Numerical problem in species Transport in InterFoam at the interface
Like Tree1Likes
  • 1 Post By Cyp
Old   October 11, 2018, 06:15
Default Numerical problem in species Transport in InterFoam at the interface
Mehdi Aminyavari
Mehdi3031 is on a distinguished road
Hello Forum;
I am trying to introduce a species transport equation in interfoam for the liquid phase (Alpha1 = 1) as bellow:
Info << "solve ylEqn.H"<<endl;
    surfaceScalarField rho1Phialpha1 = rho1*phi*fvc::interpolate(alpha1);
    fvScalarMatrix ylEqn
        fvm::ddt(alpha1*rho1, yl)
      + fvm::div(rho1Phialpha1, yl, "div(rhoPhiAlpha,yl)")
      - fvm::laplacian(alpha1*rho1*Dl, yl)
This equation has been cited 100s of times and thats how people cancell out the gas domain(Alpha1=0) when solving the species balanse for the liquid phase and just solves it where ever Alpha1 is 1 or between 0 and 1.
But the problem is that I get crazy yl values at the interface where 0<Alpha1<1 as you can see in the attached photo! and if I don't bound the yl between 0 and 1 by force, it will go to infinity.
any Idea how to solve this numerical problem? did anybody have done it before?
Thanks a lot in advance
Mehdi3031 is offline   Reply With Quote
Old   October 11, 2018, 10:20
Mehdi Aminyavari
why my posts have always minimum views among the list??????!!!!
is there a trick or something to increase the view and reply??
Old   October 12, 2018, 03:45
Cyp
Cyprien
Cyp is on a distinguished road
Please, have a look at this paper :
https://www.sciencedirect.com/science/article/pii/S0009250918303944
Cheers,
Cyprien
Cyp is offline   Reply With Quote
Old   October 12, 2018, 08:01
Mehdi Aminyavari
Dear Cyprien,
Thank you so much for your response, I have seen the article, but the point is that you could use the Henry coefficient in this work and make a CST equation because you had a dilute solution which in my case I don't and cant do that. I have to solve the species equation separately for both phases like for phase 1:
and the same for Phase 2; and then couple them with a source term. What I can't solve is that as soon as Alpha comes around in the species transfer equations, All goes wrong due to numerical problems introduced at the interface:
Any suggestion on that?
Old   October 12, 2018, 08:03
Cyp
Cyprien
You can if you put H=0.
Mehdi3031 likes this.
Old   October 12, 2018, 08:28
Mehdi Aminyavari
I may explained bad,
(Using the notion in your paper): Cj,2 = Hj*Cj,1
so if Hj=0, means Cj,2 = 0 which means in phase two I have no Cj!!
In another word phase 2 (gas phase) is pure species i and liquid phase is binary mixture of Species j and i with Cj,1!
My problem is Ammonia-water mixture which means in both phases I have both species and it is non-diluted (Cj,2 = 0.95-0.995) and (Cj,1=0.1-0.6) which is as far as I know, not the case to use Henry coefficient.
Isn't that right?
UDF for Sorption in Species Transport through Porous Medium Kosch Fluent UDF and Scheme Programming 6 October 21, 2020 18:46
Species transport model problem argeus FLUENT 8 September 20, 2019 08:23
InterFoam and species transport PKeller OpenFOAM Running, Solving & CFD 7 October 7, 2014 03:40
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
