Impose volume mesh vertex motion with external library |
March 11, 2019, 11:51 |
Dave
Rep Power: 16 |
Hello all,
I am currently trying to couple an external mesh deformation library to pimpleDymFoam of v1812. The external library is in Fortran90 so I pass the components of the mesh vertices for both the volume mesh and the boundary mesh to the library. The library returns the components of the mesh vertex displacements and I can convert these 1D arrays into the vectorField type of OpenFOAM. I manage to apply the deformations of the boundaries and propagate the displacements using: pointDisplacement.boundaryFieldRef()[iPatch] == displacementValues; where displacementValues is a vectorField of the given patch's vertex displacements. Here I am using dynamicMotionSolverFvMesh and displacementLaplacian. In contrast, I am struggling to directly deform the volume mesh along the lines of: Manipulation of every single mesh node inside the domain (OpenFoam) Trying to add the code of the above post into the pimpleDymFoam solver I find that it compiles fine, but that the mesh doesn't move. ie: vectorField newPoints = mesh.points() + volumeDisp; mesh.movePoints(newPoints); Adding mesh.update() changes nothing. Has anyone got any experience with how to directly impose the internal mesh vertex positions? Should I continue to try using something along the lines of: pointDisplacement.somethingHere() == volumeDisp (of type vectorField) or is the solution further afield like adding a meshSolver type that takes as input a user input vectorField? Note, re-implementing the deformation library internally to OpenFOAM is not an option for me. Thanks in advance for any help! -Dave |
March 13, 2019, 07:37 |
Atul Kumar
Location: National Centre for Combustion Research and Development
Rep Power: 10 |
Can you please put whole case/changes ??
mesh deformation, openfoam 1812, volume mesh |
ill defined primitive entry 'boundary' | francisco.angel | OpenFOAM Pre-Processing | 16 | September 8, 2022 06:11 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
