Modifying the energy equation to remove mass without changing temperature
Like Tree2Likes
  • 1 Post By Benben
  • 1 Post By Benben
Old   August 14, 2018, 12:58
Smile Modifying the energy equation to remove mass without changing temperature
benoit favier
Benben is on a distinguished road
I am currently modifying reactingFoam, on version 6.0 of OpenFoam.
I am trying to implement an oxydation reaction :
H2O(g) + Metal(s) -----> H2(g) + MetalOxyde(s)
which for the gas phase is simply :
H2O(g) -----> H2(g)
To do so, i declared a "volScalarField" reaction rate R, which is my reaction rate in the volume in mol/m^3/s.
volScalarField R
    IOobject
        "R",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,//Dont read at the begining
        IOobject::AUTO_WRITE//Save every time step
    mesh,
    dimensionedScalar("R", dimensionSet(0,-3,-1,0,1,0,0), scalar(0.0))
I initialized it to positive values before the main loop of reactingFoam.
I also defined the molar masses of H2O and H2 as "dimensionedScalar" variables, in kg/mol :
dimensionedScalar M_H2("M_H2", dimensionSet(1,0,0,0,-1,0,0), composition.W(i_H2) * 1.E-3);
dimensionedScalar M_H2O("M_H2O", dimensionSet(1,0,0,0,-1,0,0), composition.W(i_H2O) * 1.E-3);
I modified my equation in "YEqn.H" to have formation of H2 and destruction of H2O :
//Defining the source term of mass of specie i, in kg/mol/s.
volScalarField SourceTerm = R * dimensionedScalar("Molar_mass",dimensionSet(1,0,0,0,-1,0,0),0.);//Copy the volScalarField "R", change its unit to kg/m^3/s, and set it to 0.
if (Yi.name()=="H2")
    SourceTerm = R * M_H2;
else if (Yi.name()=="H2O")
    SourceTerm = R * -M_H2O;
fvScalarMatrix YiEqn
    fvm::ddt(rho, Yi)
  + mvConvection->fvmDiv(phi, Yi)
  - fvm::laplacian(turbulence->muEff(), Yi)
    fvOptions(rho, Yi)
  + SourceTerm
And then modified my "RhoEqn.H" to remove the mass of oxygen atoms that go to solid phase (as H2O is heavier than H2):
//Defining the sink term of mass due to the chemical reaction. (H2O(g) + Zn(s) ---> H2(g) + ZnO(s) => mass of gas is reduced)
volScalarField SinkTerm_reaction = R * (M_H2 - M_H2O);
fvScalarMatrix rhoEqn
    fvm::ddt(rho)
  + fvc::div(phi)
    fvOptions(rho)
  + SinkTerm_reaction
But then when I tested it, there was an unwanted modification of the temperature inside of my test case. (I set up a test case between 6 walls, with no velocity at all).
I realized that it was because i didn't remove the enthalpy of the oxygen atoms from my system, in the energy equation.
I dont really know how i should proceed.
Anyone has any clue of how i should do this ?
atulkjoy likes this.
Benben is offline   Reply With Quote
Old   August 14, 2018, 13:09
benoit favier
I tried to do this :
created a new "volScalarField" variable he_R which is a energy source due to the oxydation reaction in J/m^3/s :
//Enthalpie variation due to the reaction (in J/m^3/s) [J = kg.m^2/s^2 => J/m^3/s = kg.m^-1.s^-3]
volScalarField he_R
    IOobject
        "he_R",
        runTime.timeName(),
        mesh,
        IOobject::NO_WRITE//Dont save
    mesh,
    dimensionedScalar("he_R", dimensionSet(1,-1,-3,0,0,0,0), scalar(0.0))
I calculated it using the total enthalpy of specie H2 and H2O :
he_R[Cell_ID] = R[Cell_ID] * (
                              composition.Ha(i_H2,p[Cell_ID],Temp)*M_H2
                              - composition.Ha(i_H2O,p[Cell_ID],T [Cell_ID])*M_H2O
And added this source term in my energy equation "EEqn.H" :
fvScalarMatrix EEqn
    fvm::ddt(rho, he) + mvConvection->fvmDiv(phi, he)
  + fvc::ddt(rho, K) + fvc::div(phi, K)
        he.name() == "e"
      ? fvc::div
            fvc::absolute(phi/fvc::interpolate(rho), U),
            p,
            "div(phiv,p)"
      : -dpdt
  - fvm::laplacian(turbulence->alphaEff(), he)
    Qdot
  + fvOptions(rho, he)
  + he_R
But the temperature is still changing during the simulation
What am i doing wrong ?
