Access molecular weight from basicMultiComponentMixture |
April 25, 2018, 18:54 |
Somesh
I am trying to convert an old custom library from OpenFOAM-2.3.x to OpenFOAM-4.x The library uses molecular weights of different species in calculations. Earlier in OF-2.3.x the library had routines such as: Code:
void Foam::custom::computeCustom ( ... basicMultiComponentMixture& mixture ... ) { ... mixture.W(spIndex); // spIndex is an already-defined label ... } Does anyone have any suggestion on how to access molecular weight of species from basicMultiComponentMixture? |
April 25, 2018, 23:39 |
Yan Zhang
Rep Power: 12 |
Can it be replaced by
this->getLocalThermo(speciei).W() |
April 26, 2018, 08:45 |
Somesh
Thanks zhangyan for the quick reply.
I did not try your method, but I think I have figured it out (my C/C++ skills are rusty at best!) I used Code:
void Foam::custom::computeCustom ( ... basicMultiComponentMixture& mixture ... ) { ... const basicSpecieMixture& spMixture = dynamic_cast<const basicSpecieMixture&>(mixture); spMixture.W(spIndex); // spIndex is an already-defined label ... } |
4.x, molecular weight |
How to access species molecular weight in UDFs | Ellen | FLUENT | 3 | June 2, 2019 19:55 |
polymerization molecular weight distribution | Tleja | FLUENT | 0 | August 1, 2014 17:03 |
How to change molecular weight of a species in pdf-mixture | Jenny_W | FLUENT | 0 | November 3, 2012 16:49 |
Pressure and molecular weight ? | Jane | FLUENT | 0 | January 2, 2009 04:17 |
Molecular weight of the solid phase? | imburse | CFX | 3 | May 9, 2002 18:28 |
