November 28, 2018, 10:04 |
coded function object in parallel
Daniel
Rep Power: 21 |
Hi foamers,
This piece of code does compile and run in serial mode normally, however when I try to run it in parallel it compiles successfully (although it takes much longer to compile) it only create the output file but it doesn't write anything into the file! Perhaps the code is not ready for parallel? where do I need to modify to make it work? Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interfsiFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 60; deltaT 1e-5; writeControl adjustableRunTime; writeInterval 0.02; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 7; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.2; maxDeltaT 1e-3; maxAlphaCo 0.2; maxFourier 1.0; InfoSwitches { allowSystemOperations 1; } //- real-time temperature monitoring utility functions ( temperatureRange { functionObjectLibs ("libutilityFunctionObjects.so"); type coded; redirectType temperatureRange; outputControl timeStep; outputInterval 10; code #{ //- Get temperture field const volScalarField& T = mesh().lookupObject<volScalarField>("T"); //- Get simulation time scalar t = mesh().time().value(); //- Now printing out the results if(Pstream::master()) { std::ofstream fs; fs.open ("temperatureRange.dat", std::fstream::app); fs.precision(12); fs << t << "\t" << min(T).value() << "\t" << max(T).value() <<"\n"; fs.close(); } #}; codeInclude #{ #include <fstream> #}; } ); // ************************************************************************* // D.Khazaei Last edited by Daniel_Khazaei; December 4, 2018 at 08:51. |
December 4, 2018, 05:36 |
Rep Power: 11 |
Hello Daniel,
I am facing the same problem. My coded function object compiles and runs properly in serial but it is completely ignored (not even compiled!) in parallel. Did you manage to find a solution? I am using OpenFOAM v2.4 by the way. USV |
December 4, 2018, 09:01 |
#3 | |
Daniel
Rep Power: 21 |
mine does compile but as I said it takes much longer and only creates the output file without writing anything into it! probably @wyldckat may be able to help us if he has time |
December 16, 2018, 20:13 |
Daniel
Rep Power: 21 |
anybody can help us regarding this problem?
December 21, 2018, 12:39 |
Mark Olesen
Rep Power: 40 |
I don't have any experience with extend, but are the min()/max() functions there meant for parallel or serial?
If they are parallel operations, I'd think they'd block indefinitely since you have them only being invoked on the master process. If that doesn't work for you. I'd suggest grabbing some other version (1806, 1812,..) and trying exactly the same bit of coding on one of the tutorials. Another option. Try just writing out some the time (without min/max) in your file. If this produces content for you, you've found the problem. /mark |
December 22, 2018, 04:29 |
#6 | |
Daniel
Rep Power: 21 |
//- real-time temperature monitoring utility functions ( temperatureRange { functionObjectLibs ("libutilityFunctionObjects.so"); type coded; redirectType temperatureRange; outputControl timeStep; outputInterval 50; code #{ //- Get temperture field const volScalarField& T = mesh().lookupObject<volScalarField>("T"); //- Get velocity vector field const volVectorField& U = mesh().lookupObject<volVectorField>("U"); const volScalarField magU = mag(U); //- Get simulation time scalar t = mesh().time().value(); scalar dt = mesh().time().deltaTValue(); //- Get the bounds scalar maxMagU = max(magU).value(); scalar maxT = max(T).value(); scalar minT = min(T).value(); //- Now printing out the results if(Pstream::master()) { std::ofstream fs; fs.open ("temperatureRange.dat", std::fstream::app); fs.precision(12); fs << t << "\t" << dt << "\t" << maxMagU << "\t" << minT << "\t" << maxT << "\n"; fs.close(); } #}; codeInclude #{ #include <fstream> #}; } ); Regards, Daniel |
December 22, 2018, 11:02 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions: Can you provide the Allrun complete script you are using? Or at least indicate which exact commands you are running in the command line?
December 22, 2018, 11:52 |
#8 | |
Daniel
Rep Power: 21 |
Here is the AllrunPar script I'm using for this case: Code:
#!/bin/sh # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions # Get application name application=`getApplication` mkdir -p ../solid/0 cp -r ../solid/orig/* ../solid/0/ runApplication -l log.fluent3DMeshToFoam.solid fluent3DMeshToFoam -case ../solid/ ../solid/solid.msh runApplication -l log.changeDictionary.solid changeDictionary -case ../solid runApplication -l log.renumberMesh.solid renumberMesh -overwrite -case ../solid runApplication -l log.setSet.solid setSet -case ../solid -batch ../solid/setBatch runApplication -l log.setsToZones.solid setsToZones -case ../solid -noFlipMap runApplication -l log.setFields.solid setFields -case ../solid runApplication -l log.decomposePar.solid decomposePar -case ../solid mkdir -p 0 cp -r orig/* 0/ runApplication fluent3DMeshToFoam fluid.msh runApplication changeDictionary runApplication renumberMesh -overwrite runApplication setSet -batch setBatch runApplication setsToZones -noFlipMap runApplication setFields runApplication decomposePar cd .. ./makeLinks fluid solid cd fluid runParallel $application 2 runApplication reconstructPar runApplication -l log.reconstructPar.solid reconstructPar -region solid # ----------------------------------------------------------------- end-of-file |
December 22, 2018, 12:49 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi Daniel,
Something doesn't sound right here... a few more questions:
The only reason for it to be slower in compiling when running in parallel, is if:
Best regards, Bruno |
December 22, 2018, 12:57 |
#10 | ||
Daniel
Rep Power: 21 |
thank you very much Bruno Regards, Daniel |
December 22, 2018, 13:01 |
#11 | |
Bruno Santos
Rep Power: 128 |
