Information exchange between processors
Like Tree9Likes
  • 3 Post By palmera2
  • 2 Post By olesen
  • 1 Post By olesen
Old   November 18, 2018, 07:02
Default Information exchange between processors
Anonymous
palmera2 is on a distinguished road
Hi!
I'm programming a parallel application for interpolation and I need to exchange information between processors. In particular, I have a List p with different size and elements in each processor and I want to merge all p and share it among processors.
I split the problem in two parts:
  1. Pass p from the different processors to processor0 and merge them in a List P
  2. Share List P among all processors
For 1) I did the following:
label n=Pstream::nProcs();
DynamicList<point> samplePosCellCenter;
// Sharing list samplePosCellCenter among processors
// Perhaps there is a more compact way of doing it through
// reduce(List<T>, binaryOP<>)
// Compiling list on master processor
if (Pstream::myProcNo() == 0)
    // Output variable for processor 0
    forAll(samplePosCellID, cellID)
        point cellCenter = mesh.C()[cellID];
        samplePosCellCenter.append(cellCenter);
    // Information exchange between processors
    for(label i=1; i<n; i++)
        // Local declaration of masterPlaceHolder
        List<point> masterPlaceHolder;
        // Create an input stream for processor i
        IPstream masterStream(Pstream::blocking, i);
        masterStream >> masterPlaceHolder;
        // Add elements of placeHolder to samplePosCellCenter
        forAll(masterPlaceHolder, proci)
            point cellCenterI = masterPlaceHolder[proci];
            samplePosCellCenter.append(cellCenterI);
else
    // Create stream to send slavePlaceHolder to the main proc
    DynamicList<point> slavePlaceHolder;
        slavePlaceHolder.append(cellCenter);
    OPstream slaveStream(Pstream::blocking, 0);
    slaveStream << slavePlaceHolder;
For 2) I did as follows:
// Sharing master's list among slaves
        // Create an output stream for processor i
        OPstream masterStream(Pstream::blocking, i);
        masterStream << samplePosCellCenter;
else
    // Create input stream to send share samplePosCellCenter from master to
    // slave processors
    IPstream slaveStream(Pstream::blocking, 0);
    slaveStream >> samplePosCellCenter;
The code above does work, but I'm pretty sure that there is a "cleaner" way of doing it. In the beginning I was thinking of using the reduce operation, but I didn't know which BinaryOp to use.
My question: Is there a cleaner way to merge lists from different processors?
Thank you in advance!
palmera2 is offline   Reply With Quote
Old   November 21, 2018, 20:15
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Not really sure what you want your final access to be. One flat list that is identical on all processors? Is this list appended with/without duplicates? Or do you just want everyone to know everything about each other?
https://www.openfoam.com/documentati...d51a9a321792d9
Eg,
.. taken from laserDTRM.C as an example
List<pointField> positions(Pstream::nProcs());
... fill in per processor
Pstream::gatherList(positions);
Pstream::scatterList(positions);
blue8803 and palmera2 like this.
olesen is offline   Reply With Quote
Old   November 24, 2018, 05:48
Anonymous
Dear Olesen,
Thank you very much for your answer and time. I have one list different in size and contents in each processor and I want everyone to know about each other (to share the contents of the list). For example, for a parallel simulation using 2 cores I could have the following lists:
[0] Processor 0: 1(0 1)
[1] Processor 1: 2(1)
And I would like to have the following:
[0] Processor 0: 3(0 1 1)
[1] Processor 1: 3(0 1 1)
Your solution indeed solved the problem! I attach a test implementation below:
// OpenFOAM
#include "fvCFD.H"
int main(int argc, char *argv[])
#   include "setRootCase.H"
#   include "createTime.H"
#   include "createMesh.H"
// Creating a different (both in size and contents) list for each processor
    // Number of processors
    label n = Pstream::nProcs();
    // Create a different test list in each processor
    DynamicList<label> prociList;
    label proci = Pstream::myProcNo();
    for (label i=proci; i<n;i++)
        prociList.append(i);
    // Printing list's elements for each processor
    Pout<< "Processor " << proci << ": " << prociList
        << nl;
    Info<< nl << endl;
// Implementing Olesen's reply on cfd-online
    // Creating a placeholder list
    List<List<label> > shareList(n);
    // Transfering prociList into the proci'th element of placeholder
    // list shareList. This removes the contents of prociList.
    shareList[proci].transfer(prociList);
    // Currently, only the proci'th element of list shareList is populated.
    // Gather the different shareList's of slave processors in master processor
    Pstream::gatherList(shareList);
    // Share masters' shareList to the rest of processors
    Pstream::scatterList(shareList);
    // Creating a single list with all elements
    forAll(shareList, listI)
        prociList.append(shareList[listI]);
    Pout<< "Size of resulting prociList: " << prociList.size() << nl
        << "prociList in proc " << proci << ": " << prociList << nl;
Thanks again!
Old   December 6, 2018, 05:34
Mark Olesen
For what it's worth, you can add some more modern coding - should work with 1712 and later, but you should check.
List<labelList> shareList(Pstream::nProcs()) ;
shareList[Pstream::myProcNo()].transfer(prociList);
// Flatten
for (labelList& list : shareList)
     procList.append(std::move(list)):
If you are dealing with a list of labels, the additional std::move() doesn't help much on the append (doesn't hurt either), but if your lists contain something "heavier" (like longer strings etc) this will recover their memory element-wise and reduce some allocations.
blue8803 likes this.
parallel
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
script for export particle information archetype CFX 2 August 8, 2017 10:57
Socket 2011-3 processors - an overwiew flotus1 Hardware 10 June 17, 2017 10:47
OpenFOAM 2D simulation - Freelancer Job- Information will be provided sanjar CFD Freelancers 0 March 7, 2017 10:45
information from saved data files:Unsteady flow Atul FLUENT 5 July 27, 2008 21:05
