Question about lookupObject function
Like Tree1Likes
  • 1 Post By zhangyan
Old   February 3, 2019, 04:05
Question Question about lookupObject function
LT
NewKid is on a distinguished road
Hi, everyone.
To investigate the interactions between the gas and the injected liquid, I just modified one turbulence model source file. In this source file, I must read every parcel of the spray cloud to calculate the interaction. Therefore, lookupObject function may be called as follows.
const basicSprayCloud & cloud = (this->mesh_.objectRegistry.template lookupObject<basicSprayCloud>("sprayCloud"));
Anyway, the compiling message says:
error: reference to 'Foam::SprayCloud<Foam::ReactingCloud<Foam::Thermo Cloud<Foam::KinematicCloud<Foam::Cloud<Foam::Spray Parcels<Foam::ReactingParcel<Foam::ThermoParcel<Fo am::KinmaticParcel<Foam::Parcel>>>>>>>>>::typeName is ambiguous'
where basicSprayCloud and sprayCloud are declared in createClouds.H as follows:
Info<<"\nConstructing reacting cloud" << endl;
basicSprayCloud parcels
"sprayCloud",
rho,
U,
g,
slgThermo
So how to call lookupObject function properly to get the sprayCloud in turbulence model (k function)?
NewKid is offline   Reply With Quote
Old   February 3, 2019, 07:06
Andrew Somorjai
massive_turbulence is on a distinguished road
Originally Posted by NewKid View Post
Hi, everyone.
"sprayCloud",
rho,
U,
g,
slgThermo
This might help inject particles of different densities - kinematiccloud
"What i did so far is to just add a second cloud in the createClouds.C:"
Info<< "\nConstructing bubble cloud" << endl;
basicSprayCloud bubbles
    "bubbles",
    rho,
    U,
    g,
    slgThermo
Info<< "\nConstructing catalysator cloud" << endl;
basicSprayCloud cat
    "cat",
    rho,
    U,
    g,
    slgThermo
Did you try doing this with createClouds.C, because you said you did it in createClouds.H? Maybe that's all?
massive_turbulence is offline   Reply With Quote
Old   February 3, 2019, 10:13
LT
Hi, massive_turbulence,
Thanks a lots!
The createClouds.H is one original file of the source files of solver "sprayFoam", what I'm trying to do is to get the "sprayCloud" in the turbulence model file with lookupObject function instead of to declare it in createClouds.H.
Thanks for your kindest helps!
Old   February 3, 2019, 11:34
Andrew Somorjai
Thanks a lots!
You mean inside the /constant/turbulenceProperties file?
I think you could compile a .so file and call it from "/constant/turbulenceProperties" instead as a type but I'm guessing and it's far fetched in terms of the coding. You would still need to declare it in the createClouds.H and then you create a new library file to your liking and place it in the lib folder, something like "OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/"
Either that or this might help objectRegistry::lookupObject<scalar>
Old   February 10, 2019, 22:34
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
Did you try this:
const basicSprayCloud & cloud = dynamic_cast<const basicSprayCloud&>(this->mesh_.objectRegistry::lookupObject<sprayCloud>("sprayCloud"));
Tobermory likes this.
https://openfoam.top
zhangyan is offline   Reply With Quote
Old   February 12, 2019, 05:24
LT
Hi, ZhangYan, your code works! Thanks very much!
And what's the parcelType of every parcel in this cloud if I have to access every parcel's parameters, such like velocity, mu, density or something like that.
const parcelType& droplet=cloud[index];
Old   February 12, 2019, 22:55
Question
LT
After getting "cloud" as mentioned above, to traverse the parcels in the cloud, a forAll macro is called as follows:
forAll(cloud,parcelI)
const basicSprayParcel& droplet=dynamic_cast<const basicSprayParcel&>(cloud[parcelI]);
}//Compiling error: cloud has no operator []
where parcelI is the "index" in const parcelType& droplet=cloud[index];
Or another macro
forAllConstIter(typename SprayCloud<CloudType>,*cloud,iter)
The latter shows compiling errors too.
Old   February 12, 2019, 23:21
Andrew Somorjai
Or another macro
The bracket operator is probably not overloaded for that type but there might be a function call that returns what you need, otherwise you'll need to write your own overloaded [] and return whatever cloud has at that index.
Old   February 13, 2019, 15:48
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You cannot use a [] operator since a cloud is not a random access array. You can use an iterator access with begin/end. If you are using OpenFOAM-v1712 or newer, the iterators are properly defined and you can use a for-range as well.
olesen is offline   Reply With Quote
Old   February 13, 2019, 16:12
Andrew Somorjai
It must be a list then, like a STL list with an iterator?
Old   February 13, 2019, 23:31
Question
  #11
LT
Olsen and massive_turbulence, thank both of you!
I tried forAllConstIter macro, anyway, the proper type of iterator, or the parameters of forAllConstIter(typename SprayCloud<CloudType>,*cloud,iter) confuse me since "cloud" is retrieved via "const basicSprayCloud & cloud = dynamic_cast<const basicSprayCloud&>(this->mesh_.objectRegistry::lookupObject<sprayCloud>("s prayCloud"));"
Any clues?
I use OF 4.0.
Old   February 14, 2019, 00:09
Andrew Somorjai
Any clues?
This typename SprayCloud<CloudType> is somehow equivalent to this dynamic_cast<const basicSprayCloud&>(this->mesh_.objectRegistry::lookupObject<sprayCloud>("s prayCloud"))
Dynamic casting works by going up a "tree" of sorts in the object hierarchy and somehow that gets created at runtime. I'm not too clear on the process either.
Old   February 14, 2019, 03:45
Question
  #13
LT
I agree with Olesen, it is impossible to traverse the parcels with operator [], iterator is a good choice!
Therefore, the question is how to traverse the parcels of the "cloud" via iterator, i.e. the parameters of forAllConstIter() macro.
And what is the difference between forAllConstIter() and forAllIter()?
Old   February 14, 2019, 04:32
Smile Thanks!!! Seems solved!
  #14
LT
Thanks all the contributors to this thread!
It seems this problem is solved, details come as follows:
1. Get the cloud
2. Traverse all the parcels
forAllConstIter(typename basicSprayCloud, cloud, iter)
3. Access every parcel in the cloud
const basciSprayParcel & d =iter();
d has many attributes, enjoy it!
After all the steps above, write your code in turbulence model source file!
Once there is something wrong or not complete/proper, please let me know or email me: swust_lt@sina.com
interaction, lookupobject, spraycloud, template
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