In that case, you must first test if this also occurs with foam-extend 4.1 (4.0-nextRelease) or not, just to ensure that this wasn't something you introduced yourself Additionally, you might want to hack into the code that handles the calls to wmake for the coded function object and use "Pout" instead of "Info", to make it output the messages not only for the master process, but also the slave ones. |
December 26, 2018, 00:19 |
#12 | |
Daniel
Rep Power: 21 |
I have just tried to follow your suggestion and installed fresh copy of foam-extend-4.1 (nextRelease branch)! The behavior is the same...so the bug is not mine what I have forgot to say before is that the compilation process itself runs just fine, however the solver waits for a long time after the Code:
'....so' is up to date Here is a sample log: Code:
Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Creating field DpDt Starting time loop Using dynamicCode for functionObject temperatureRange at line 70 in "::temperatureRange" Creating new library in "dynamicCode/temperatureRange/platforms/linux64GccDPOpt/lib/libtemperatureRange_960cb3ad9b821b535c5532223dd972a7d13833d0.so" Invoking "wmake -s libso /home/shadowfax/foam/shadowfax-4.1/run/tutorials/compressible/rhoPimpleFoam/angledDuct/dynamicCode/temperatureRange" wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file functionObjectTemplate.C Making dependency list for source file FilterFunctionObjectTemplate.C SOURCE=functionObjectTemplate.C ; g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -g -I/home/shadowfax/foam/foam-extend-4.1/src/finiteVolume/lnInclude -I/home/shadowfax/foam/foam-extend-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude -I/home/shadowfax/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/functionObjectTemplate.o SOURCE=FilterFunctionObjectTemplate.C ; g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -g -I/home/shadowfax/foam/foam-extend-4.1/src/finiteVolume/lnInclude -I/home/shadowfax/foam/foam-extend-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude -I/home/shadowfax/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/FilterFunctionObjectTemplate.o '/home/shadowfax/foam/shadowfax-4.1/run/tutorials/compressible/rhoPimpleFoam/angledDuct/dynamicCode/temperatureRange/../platforms/linux64GccDPOpt/lib/libtemperatureRange_960cb3ad9b821b535c5532223dd972a7d13833d0.so' is up to date. Code:
Courant Number mean: 0 max: 0 velocity magnitude: 0 Time = 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 BiCGStab: Solving for Ux, Initial residual = 1, Final residual = 0.00374194, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.00575923, No Iterations 1 BiCGStab: Solving for Uz, Initial residual = 1, Final residual = 0.00920929, No Iterations 1 BiCGStab: Solving for h, Initial residual = 1, Final residual = 0.00613828, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00996037, No Iterations 82 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.12402, global = -0.0112633, cumulative = -0.0112633 rho max/min : 1.18758 1.1863 BiCGStab: Solving for epsilon, Initial residual = 0.898069, Final residual = 2.79157e-06, No Iterations 4 BiCGStab: Solving for k, Initial residual = 1, Final residual = 5.4789e-06, No Iterations 2 PIMPLE: iteration 2 BiCGStab: Solving for Ux, Initial residual = 0.680134, Final residual = 0.0040336, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0.288343, Final residual = 0.00156818, No Iterations 1 BiCGStab: Solving for Uz, Initial residual = 0.721388, Final residual = 0.00352804, No Iterations 1 BiCGStab: Solving for h, Initial residual = 1, Final residual = 0.0063911, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.501305, Final residual = 0.00459142, No Iterations 83 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.21116, global = 0.00796014, cumulative = -0.00330312 rho max/min : 1.20425 1.1863 BiCGStab: Solving for epsilon, Initial residual = 0.363985, Final residual = 8.11722e-07, No Iterations 6 BiCGStab: Solving for k, Initial residual = 0.221285, Final residual = 3.71386e-06, No Iterations 2 PIMPLE: iteration 3 BiCGStab: Solving for Ux, Initial residual = 0.781972, Final residual = 0.00337158, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0.723679, Final residual = 0.00315982, No Iterations 1 BiCGStab: Solving for Uz, Initial residual = 0.613821, Final residual = 0.00339603, No Iterations 1 BiCGStab: Solving for h, Initial residual = 0.889189, Final residual = 0.00303323, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.106732, Final residual = 0.000885835, No Iterations 81 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.89355, global = -0.0584832, cumulative = -0.0617864 rho max/min : 1.21736 1.1863 BiCGStab: Solving for epsilon, Initial residual = 0.306246, Final residual = 7.63149e-06, No Iterations 5 BiCGStab: Solving for k, Initial residual = 0.178564, Final residual = 6.25217e-06, No Iterations 2 PIMPLE: iteration 4 BiCGStab: Solving for Ux, Initial residual = 0.609119, Final residual = 0.00447596, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0.303115, Final residual = 0.00142949, No Iterations 1 BiCGStab: Solving for Uz, Initial residual = 0.221475, Final residual = 0.00141429, No Iterations 1 BiCGStab: Solving for h, Initial residual = 0.659225, Final residual = 0.00407236, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.136302, Final residual = 0.00117668, No Iterations 81 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 4.01168, global = -0.0285645, cumulative = -0.0903508 rho max/min : 1.21538 1.18647 Best Regards and Happy new year Daniel |
December 28, 2018, 16:29 |
#13 |
Bruno Santos
Rep Power: 128 |
Quick answer: I haven't built foam-extend 4.1 (nextRelease) yet and don't have plans to do so.
So either someone else here on the forum picks this up, or it's better for you to simply report this on the foam-extend bug tracker. Happy New Year, may 2019 be even more foamy... |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Coded function object in openfoam v5 | kit607 | OpenFOAM Post-Processing | 3 | September 29, 2020 16:43 |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 05:12 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
