reasons for floating point error
Like Tree1Likes
  • 1 Post By cyss38
Old   October 4, 2018, 08:03
Default reasons for floating point error
krishna kant
kk415 is on a distinguished road
I am getting problem in a very simple line in OF4.1
i.e. psifine += mag(psi0fine)/psi0fine;
where psi0fine and psifine are volScalarField
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? at sigaction.c:?
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#6 ? at ??:?
#7 __libc_start_main at ??:?
#8 ? at ??:?
Floating point exception (core dumped)
Can anyone suggest what could be the possible cause for the error?
kk415 is offline   Reply With Quote
Old   October 4, 2018, 10:11
Default divide by zero
Eric Bringley
ebringley is on a distinguished road
is your psi0fine zero anywhere?
ebringley is offline   Reply With Quote
Old   October 4, 2018, 11:50
krishna kant
NOPE... I tried to print the values of psi0fine over the entire field. It is never zero. And the boundary condition is cyclic.
Old   October 4, 2018, 17:14
cyss38's Avatar
Cyrille Bonamy
cyss38 is on a distinguished road
if i understand correctly, you want the sign of volScalarField.
So try this codeline :
psifine += sign(psi0fine);
kk415 likes this.
cyss38 is offline   Reply With Quote
Old   October 5, 2018, 08:12
krishna kant
Thanks that way is working
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 01:37
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
