share something about dev of openfoam using cmake rather than wmake
Like Tree6Likes
  • 6 Post By chengdi
Old   August 13, 2018, 03:40
Default share something about dev of openfoam using cmake rather than wmake
Di Cheng
chengdi is on a distinguished road
The purpose is take advantage of modern IDEs (VSC, CLion, QT Creator, even Visual Studio with Linux Development Workload) which integrate with cmake better.
wmake is used to do two things:
1. compile OpenFOAM libs: from `src` to `lib*.so`
2. compile applications using OpenFOAM libs: from `xxFoam.C` to `xxFoam`
I only intended to do the second task.
for example: basic/laplacianFoam
add CMakeLists.txt
cmake_minimum_required (VERSION 3.8)
# cxx11
set( CMAKE_CXX_STANDARD 11 )
set(CMAKE_EXE_LINKER_FLAGS "${CMAKE_EXE_LINKER_FLAGS} -Xlinker --no-as-needed -Xlinker --add-needed")
link_directories($ENV{FOAM_LIBBIN})
add_definitions(-Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DNoRepository -m64 -fPIC )
# Make/files
# Add source to this project's executable.
add_executable (laplacianFoam "laplacianFoam.C")
# Make/options
include_directories( $ENV{FOAM_SRC}/finiteVolume/lnInclude )
include_directories( $ENV{FOAM_SRC}/meshTools/lnInclude )
include_directories( $ENV{FOAM_SRC}/OpenFOAM/lnInclude )
include_directories( $ENV{FOAM_SRC}/OSspecific/POSIX/lnInclude )
set(EXTRA_LIBS dl m)
set(LIBS finiteVolume fvOptions meshTools OpenFOAM ${EXTRA_LIBS})
target_link_libraries(laplacianFoam ${LIBS})
I am using vs 2017 to do debug remotely, and intellisense works under proper header sharing settings.
nsf, msaravia, ajitkumar22 and 3 others like this.
chengdi is offline   Reply With Quote
Old   February 8, 2021, 10:53
LeeRuns is on a distinguished road
any chance you would share the cmake files?
LeeRuns is offline   Reply With Quote
Old   February 9, 2021, 09:46
Now I see your cmake files. Nm.
cmake, openfoam
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 20:53
