Block coupling three equations using foam extend 4.1
Like Tree1Likes
  • 1 Post By ELwardi
Old   March 16, 2019, 12:29
Question Block coupling three equations using foam extend 4.1
Elwardi Fadeli
ELwardi is on a distinguished road
Hi all,
I'm using (trying to use ) foam-extend's coupledFvMatrix (https://github.com/Unofficial-Extend...vBlockMatrix.H)
to couple three equations. The coupling terms consist of "laplacians" and Time derivatives .
This thread explains how I'm approaching this and what the current results are. I know I'm doing something (Or more) wrong since these results are not sane enough .
First, construct a volVectorField to hold solved (scalar) Fields:
volVector3Field pSwSg
    IOobject
        "pSwSg",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    mesh,
    dimensionedVector3("zero", dimless, vector3::zero)
Later in the code, define each fvScalarMatrix; for example:
// "Main" pressure equation
fvScalarMatrix pEqn
     fvm::ddt(M, p) + fvm::laplacian(-D, p) + fvc::div(somePhi)
// Coupled term between pEqn and some other SwEqn
fvScalarMatrix SwInp
    - fvm::ddt(M1, Sw) // and maybe fvm::laplacian(D1, Sw)
The actual coupling is carried out when creating the block matrix:
// Instantiate the coubled matrix
fvBlockMatrix<vector3> resEqn(pSwSg);
// Add equations
resEqn.insertEquation(0, pEqn);
resEqn.insertEquation(1, SwEqn);
resEqn.insertEquation(2, SgEqn);
// Insert coupling terms
// Sw term in pEqn:
 resEqn.insertEquationCoupling(0, 1, SwInp);
// Note that SwInp is a fvScalarMatrix
 // Add more couplings ...
After this, we solve the blockMatrix and retrieve solutions.
The problem is, inserting the following code:
Info<< "Lower Coupling:" <<
    << resEqn.coupleLower() << nl
    << "Upper Coupling:" <<
    << resEqn.coupleUpper() << nl
    << "Component Coupled:" <<
    << resEqn.componentCoupled() << nl
    << "Coupled Diagonal:" << nl
    << resEqn.diag() << endl;
somewhere before solving the equation, and testing it on a minimal case (1D 5cells mesh), results in the following output:
Lower Coupling:
3
unallocated
1
unallocated
1
unallocated
0
Upper Coupling:
3
unallocated
1
unallocated
1
unallocated
0
Component Coupled:
1
Coupled Diagonal:
square
5
(-865.137 -7.42132e-07 -7.42132e-07 21.9694 7.42132e-06 0 -129771 -0.00011132 -0.000103899)
(-14549.7 -1.51723e-13 -1.51723e-13 368.569 1.51723e-12 0 -2.18245e+06 -2.27584e-11 -2.12412e-11)
(-302060 -4.08706e-29 -4.08706e-29 7645.23 4.08706e-28 0 -4.5309e+07 -6.13059e-27 -5.72188e-27)
(-1.3066e+07 -8.3987e-74 -8.3987e-74 330590 8.3987e-73 0 -1.95991e+09 -1.2598e-71 -1.17582e-71)
(-1.27778e+07 -3.88293e-254 -3.88293e-254 323294 3.88293e-253 0 -1.91666e+09 -5.8244e-252 -5.4361e-252)
GMRES:  Solving for pSwSg, Initial residual = (0.006936 0.000167427 0.992364), Final residual = (2.11584e-12 7.29283e-15 1.42317e-14), No Iterations 1
Huh, no upper/lower coupling .
Any help or orientation to some reference materials is greatly appreciated.
Best regards,
Kummi likes this.
ELwardi is offline   Reply With Quote
Old   March 18, 2019, 22:20
Hrvoje Jasak
Are you looking at the right place? Look at the matrix: there is diag, upper and lower; then there is out-of-core coefficient like processor boundaries.
From your output, you MUST get block clefs for upper and lower; otherwise GMT’s would not be called. I think you are looking at the wrong place.
I also have doubts about your cross-mciupling matrix, but that’s another thing...
Hrvoje Jasak
Old   March 19, 2019, 11:35
Elwardi Fadeli
Mr @hjasak, thank you for your reply.
As you pointed out, the coupled matrix seems to be OK unless I'm making a vague, invalid assumption somewhere (detailed log attached).
I need to be 100% sure of something though; Does
fvBlockMatrix::insertEquationCoupling(id1, id2, 2In1)
insert the matrix 2In1 as coupling term of variable of equation 2 in equation1 ?
(following the same convention of insertBlockCoupling used in pUCoupledFoam) Or is it the other way around.
block matrix, block-coupling, foam ext 4.0, foam extend
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
