Unable to compile a source from an old repo?
Like Tree3Likes
  • 3 Post By Daniel_Khazaei
Old   January 15, 2019, 20:58
Default Unable to compile a source from an old repo?
Andrew Somorjai
massive_turbulence is on a distinguished road
Hello All,
I'm trying to get this code to compile so that I can see what it does but for some reason it's hung up over this
solver.C:34:65: error: passing ‘const Internal {aka const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>}’ as ‘this’ argument discards qualifiers [-fpermissive]
     U.internalField() = axis ^ (centres.internalField() - origin);
Here's the full code
#include "fvCFD.H"
int main(int argc, char *argv[])
	#include "setRootCase.H"
	#include "createTime.H"
	#include "createMesh.H"
    Info<< "Time = " << runTime.value() << endl;
    Info<< "    Reading U" << endl;
    volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
        mesh
    // Do cells
    const volVectorField& centres = mesh.C();
    point origin(1, 1, 0.05);
    vector axis(0, 0, -1);
    U.boundaryField()[0] == (axis ^ (centres.boundaryField()[0] - origin));
    U.boundaryField()[1] == (axis ^ (centres.boundaryField()[1] - origin));
    U.boundaryField()[2] == (axis ^ (centres.boundaryField()[2] - origin));
    U.write();
    Info<< "End\n" << endl;
    return(0);
and the link to the original Github
Please let me know if there are other ways to do the same thing or something similar.
massive_turbulence is offline   Reply With Quote
Old   January 15, 2019, 22:51
Daniel
Daniel_Khazaei will become famous soon enough
you haven't said what OpenFOAM version you are trying to compile this piece of code on, but if the latest version is involved, you may try this:
U.primitiveFieldRef() = axis ^ (centres.primitiveField() - origin);
U.boundaryFieldRef()[0] == (axis ^ (centres.boundaryField()[0] - origin));
U.boundaryFieldRef()[1] == (axis ^ (centres.boundaryField()[1] - origin));
U.boundaryFieldRef()[2] == (axis ^ (centres.boundaryField()[2] - origin));
In recent versions, internalField() and boundaryField() functions both return a "const" reference to the internal field and boundary field of an object, respectively! So you can't modify them and need to use the above method.
Daniel_Khazaei is offline   Reply With Quote
Old   January 16, 2019, 11:13
Andrew Somorjai
OpenFOAM 6 v1806. Thank you sir!
compilation error, internalfield
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
