Antti Hellsten model: New Advanced k–ω Turbulence Model for High-Lift Aerodynamics
Like Tree2Likes
  • 1 Post By mAlletto
Old   April 3, 2019, 11:19
Default Antti Hellsten model: New Advanced k–ω Turbulence Model for High-Lift Aerodynamics
Purn Prakash
purnp2 is on a distinguished road
Thanks for your attention.
Purpose of this thread- I am looking for help on the above title which I'll call "Hellsten model" (2005.
I am a student and new to the OpenFOAM software. Currently, I am working on a project and the first step of this project is a simulation of flow over a flat plate using the Hellsten model).
The problem is I can't find any pre-developed Hellsten model anywhere on the internet. So, I want to request that if someone has already developed this model in OpenFOAM then kindly share it with me. If no one has then can you please take a look at this model and suggest me which other model has a similar structure and is available for OF so that I can edit this second model into the Hellsten model.
Thank you in advance for the time you are going to put for me.
1. I am using OF1812+ on Ubuntu 1804.
2. Here is the link of the Hellsten model:
https://drive.google.com/open?id=1EJ...tplVWS6_TqR6i-
purnp2 is offline   Reply With Quote
Old   April 6, 2019, 13:50
Michael Alletto
mAlletto will become famous soon enough
You can find something similar in this masterthesis https://www.google.com/url?sa=t&sour...AFUhDtzdYAHvQP. Source code is in the thesis. The may be a starting point for your thesis.
purnp2 likes this.
mAlletto is offline   Reply With Quote
Old   April 6, 2019, 15:07
Michael Alletto
This may also be usefull A new EARSM turbulence model implementation
purnp2 likes this.
Old   May 10, 2019, 13:29
Smile
Purn Prakash
1. Thank you very much for your time and effort, Sir Allento. I'll take references from the above sources.
2. Because those codes are developed for old versions of OF, I am posting a new thread with a fresh question:
3. Can anyone suggest me which standard RAS model supplied with OF1812+ I should use to edit and develop my own model of AnttiHellsten?
The list of RAS models available is :
20
LRR
LamBremhorstKE
LaunderSharmaKE
LienCubicKE
LienLeschziner
RNGkEpsilon
SSG
ShihQuadraticKE
SpalartAllmaras
bslearsm
kEpsilon
kEpsilonLopesdaCosta
kOmega
kOmegaSST
kOmegaSSTLM
kOmegaSSTSAS
kkLOmega
qZeta
realizableKE
v2f
earsm, hellsten, k-omega model, k-w model, turbulence model
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Turbulence model for Aerodynamics David Baker Siemens 3 August 6, 2003 05:16
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
