Setting normal gradient as BC
Like Tree1Likes
  • 1 Post By fumiya
Old   May 3, 2019, 10:27
Default Setting normal gradient as BC
Dozer_94 is on a distinguished road
Hi all,
I am editing icoFoam for a specific calculation in which I want to set the normal gradient of a patch as a boundary condition.
So normally scalar field 'c' would be solved using the BCs for the values of 'c', but now I would like OF to use normal gradient 'dc/dn' as BC.
I know that 'c.boundaryField()[patch].snGrad()' would return the values of the normal gradient, but I'd like it vice versa.
Anyone know if this is possible at all?
Thanks in advance,
Dozer_94 is offline   Reply With Quote
Old   May 7, 2019, 09:14
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use the fixedGradient boundary condition to set a patch normal gradient to a user-specified value.
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   May 7, 2019, 12:22
Hi Fumiya,
Thanks for your reply. I was aware that this was the way to go for the initial conditions. However, I would like OF to do this for me as a BC that changes each timestep.
To give a bit more information: I am using an external solver that calculates dc/dn from other quantities. The goal is to set this calculated dc/dn as BC for the next timestep. Therefore, I need a way (be it a provided member function or a more elaborate method) to incorporate this in the solver itself.
Thanks,
Old   May 8, 2019, 10:54
fumiya's Avatar
Fumiya Nozaki
Hi Dozer_94,
The following thread will be of help:
Updating Boundary Conditions Each Iteration
Fumiya
Gerry Kan likes this.
[Personal]
Old   May 21, 2019, 11:33
Thank you Fumiya, this was exactly what I was searching for. Seems like something I could have figured out myself, though.
Old   August 1, 2024, 13:19
Default Doubt regarding fixed gradient boundary condition.
ghanashyam k c
gsam is on a distinguished road
If I apply a fixed gradient condition on a patch under atmospheric conditions, will the gradient change over time as the liquid passes through this boundary? For example, if I use `zero gradient` as the boundary condition for the velocity ( U ), and the fluid passes through, would recalculating the gradient later necessarily result in a zero gradient again?
gsam is offline   Reply With Quote
Old   August 2, 2024, 08:11
Tobermory will become famous soon enough
I think you are misunderstanding the nature of the fixed gradient boundary condition ... it literally fixes the gradient. So yes, the gradient will be maintained as the flow passes through (the patch value will of course change).
Tobermory is offline   Reply With Quote
Old   August 5, 2024, 10:36
ghanashyam k c
Thank you for the reply. Apparently, i am dealing with an Electrohydrodynamic solver. The problem is when I apply zero gradients at one of the boundaries as a voltage condition, my electric field changes, which is not supposed to since the electric field is -grad(Voltage). Since I am applying a zero gradient, it should maintain the Ey constant, which is a normal component of the electric field. I am unable to find what is the real issue occurring here.
solver, volscalarfield
[swak4Foam] Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Community Contributions 32 November 17, 2017 04:44
How to extract the normal pressure gradient from the momentum equation mtgoncalves OpenFOAM Programming & Development 4 September 29, 2017 11:50
Surface normal velocity BC with zero gradient tangential, cylinder c_dowd OpenFOAM Running, Solving & CFD 0 May 25, 2013 08:22
[swak4Foam] Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Community Contributions 2 January 26, 2013 03:37
normal temperature gradient on a boundary Sandrine FLUENT 0 June 10, 2009 13:29
