codedFIxedValue, writing only to Z-Component of an Inletpatch
Like Tree2Likes
  • 1 Post By fanta
  • 1 Post By fanta
Old   May 12, 2018, 11:20
Arrow codedFIxedValue, writing only to Z-Component of an Inletpatch
fanta is on a distinguished road
i am working on a codedFixedValue Boundarycondition and i am stuck.
At the inlet i want to read the calculated rho from the field and correct the mass flow rate with the continuity equation. It starts with a rho read from the file rho.
Here ist my U file:
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            codedFixedValue;
    value        uniform (0 0 0.011449586); //5kg/h in +Z-Direction respectiv to the inlet;
    redirectType    rho_corrected;
    code
        const fvPatch& boundaryPatch = this->patch();
        vectorField& U = *this;
             const vectorField& Cf = boundaryPatch.Cf();
        scalar patchArea = gSum(boundaryPatch.magSf());
         const volScalarField& rhop = this->db().lookupObject<volScalarField>("rho");
        const scalar m_dot = 5.0/3600.0; // 5 kg/h Massflowrate
        volScalarField v = (m_dot/(rhop*patchArea)); //Continuity Equation
//        tmp<vectorField> n = this->patch().nf();
        fixedValueFvPatchVectorField myPatch(*this);
        forAll(this->patch().Cf(),i)
            myPatch[i]=vector(0,0,v);
//            myPatch[i]=vector(0,0,0.011449586);
        operator==(myPatch);
    outlet
        type            zeroGradient;
    wall
        type            noSlip;
    defaultFaces
    type         fixedValue;
    value        uniform (0 0 0);
Can someone help me? It doesn't run because of this line:
in the For loop. Seems i cannot apply v as a component to a vector. How do i do this? v is from the type volScalarField, vector is a vector (of which type of components?).
Kummi likes this.
fanta is offline   Reply With Quote
Old   May 12, 2018, 12:28
Taher Chegini
Taataa is on a distinguished road
Because you've defined v as a field then you've used it as a scalar!
Either directly calculate v in the loop using rhop[i] or use v[i].
Taataa is offline   Reply With Quote
Old   May 12, 2018, 13:55
Thanks for the hint, this is the code:
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    inlet
    code
//        scalar v = (m_dot/(rhop[2]*patchArea));
            myPatch[i]=vector(0,0, (m_dot/(rhop[2]*patchArea)));
    outlet
        type            zeroGradient;
    wall
        type            noSlip;
    defaultFaces
    type         fixedValue;
Zhiheng Wang likes this.
Old   May 24, 2018, 11:28
Zhiheng Wang
Zhiheng Wang is on a distinguished road
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    inlet
    code
    outlet
        type            zeroGradient;
    wall
        type            noSlip;
    defaultFaces
    type         fixedValue;
Excellent work thanks
Zhiheng Wang is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
