Surface tension driven flows: interFoam vs. multiphaseInterFoam |
October 25, 2018, 09:46 |
Rep Power: 10 |
Greetings!
I wanted to discuss a topic that I have not seen talked about on these forums. The difference between interFoam and multiphaseInterFoam for surface tension driven flows. In my work I am simulating breaks up of a water jet. I have been using for a while multiphaseInterFoam solver but recently changed to interFoam solver. The main difference I noticed that the two solvers do not behave in the same way. The point of breakup differs for both solvers. Took me some time to figure it out and I just wanted to share if anyone else has the same issues or does not know which one to use. So the code implementation for surface tension force (STF)looks like this: INTER FOAM: MULTIPHASEINTERFOAM: The issues is the two implementations are identical theoretically but surely not the same numerically. Problem occurs with the calculation of gradient of discontinuous volumetric alpha fields (this is a known issue in OpenFoam, and the erroneous calculations lead to spurious currents development.) Looking only at gradient (STFif) and the brackets (STFmif) and using the previous three relations we get to the end result: It can be seen that there is an extra error term, which makes calculating with multiphaseInterFoam worse. In my case the reduction of stf in mif makes the jet longer. There is of course the same error coming out of curvature K, which has the same issue of calculating gradients, calculation of which was omitted from here for clarity. Hopefully the error calculation reduces with implementation of new numerical techniques like the one from Scheufler & Roenby (Accurate and efficient surface reconstruction from volume fraction data on general meshes) and the two solvers produce equal solutions. The question I have is does anybody know why surface tension is implemented in such way? Any literature on surface tension terms in momentum equation in mixture model would be much appreciated. Cheers |
October 30, 2018, 09:00 |
Michael Alletto
Rep Power: 16 |
There are two references in https://openfoamwiki.net/index.php/InterFoam which i found usefull.
October 31, 2018, 23:26 |
interFoam
Vivek
Rep Power: 8 |
Hi dzordz & Michael Alletto
I am also simulating liquid jet breakup using interFoam solver. In my case, the liquid jet is not even showing any sign of breakup, but small oscillation or perturbation are happening at the liquid jet surface. I don't know exactly what causes this problem. I tried with different mesh size. Could anyone help to find out this problem? Thank you, |
December 22, 2021, 03:57 |
Zhicheng YUAN
Rep Power: 5 |
Form my point of view, MFIF can be used for a system more than three fluids. If only two phases are present in a cell, then $\nabla \alpha_1 = - \nabla \alpha_2$. With \alpha_1=1-\alpha_2, we will get the equation used by interFOAM.
How to add Surface Tension in cavitatingFoam solver | jamestangx | OpenFOAM Programming & Development | 1 | April 6, 2016 17:39 |
Surface tension Interfoam | nb977 | OpenFOAM Running, Solving & CFD | 1 | March 9, 2016 04:02 |
Help!! customize surface tension term in interFoam | w051cxw | OpenFOAM Running, Solving & CFD | 0 | February 12, 2016 02:15 |
interface tension question with interFoam solver | openTom | OpenFOAM Running, Solving & CFD | 4 | May 29, 2009 14:18 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 22:03 |