Is it really the total enthalpy "composition.Ha(...)" that i have to considerate ? (there is also Hs the sensible enthalpy, and Hc the chemical enthalpy, which i dont realy know what they are)
Should i use the partial pressure of species to calculate the enthalpy instead of total pressure of the gas ?
Old   August 16, 2018, 03:18
Atul Kumar
Location: National Centre for Combustion Research and Development
atulkjoy is on a distinguished road
volScalarField he_R
    IOobject
        "he_R",
        runTime.timeName(),
        mesh,
    mesh,
fvScalarMatrix EEqn
        he.name() == "e"
      ? fvc::div
            p,
            "div(phiv,p)"
      : -dpdt
    Qdot
  + he_R
Are you updating fields like
forAll(T.ref(),cellID)
before ?? or after ??? you van use mole/mass fraction of species to check that
atulkjoy is offline   Reply With Quote
Old   August 16, 2018, 03:19
benoit favier
I do this at the begining of the pimple loop, before "UEqn.H".
Edit : my bad, temperature is still changing
Old   August 16, 2018, 09:03
benoit favier
I changed the total enthalpy for the sensible enthalpy, as that is what i selected in my case setting (constant/thermophysicalProperties.energy = sensibleEnthalpy).
I also added the kinetic energy that is removed by the reaction, even if there is no velocity.
    composition.Hs(i_H2,p[Cell_ID],Temp)*M_H2
    - composition.Hs(i_H2O,p[Cell_ID],T [Cell_ID])*M_H2O
    + K[Cell_ID]*(M_H2 - M_H2O)
My temperature is still decreasing.
An interesting fact is that even thought my mass is supposed to decrease, and my temperature decrease, the pressure increase.
Old   August 17, 2018, 05:43
benoit favier
So, actually, the reason why the pressure increase is probably due to the fact that reactingFoam uses a pressure equation at the end of the loop to correct the pressure (poisson pressure equation). I didnt modify this equation to take into account the mass variation of the systeme. I will look into it once i managed to have my temperature variation fixed.
I am a bit stuck here, as according to this :
How exactlly is enthalpy calculated
The hentalpy variation to take into account is indeed the sensible enthalpy, but my code still doesnt work.
I checked that the mass is indeed removedof the system, and it is (rho goes from 0.393963 Initially to 0.394123 in my volume).
I instrumented the code to display internal enthalpy in a cell, before and fater the first time step, as well as the theoretical enthalpy variation as i calculate it, and it clearly isnt the same thing :
debug (YEqn_RDMP.H) : Hs before = 529701
debug (YEqn_RDMP.H) : T before = 600
debug (EEqn_RDMP.H) : Delta Hs theoretical = 16.7804
debug (EEqn_RDMP.H) : Hs after = 529812
debug (EEqn_RDMP.H) : T after = 599.991
I even displayed every calculated term of the energy equation, and everything is of the order of 10^(-20) or less, except for my energy source term.
debug (EEqn_RDMP.H) : fvc::ddt(rho, K) = -1.34174e-24
debug (EEqn_RDMP.H) : fvc::div(phi, K) = 0
debug (EEqn_RDMP.H) : -dpdt = -0
debug (EEqn_RDMP.H) : Qdot = 0
debug (EEqn_RDMP.H) : he_R = 16.7804
So how the hell does my Hs change so much ??
Old   August 17, 2018, 07:01
benoit favier
According to this :
https://cfd.direct/openfoam/energy-equation/#x1-60003
The energy equation in term of enthalpy that is derived for openfoam injects the mass conservation at some points in it.
So, as my mass conservation equation is different, this equation is wrong.
I will try to obtain the equivalent equation with a mass sink.
Old   July 27, 2019, 02:10
Niu
Z.Q. Niu is on a distinguished road
Hi benoit,
Have you find the correct way to code right energy source? Thanks!
Best Regards!
Z.Q. Niu is offline   Reply With Quote
energy equation, reactingfoam
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
