wmake error: source files could not be created
Like Tree1Likes
  • 1 Post By dleduc
Old   September 19, 2018, 07:47
Default wmake error: source files could not be created
shivani gupta
shivani17 is on a distinguished road
I am trying to reproduce the viscosity model given in this file.
http://www.tfd.chalmers.se/~hani/kur...nFoam%20v2.pdf
The error I am getting while compiling the viscosity model is
Make/linux64GccDpInt320pt/option:56:*** missing separator. Stop
wmake error: file 'Make//linux64GccDpInt320pt/sourceFiles' could not be created in /home/admin1/openfoam6/src/transportModels/temppowerLaw.
I used wclean before wmake, written \ at right places(not in last line), used -P in wmake/rules/linuxGcc as mentioned in one of the answers, nothing could work.
checked installation of wmake also.
Please help!
shivani17 is offline   Reply With Quote
Old   September 19, 2018, 11:06
Damien Leduc
dleduc is on a distinguished road
"Make/linux64GccDpInt320pt/option:56:*** missing separator. Stop
written \ at right places"
Are you perfectly sure you didn't forget one ?
Also, your message tells : "could not be created in /home/admin1/openfoam6/src/transportModels/temppowerLaw"
I'm no specialist, but I think you should try to make your new solver elsewhere...
For example /home/admin1/myapplications/temppowerLaw
shivani17 likes this.
dleduc is offline   Reply With Quote
Old   September 20, 2018, 02:53
shivani gupta
Thank you for your reply. My Options file
EXE_INC = \
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = \
-lfiniteVolume
Tried changing the location of the folder also. the same error I am getting.
missing separator, source files, wmake error
[OpenFOAM.org] Error running #codeStream/functions wmake lnInclude fails to open *.H Files tarik OpenFOAM Installation 8 June 14, 2020 04:12
Error code 2 memory exceed no *. res files created Alejandro Garcia CFX 2 February 3, 2016 03:11
Problems about compiling OF1.5.x on Bluegene/P ywang OpenFOAM 1 August 25, 2011 06:22
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
