BasicTurbulenceModel class declaration in OpenFOAM 6
Like Tree10Likes
  • 2 Post By GerhardHolzinger
  • 8 Post By zhangyan
Old   April 12, 2019, 16:34
Default BasicTurbulenceModel class declaration in OpenFOAM 6
Rodrigo Petrone dos Anjos
rod_petrone is on a distinguished road
I was trying to understand turbulence models implementation in OpenFOAM 6. Nevertheless, in linearViscousStress. H, it is used a parent class called BasicTurbulenceModel, which is the class template parameter too.
I have not been able to find BasicTurbulenceModel declaration and definition. Does someone know where it is in OpenFOAM? Or is it a declaration way that i am not familarizied with?
Codes:
linearViscousStress.H:
#ifndef linearViscousStress_H
#define linearViscousStress_H
namespace Foam
                           Class linearViscousStress Declaration
template<class BasicTurbulenceModel>
class linearViscousStress
    public BasicTurbulenceModel
public:
    typedef typename BasicTurbulenceModel::alphaField alphaField;
    typedef typename BasicTurbulenceModel::rhoField rhoField;
    typedef typename BasicTurbulenceModel::transportModel transportModel;
    // Constructors
        //- Construct from components
        linearViscousStress
            const word& modelName,
            const alphaField& alpha,
            const rhoField& rho,
            const volVectorField& U,
            const surfaceScalarField& alphaRhoPhi,
            const surfaceScalarField& phi,
            const transportModel& transport,
            const word& propertiesName
    //- Destructor
    virtual ~linearViscousStress()
    // Member Functions
        //- Re-read model coefficients if they have changed
        virtual bool read() = 0;
        //- Return the effective stress tensor
        virtual tmp<volSymmTensorField> devRhoReff() const;
        //- Return the source term for the momentum equation
        virtual tmp<fvVectorMatrix> divDevRhoReff(volVectorField& U) const;
            const volScalarField& rho,
            volVectorField& U
        ) const;
        //- Solve the turbulence equations and correct the turbulence viscosity
        virtual void correct() = 0;
} // End namespace Foam
#ifdef NoRepository
    #include "linearViscousStress.C"
#endif
#endif
linearViscousStress.C:
#include "linearViscousStress.H"
#include "fvc.H"
#include "fvm.H"
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::linearViscousStress<BasicTurbulenceModel>::linearViscousStress
        modelName,
        alpha,
        rho,
        U,
        alphaRhoPhi,
        phi,
        transport,
        propertiesName
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
bool Foam::linearViscousStress<BasicTurbulenceModel>::read()
    return BasicTurbulenceModel::read();
Foam::tmp<Foam::volSymmTensorField>
Foam::linearViscousStress<BasicTurbulenceModel>::devRhoReff() const
    return tmp<volSymmTensorField>
        new volSymmTensorField
            IOobject
                IOobject::groupName("devRhoReff", this->alphaRhoPhi_.group()),
                this->runTime_.timeName(),
                this->mesh_,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            (-(this->alpha_*this->rho_*this->nuEff()))
           *dev(twoSymm(fvc::grad(this->U_)))
Foam::tmp<Foam::fvVectorMatrix>
Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff
    volVectorField& U
) const
    return
      - fvc::div((this->alpha_*this->rho_*this->nuEff())*dev2(T(fvc::grad(U))))
      - fvm::laplacian(this->alpha_*this->rho_*this->nuEff(), U)
    volVectorField& U
) const
    return
      - fvc::div((this->alpha_*rho*this->nuEff())*dev2(T(fvc::grad(U))))
      - fvm::laplacian(this->alpha_*rho*this->nuEff(), U)
void Foam::linearViscousStress<BasicTurbulenceModel>::correct()
    BasicTurbulenceModel::correct();
Last edited by wyldckat; August 5, 2019 at 20:21. Reason: Added [CODE][/CODE] markers
rod_petrone is offline   Reply With Quote
Old   April 15, 2019, 05:28
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
There is no class named BasicTurbulenceModel, it is a template parameter from which some classes are also derived from. In order to make sense of this, get familiar with the C++ concepts of object orientation, inheritace and templates.
In OpenFOAM's hierarchy of turbulence models, there are two basic categories of turbulence models: incompressible and compressible ones.
Thus, OpenFOAM derives from the base-class of all turbulence models turbulenceModel two classes: incompressibleTurbulenceModel and compressibleTurbulenceModel.
These two classes are then used as template parameter to build the model-trees for incompressible and compressible turbulence models.
Unfortunately, the organisation of the turbulence model classes is not easy to get to understand, and it is also not easy to explain, at least for me. However, it is a brilliant way to avoid the code duplication that was there before. Download the sources of any OpenFOAM version prior to 3.0, and expore the content of $FOAM_SRC/turbulenceModels. Easier to grasp, yet lots of duplicated code.
rod_petrone and oaklet like this.
GerhardHolzinger is offline   Reply With Quote
Old   April 15, 2019, 06:16
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
You can find the compressible part here: https://openfoam.top/en/turb/
Sorry for that the language is Chinese.
But the UML is clear:
zhangyan is offline   Reply With Quote
Old   April 15, 2019, 09:27
Hi Gerhard,
I am familiar with many of this C++ concepts of object orientation, inheritace and templates, what i have not understand it was the template parameter used as a parent class, i haven't seen this before. But i think i was able to understand now. At the same time, BasicTurbulenceModel is a parameter, this parameter becomes the parent class of linearViscousStress class.
OpenFOAM version prior to 3.0 i understand the turbulence models class, because i had to implement turbulence models in OpenFOAM 2.3 to my master thesis.
Thank you for the answer.
Best regards,
Rodrigo Petrone
basicturbulencemodel, openfoam6, turbulencemodels
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Possible bug in OpenFoam Interpolation class MMC15 OpenFOAM Bugs 2 March 23, 2014 13:55
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
