July 9, 2018, 09:43 |
nonUniform internalField using codeStream
Saleh Abuhanieh
Rep Power: 8 |
Hi Foamers,
I am trying to set the internalField for a scalar field phi according to a simple formula using sodeStream. The task shall be easy, I used for boundaryField successfully, however I am receiving error during running the case. - in 0/rho file internalField #codeStream { codeInclude #{ #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ const IOdictionary& d = static_cast<const IOdictionary&> ( dict.parent().parent() ); const fvMesh& mesh = refCast<const fvMesh>(d.db()); scalarField rho(mesh.nCells(), 0); forAll(rho, i) { const scalar x = mesh.C()[i][0]; const scalar y = mesh.C()[i][1]; rho[i] = x*(y-1.0); } rho.writeEntry("", os); #}; }; - the error // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading physicalProperties Reading field phi Reading field rho Using #codeStream at line 19 in file "//Example_3_4/0/rho" Using #codeStream with "//Example_3_4/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_fb6fa2a2647a8c56be151bdd6cfc899b6f3a 075e.so" Creating new library in "dynamicCode/_fb6fa2a2647a8c56be151bdd6cfc899b6f3a075e/platforms/linux64GccDPInt32Opt/lib/libcodeStream_fb6fa2a2647a8c56be151bdd6cfc899b6f3a 075e.so" Invoking "wmake -s libso ///Example_3_4/dynamicCode/_fb6fa2a2647a8c56be151bdd6cfc899b6f3a075e" wmake libso ///Example_3_4/dynamicCode/_fb6fa2a2647a8c56be151bdd6cfc899b6f3a075e ln: ./lnInclude wmkdep: codeStreamTemplate.C Ctoo: codeStreamTemplate.C ld: ///Example_3_4/dynamicCode/_fb6fa2a2647a8c56be151bdd6cfc899b6f3a075e/../platforms/linux64GccDPInt32Opt/lib/libcodeStream_fb6fa2a2647a8c56be151bdd6cfc899b6f3a 075e.so #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 __dynamic_cast in "/usr/lib/x86_64-linux-gnu/libstdc++.so.6" #4 codeStream_fb6fa2a2647a8c56be151bdd6cfc899b6f3a075 e at /opt/openfoam5/src/OpenFOAM/lnInclude/typeInfo.H:110 #5 Foam::functionEntries::codeStream::execute(Foam::d ictionary const&, Foam:rimitiveEntry&, Foam::Istream&) at ??:? #6 Foam::functionEntry::execute(Foam::word const&, Foam::dictionary const&, Foam:rimitiveEntry&, Foam::Istream&) at ??:? #7 Foam:rimitiveEntry::expandFunction(Foam::word const&, Foam::dictionary const&, Foam::Istream&) at ??:? #8 Foam:rimitiveEntry::append(Foam::token const&, Foam::dictionary const&, Foam::Istream&) at ??:? #9 Foam:rimitiveEntry::read(Foam::dictionary const&, Foam::Istream&) at ??:? #10 Foam:rimitiveEntry::readEntry(Foam::dictionary const&, Foam::Istream&) at ??:? #11 Foam:rimitiveEntry:rimitiveEntry(Foam::keyType const&, Foam::dictionary const&, Foam::Istream&) at ??:? #12 Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:? #13 Foam::dictionary::read(Foam::Istream&, bool) at ??:? #14 Foam:perator>>(Foam::Istream&, Foam::dictionary&) at ??:? #15 Foam::baseIOdictionary::readData(Foam::Istream&) at ??:? #16 Foam::fileOperations::uncollatedFileOperation::rea d(Foam::regIOobject&, bool, Foam::IOstream::streamFormat, Foam::word const&) const at ??:? #17 Foam::regIOobject::readHeaderOk(Foam::IOstream::st reamFormat, Foam::word const&) at ??:? #18 Foam::localIOdictionary::localIOdictionary(Foam::I Oobject const&, Foam::word const&) at ??:? #19 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "//Example_3_4" #20 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "///Example_3_4" #21 ? in "/OpenFOAM/-5.0/platforms/linux64GccDPInt32Opt/bin/Example_3_4" #22 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #23 ? in "/OpenFOAM/-5.0/platforms/linux64GccDPInt32Opt/bin/Example_3_4" Segmentation fault (core dumped) when I set any uniform value .. the solver works I hope the case is clear Any help will be appreciated |
July 12, 2018, 03:14 |
Saleh Abuhanieh
Rep Power: 8 |
any support pls?
