work? Catthan ANSYS 0 June 18, 2014 11:53
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 13:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 22:03
