Wrong shear rate result with the existing code |
October 17, 2018, 22:31 |
Amir
Rep Power: 7 |
Hello all,
I'm working on problem in which knowing the magnitude of shear rate tensor is important to me. I added these lines to createFields.H file in solver's folder (buoyantBoussinesqPimpleFoam) and recompiled it in order to have the shear rate magnitude in each time step: Code:
volScalarField shearRate ( IOobject ( "shearRate", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), sqrt(2.0f)*mag(symm(fvc::grad(U))) ); is anything wrong with this expression: shearRate=sqrt(2.0f)*mag(symm(fvc::grad(U))) or it's a programming problem? Thank you is advance! Amir |
April 21, 2022, 07:45 |
Giancarlo Esposito
Rep Power: 4 |
I have the same problem, but so far I did not manage to solve it.
April 25, 2022, 14:22 |
Kellis
Rep Power: 9 |
Amir,
The createFields.H file is only called once, at the beginning of the simulation. Assuming you are starting with a zero or otherwise uniform velocity field, the shear rate will be zero. If you are not updating the shear rate somewhere else in the code, the shear rate will be initialized in createFields and then never updated as the simulation progresses. To fix this, simply add another line of code (perhaps at the end of pEqn.H, once the velocity field for the timestep is finalized) to recalculate the shear rate with the updated velocity field. Then you should be seeing non-zero values as your case progresses. Hope this helps. Kellis |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
Blood and shear strain rate | Dave442 | CFX | 2 | July 27, 2012 06:10 |
Shear rate and Shear stress | kakarot9999 | FLUENT | 0 | September 8, 2011 08:28 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
Total shear rate in a 3 dimensional flow | Bo Busk Jensen | Main CFD Forum | 3 | May 23, 2003 15:26 |
