Collated File Format (in Foam-Extend) Question |
May 29, 2018, 03:33 |
Andreas P.
Rep Power: 9 |
i am curious if somebody knows if the collated file format which was introduced in OpenFOAM v1712 and OpenFOAM 5.0 will also be integrated into the Foam-Extend project? I also have a question regarding the file handler itself: Why doesn't the collated file format directly write the data in the "reconstructed" way instead of having each processor field in a seperate region of the collated files? Is it because of the way how the mesh is handled with parallel processing? I will have a look into the commit (e.g. https://github.com/OpenFOAM/OpenFOAM...ae435d4ab42e6f ) but any help would be greatly appreciated. Thank you for your help! Andreas |
May 30, 2018, 08:20 |
Hrvoje Jasak
Rep Power: 33 |
Hi Andreas,
I have no problem including the collated file format in foam-extend. This seems to belong into a bigger project we are working on which includes low-level support for load balancing and alternative ways of dealing with the parallel decomposition mesh numbering. Would you be interested in preparing a git commit for the merge? Hrvoje
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 8, 2018, 10:11 |
Lee Yachao
Rep Power: 11 |
Hi Hrvoje, the current dynamic load balancing tools aren't easy to use in our calculations when it is combined with adaptive mesh refinement. How is the work you mentioned going?
July 20, 2021, 00:04 |
Collated file format in foam-extend-3.2
#4 | |
Hi Prof. Jasak, I am using fe32 to run a large transient simulation in a cluster. Due to the number of files limitation, I am unable to write much timesteps. A collated fileHandler is really needed for me to ensure I don't generate a lot of files. Is this feature available in fe32? |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 12:32 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
