Temperature calculation from sensible internal energy
Like Tree1Likes
  • 1 Post By zhangyan
Old   April 12, 2019, 06:42
Default Temperature calculation from sensible internal energy
Matteo
Zanco is on a distinguished road
Hi guys. I'm writing a code using the NACA0012 airfoil tutorial for rhoSimpleFoam compressible solver as a guide.
Actually I'm not able to figure out how the temperature is calculated. I mean, If I'm right everything should be done inside the hePsiThermo.C and thermoI.H files where thermo.correct() and calculate() functions are defined.
Temperature calculation is coded this way:
Test = Tnew;
        Tnew =
            (this->*limit)
            (Test - ((this->*F)(p, Test) - f)/(this->*dFdT)(p, Test));
I cannot understand what the f stands for. To me this procedure looks like a Newton algorithm.
Inside the thermophysicalProperties these are the selected parameters:
thermoType
    type              hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie            specie;
    energy           sensibleInternalEnergy;
hConst means Cp = const. sensibleInternalEnergy means I have to use the TEs. Thus f = es and F = Es where
template<class Thermo, template<class> class Type>
inline Foam::scalar
Foam::species::thermo<Thermo, Type>::Es(const scalar p, const scalar T) const
    return this->Hs(p, T) - p/this->rho(p, T);
and
inline Foam::scalar
Foam::species::thermo<Thermo, Type>::es(const scalar p, const scalar T) const
    return this->Es(p, T)*this->W();
So Es should be the internal energy that is defined as enthalpy minus pressure over density while es (read f) is defined as Es times molecular weight.
Does anyone of you know what it stands for and why it should be there? I cannot understand exactly which is the whole functional I have to use inside the Newton iterations.
Thanks a lot to anyone who can help me.
Zanco is offline   Reply With Quote
Old   April 12, 2019, 15:48
clapointe is on a distinguished road
Check out this post by fumiya : http://caefn.com/openfoam/temperature-calculation.
Caelan
clapointe is offline   Reply With Quote
Old   April 15, 2019, 10:44
Matteo
Thank you for the answer. Unfortunately I've already seen that post and there are two points making it unuseful to me:
1 in that case enthalpy is considered instead of sensible internal energy;
2 the Newton method part is not explained, they just say a Newton method is applied and nothing more.
Is there anybody having an answer to my doubats?
Old   April 15, 2019, 15:11
The code for the newton method is provided, so I don't see the problem. Or a quick google search for the newton method will provide answers. Following the nice explanation in the link provided, we can find equivalent functions to back out temperature from internal energy -- it actually uses the same newton method, just with different inputs :
inline Foam::scalar Foam::species::thermo<Thermo, Type>::TEs
    const scalar es,
    const scalar p,
    const scalar T0
) const
    return T
        es,
        p,
        T0,
        &thermo<Thermo, Type>::Es,
        &thermo<Thermo, Type>::Cv,
        &thermo<Thermo, Type>::limit
So there you have it.
Caelan
Old   April 16, 2019, 04:46
Matteo
Probably I did not exlain well what I'm looking for. I've already written what you posted in the last reply in the first part of my thread. I know what a Newton method is, I know I have to put F=Es and f=es. The point is that I cannot understand the physical meaning of es or, if you prefer, which is the physical functional I have to put equal zero for the Newton method: x1 = x0 - G(x0)/G'(x0). What is G(x) in my case?
Old   April 16, 2019, 10:37
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
T_new = T_old - [ Hs(p_old,T_old) - hs_fromTransportEqn]/ Cp(p_old,T_old)
hwangpo likes this.
https://openfoam.top
zhangyan is offline   Reply With Quote
Total vs Internal Energy acalado FLUENT 2 May 3, 2018 18:08
Adding pressure and temperature sources instead of energy rae CFX 3 October 24, 2016 03:31
warning - extrapolating on temperature calculation cedame CONVERGE 2 September 5, 2016 12:55
Temperature to energy loss Vcent FLUENT 0 November 28, 2012 11:13
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
