March 13, 2019, 08:56 |
Add a mass source/sink to simpleFoam
Pablo Alarcón
Rep Power: 8 |
Hello everybody
I want to add a mass source/sink term to the simpleFoam solver, but I fear that it will need more modifications than I would expect. In summary, what I want to code is the following system: S Given the fact that is no longer equal to 0, I assume that in addition to the pressure equation, the stress computation will be also affected, meaning that adding that source term is not as easy as adding a constant to the continuity equation. My question is, is there any way of adding that source term into simpleFoam, without going into deep modification of additional functions like devDivReff or others? I was looking and I found that using fvOption could be an option to add a source term without modifying the solver, but it will add a source term to the momentum equation, not to the continuity equation. Last edited by palarcon; March 14, 2019 at 03:58. |
May 13, 2019, 10:50 |
Niu
Rep Power: 12 |
Hi Pablo,
Have u got it? Thanks! |
May 14, 2019, 12:58 |
Michael Alletto
Rep Power: 16 |
in the solver firefoam there is mass source term included. it has to be added in the pressure equation.
you can have a look https://openfoamwiki.net/index.php/FireFoam where the principle is explained a bit. |
May 15, 2019, 03:31 |
Pablo Alarcón
Rep Power: 8 |
Hi.
Yes, I did, but not in a "simple way" like I was looking for. I developed all the equations by hand starting from the transport equations and then I add the necessary terms to the mass equation and the momentum equation. After that, I just wrote on the code the resultant equations. |
May 15, 2019, 03:33 |
#5 | |
Pablo Alarcón
Rep Power: 8 |
Pablo |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
[PyFoam] and paraview | eelcovv | OpenFOAM Community Contributions | 28 | May 30, 2016 10:23 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
mass does not conserve in Openfoam | conceptone | OpenFOAM | 5 | February 8, 2013 04:35 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
