Unknown viscosityModel type temppowerLaw
Like Tree1Likes
  • 1 Post By mAlletto
Old   September 25, 2018, 06:14
Default Unknown viscosityModel type temppowerLaw
shivani gupta
shivani17 is on a distinguished road
I have modified the viscosity model giving viscosity variation with temperature. It has been compiled successfully but while running a case with transportModel mentioned as temppowerLaw, it is unable to identify it.The error is
--> FOAM FATAL ERROR:
Valid viscosityModels are :
7
BirdCarreau
Casson
CrossPowerLaw
HerschelBulkley
Newtonian
powerLaw
strainRateFunction
From function static Foam::autoPtr<Foam::viscosityModel> Foam::viscosityModel::New(const Foam::word&, const Foam::dictionary&, const volVectorField&, const surfaceScalarField&)
in file viscosityModels/viscosityModel/viscosityModelNew.C at line 49.
FOAM exiting
The code is:
#include "temppowerLaw.H"
#include "addToRunTimeSelectionTable.H"
#include "surfaceFields.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
namespace viscosityModels
defineTypeNameAndDebug(temppowerLaw, 0);
viscosityModel,
temppowerLaw,
dictionary
// * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * * //
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::temppowerLaw::calcNu() const
const volScalarField& T=U_.mesh().lookupObject<volScalarField>("T"); // added
return max
nuMin_,
min
nuMax_,
//k_*pow
(k_-kslope_*(T-Tbase_))*pow //added
max
dimensionedScalar("one", dimTime, 1.0)*strainRate(),
dimensionedScalar("small", dimless, small)
n_.value() - scalar(1)
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
Foam::viscosityModels::temppowerLaw::temppowerLaw
const word& name,
const dictionary& viscosityProperties,
const volVectorField& U,
const surfaceScalarField& phi
viscosityModel(name, viscosityProperties, U, phi),
temppowerLawCoeffs_(viscosityProperties.optionalSu bDict(typeName + "Coeffs")),
k_("k", dimViscosity, temppowerLawCoeffs_),
n_("n", dimless, temppowerLawCoeffs_),
kslope_(temppowerLawCoeffs_.lookup("kslope")), //added
Tbase_(temppowerLawCoeffs_.lookup("Tbase")),
nuMin_("nuMin", dimViscosity, temppowerLawCoeffs_),
nuMax_("nuMax", dimViscosity, temppowerLawCoeffs_),
nu_
IOobject
name,
U_.time().timeName(),
U_.db(),
IOobject::NO_READ,
IOobject::AUTO_WRITE
calcNu()
// * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * //
bool Foam::viscosityModels::temppowerLaw::read
viscosityModel::read(viscosityProperties);
temppowerLawCoeffs_ = viscosityProperties.optionalSubDict(typeName + "Coeffs");
temppowerLawCoeffs_.lookup("k") >> k_;
temppowerLawCoeffs_.lookup("n") >> n_;
temppowerLawCoeffs_.lookup("kslope") >> kslope_; //added
temppowerLawCoeffs_.lookup("Tbase") >> Tbase_;
temppowerLawCoeffs_.lookup("nuMin") >> nuMin_;
temppowerLawCoeffs_.lookup("nuMax") >> nuMax_;
return true;
Please help!
shivani17 is offline   Reply With Quote
Old   September 25, 2018, 06:57
Michael Alletto
mAlletto will become famous soon enough
Did you include the path of the library you compiled in the controlDict like:
libs("path/yourlib.so")
mAlletto is offline   Reply With Quote
Old   September 25, 2018, 07:21
shivani gupta
In controlDict it is required to write solver name right?, in transportproperties of constant folder the transportModel is mentioned
controlDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application temperaturesimpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 2000;
deltaT 1;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
#includeFunc streamlines
transportProperties:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object transportProperties;
transportModel temppowerLaw;
nu [0 2 -1 0 0 0 0] 1e-05;
temppowerLawCoeffs
k [0 2 -1 0 0 0 0] 2800;
n [0 0 0 0 0 0 0] 0.64;
kslope [0 2 -1 -1 0 0 0] 0.5;
Tbase [0 0 0 1 0 0 0] 300;
nuMin [0 2 -1 0 0 0 0] 0.1;
nuMax [0 2 -1 0 0 0 0] 10000000;
TempD [ 0 2 -1 0 0 0 0] 1e-8;
Old   September 25, 2018, 08:06
shivani gupta
I changed in controlDict file as:My library is in /src/transportModels/incompressible/viscosityModels/temppowerLaw
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
libs ("src/transportModels/incompressible/viscosityModels/temppowerLaw.so");
startTime 0;
stopAt endTime;
endTime 2000;
deltaT 1;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
functions
Tried with 1.libs ("src/transportModels/incompressible/viscosityModels/temppowerLaw/temppowerLaw.so");
2. libs ("libtemppowerLaw.so");
Old   September 25, 2018, 08:22
shivani gupta
While compiling .so file is not created in linux64GccDPInt32Opt
msg displayed after compiling
wmake libso .
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file temppowerLaw.C
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam6/src/transportModels/incompressible/lnInclude -I/opt/openfoam6/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude -fPIC -c temppowerLaw.C -o Make/linux64GccDPInt32Opt/temppowerLaw.o
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam6/src/transportModels/incompressible/lnInclude -I/opt/openfoam6/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/temppowerLaw.o -L/opt/openfoam6/platforms/linux64GccDPInt32Opt/lib \
-lfiniteVolume -o /home/shivani/OpenFOAM/root-6/platforms/linux64GccDPInt32Opt/lib/temppowerLaw.so
Old   September 25, 2018, 08:56
Michael Alletto
It is probably created in /home/shivani/OpenFOAM/root-6/platforms/linux64GccDPInt32Opt/lib/temppowerLaw.so
shivani17 likes this.
Old   September 28, 2018, 09:01
shivani gupta
Thank You !! So much. I wrote the path in controlDict file and it has identified the new library
Old   October 31, 2021, 15:18
Abbas
aa399@aub.edu.lb is on a distinguished road
Hello.
I have the same problem, and I wrote in the controlDict the libs with the correct path to it, but unfortunately the problem was not solved, and I am getting the following message again:
Unknown viscosityModel type tempdeppowerLaw
7
BirdCarreau
Casson
CrossPowerLaw
HerschelBulkley
Newtonian
powerLaw
strainRateFunction
FOAM exiting
can you please help me discover the problem?
Thank you in advance
aa399@aub.edu.lb is offline   Reply With Quote
Old   November 4, 2024, 23:00
Huy_Nguyen is on a distinguished road
Could you please tell me how did you write the path correctly? thank you
Huy_Nguyen is offline   Reply With Quote
Old   November 5, 2024, 03:43
Originally Posted by aa399@aub.edu.lb View Post
Hello.
7
BirdCarreau
Casson
CrossPowerLaw
HerschelBulkley
Newtonian
powerLaw
strainRateFunction
FOAM exiting
hi, did you solve the problem? if yes, could you please tell me how? Thank you and all the best.
modifying model
Problem with continuity simpleFoam kkl omega airfoils ibelunatic OpenFOAM Running, Solving & CFD 0 March 20, 2018 12:48
Time step continuity error lpz_michele OpenFOAM Running, Solving & CFD 0 October 12, 2015 07:05
Strange high velocity in centrifugal pump simulation huangxianbei OpenFOAM Running, Solving & CFD 26 August 15, 2014 03:27
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