July 16, 2018, 15:04 |
Rep Power: 15 |
July 17, 2018, 09:15 |
Saleh Abuhanieh
Rep Power: 8 |
Thank you ..
it is ok now |
July 25, 2018, 11:43 |
chen qi
Hi, I have the same error, Can you tell me how to solve the problem. Thank you in advance.
July 25, 2018, 15:09 |
Saleh Abuhanieh
Rep Power: 8 |
Check the first two lines in the code part (which gives the access for internal mesh information). this part is different in case of BC |
March 4, 2020, 10:19 |
#7 | |
Guangyu
Rep Power: 6 |
Many thanks for your post. I've checked out the tutorial and met similar problems with Saleh. The 0/U file and the error message are as follows: ********************************************* velocity-inlet-5 { type fixedValue; value #codeStream { codeInclude #{ #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; //libs needed to visualize BC in paraview codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ const IOdictionary& d = static_cast<const IOdictionary&> ( dict.parent().parent() ); const fvMesh& mesh = refCast<const fvMesh>(d.db()); const label id = mesh.boundary().findPatchID("velocity-inlet-5"); const fvPatch& patch = mesh.boundary()[id]; //vectorField U(mesh.boundary()[id].size(), vector(0, 0, 0)); vectorField U(patch.size(), vector(0, 0, 0)); const scalar pi = constant::mathematical::pi; const scalar U_0 = 2.; //max vel const scalar p_ctr = 8.; //patch center const scalar p_r = 8.; //patch radius forAll(U, i) { const scalar y = patch.Cf()[i][1]; U[i] = vector(U_0*(1-(pow(y - p_ctr,2))/(p_r*p_r)), 0., 0.); } //for (int i; i<patch.size() ; i++) //{ // const scalar y = patch.Cf()[i][1]; // U[i] = vector(U_0*(1-(pow(y - p_ctr,2))/(p_r*p_r)), 0., 0.); //} writeEntry(os, "", U); #}; }; } ************************************************** * The error message: Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Using #codeStream at line 32 in file "/users/szb15180/lustre/OpenFOAM/Day11_programming_1/Implementing_BC_using_codeStream/2Delbow_UparabolicInlet/0/U.boundaryField.velocity-inlet-5" Using #codeStream with "/users/szb15180/lustre/OpenFOAM/Day11_programming_1/Implementing_BC_using_codeStream/2Delbow_UparabolicInlet/dynamicCode/platforms/linux64IccDPInt32Opt/lib/libcodeStream_6f24639605d8ca85b20529455e75474847b7 09e7.so" Creating new library in "dynamicCode/_6f24639605d8ca85b20529455e75474847b709e7/platforms/linux64IccDPInt32Opt/lib/libcodeStream_6f24639605d8ca85b20529455e75474847b7 09e7.so" Invoking "wmake -s libso /users/szb15180/lustre/OpenFOAM/Day11_programming_1/Implementing_BC_using_codeStream/2Delbow_UparabolicInlet/dynamicCode/_6f24639605d8ca85b20529455e75474847b709e7" wmake libso /users/szb15180/lustre/OpenFOAM/Day11_programming_1/Implementing_BC_using_codeStream/2Delbow_UparabolicInlet/dynamicCode/_6f24639605d8ca85b20529455e75474847b709e7 ln: ./lnInclude wmkdep: codeStreamTemplate.C Ctoo: codeStreamTemplate.C ld: /users/szb15180/lustre/OpenFOAM/Day11_programming_1/Implementing_BC_using_codeStream/2Delbow_UparabolicInlet/dynamicCode/_6f24639605d8ca85b20529455e75474847b709e7/../platforms/linux64IccDPInt32Opt/lib/libcodeStream_6f24639605d8ca85b20529455e75474847b7 09e7.so #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/usr/lib64/libc.so.6" #3 codeStream_6f24639605d8ca85b20529455e75474847b709e 7 at /opt/software/openfoam/intel-2018.2/v7/src/OpenFOAM/lnInclude/dictionary.H:285 #4 Foam::functionEntries::codeStream::execute(Foam::d ictionary const&, Foam::primitiveEntry&, Foam::Istream&) at ??:? #5 Foam::functionEntry::execute(Foam::word const&, Foam::dictionary const&, Foam::primitiveEntry&, Foam::Istream&) at ??:? #6 Foam::primitiveEntry::expandFunction(Foam::word const&, Foam::dictionary const&, Foam::Istream&) at ??:? #7 Foam::primitiveEntry::append(Foam::token const&, Foam::dictionary const&, Foam::Istream&) at ??:? #8 Foam::primitiveEntry::read(Foam::dictionary const&, Foam::Istream&) at ??:? #9 Foam::primitiveEntry::readEntry(Foam::dictionary const&, Foam::Istream&) at ??:? #10 Foam::primitiveEntry::primitiveEntry(Foam::keyType const&, Foam::dictionary const&, Foam::Istream&) at ??:? #11 Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:? #12 Foam::dictionary::read(Foam::Istream&, bool) at ??:? #13 Foam::dictionary::dictionary(Foam::fileName const&, Foam::dictionary const&, Foam::Istream&) at ??:? #14 Foam::dictionaryEntry::dictionaryEntry(Foam::keyTy pe const&, Foam::dictionary const&, Foam::Istream&) at ??:? #15 Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:? #16 Foam::dictionary::read(Foam::Istream&, bool) at ??:? #17 Foam::dictionary::dictionary(Foam::fileName const&, Foam::dictionary const&, Foam::Istream&) at ??:? #18 Foam::dictionaryEntry::dictionaryEntry(Foam::keyTy pe const&, Foam::dictionary const&, Foam::Istream&) at ??:? #19 Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:? #20 Foam::dictionary::read(Foam::Istream&, bool) at ??:? #21 Foam::operator>>(Foam::Istream&, Foam::dictionary&) at ??:? #22 Foam::baseIOdictionary::readData(Foam::Istream&) at ??:? #23 Foam::fileOperations::uncollatedFileOperation::rea d(Foam::regIOobject&, bool, Foam::IOstream::streamFormat, Foam::word const&) const at ??:? #24 Foam::regIOobject::readHeaderOk(Foam::IOstream::st reamFormat, Foam::word const&) at ??:? #25 Foam::localIOdictionary::localIOdictionary(Foam::I Oobject const&, Foam::word const&) at ??:? #26 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:? #27 ? at ??:? #28 __libc_start_main in "/usr/lib64/libc.so.6" #29 ? at ??:? Segmentation fault ************************************ Do you have any idea what went wrong? Your kind help is very much appreciated. Best wishes; Guangyu |
March 4, 2020, 11:21 |
Rep Power: 15 |
I am not sure how you came about this code, but the initialization does not match that from the tutorial (or any of the others that I've seen via a quick google). A quick look at your error makes me suspect the creation of the dict as at least one problem.
Caelan |
March 4, 2020, 11:31 |
#9 | |
Guangyu
Rep Power: 6 |
Thank you so much for relying. The tutorial from your link is Programming2. The case I'm work with is Programming1, from the same place, three-week tutorial series, day 11, "Programming - Implementing boundary condtions using codeStream". I'll trying your case (Programming2, initialization case) to see what happens. Thanks again. |
September 17, 2021, 07:48 |
#10 |
Rep Power: 10 |
Hi Guangy,
try to replace : const IOdictionary& d = static_cast<const IOdictionary&> ( dict.parent().parent() ); with const IOdictionary& d = static_cast<const IOdictionary&>(dict); Best wishes Fanny |
internalField condition | mchehab2 | OpenFOAM Running, Solving & CFD | 14 | November 10, 2022 13:28 |
[OpenFOAM] How to correctly show the result of #codeStream# internalField? | chengdi | ParaView | 24 | July 14, 2022 04:26 |
internalField nonuniform List<vector> and internalField nonuniform List <scalar> | Ferdinand | OpenFOAM Pre-Processing | 1 | January 3, 2020 12:20 |
internalField nonuniform <List>; | Panagioto | OpenFOAM Pre-Processing | 14 | September 2, 2019 11:51 |
How to create the internalField with #codeStream | chun | OpenFOAM Running, Solving & CFD | 3 | May 6, 2017 10:35 |
