Problem compiling new solver with wmake
Like Tree6Likes
  • 1 Post By Flopi
  • 1 Post By mAlletto
  • 1 Post By ELwardi
  • 3 Post By Flopi
Old   March 27, 2019, 09:49
Default Problem compiling new solver with wmake
Flopi is on a distinguished road
Dear all,
I'm beginning OpenFOAM to solve a advection-diffusion-reaction equation. I started with the scalarTransportFoam solver and wanted to expand it. So I my due diligence and followed the steps in the tutorials to copy and start a new solver.
However, when I try to compile it (even without any change in the code) I have the following error message:
make: *** no rule to make target « Make/mingw_w64GccDPInt32Opt/my_scalarTransportFoam.C.dep », necessary for « Make/mingw_w64GccDPInt32Opt/my_scalarTransportFoam.o ». stop.
(translation from the french error message)
I have openfoam installed on windows through blueCFD.
Any idea of what's the issue ?
Thanks,
Flo
joshmccraney likes this.
Flopi is offline   Reply With Quote
Old   March 29, 2019, 14:51
Michael Alletto
mAlletto will become famous soon enough
You geht this error when the path to the file .c is not correct
foamiste likes this.
mAlletto is offline   Reply With Quote
Old   March 30, 2019, 08:35
Elwardi Fadeli
ELwardi is on a distinguished road
Just as mAlletto said:
1- The path to the source file (*.C) in Make/files (the first line is incorrect). You probably forgot to
mv scalarTransportFoam.C my_scalarTransportFoam.C
2- Depending on where you installed OpenFOAM, you may not have access to write binary files to the default path; you need to change Make/files to build the solver somewhere you can write to .
Your Make/files should spell out like this:
EXE = $(FOAM_USER_APPBIN)/my_scalarTransportFoam
tbhanderi likes this.
ELwardi is offline   Reply With Quote
Old   April 2, 2019, 11:02
I got the answer from another forum. The error was that I used lower case .c instead of .C
Thanks for the help,
XJ_Wang, PuWang and tbhanderi like this.
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 06:37
Problems about compiling OF1.5.x on Bluegene/P ywang OpenFOAM 1 August 25, 2011 06:22
Problem in Compiling the solver m.maneshi OpenFOAM Running, Solving & CFD 4 November 3, 2010 03:07
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
