Boussinesq equation of state combined with polynomial viscosity
Like Tree5Likes
  • 2 Post By TomasDenk
  • 3 Post By Marpole
Old   April 19, 2018, 06:02
Default Boussinesq equation of state combined with polynomial viscosity
Tomas Denk
TomasDenk is on a distinguished road
I'd like to solve a case where fluid density and viscosity depend on temperature. There are also some walls so I use chtMultiRegionSimpleFoam application.
When I set up thermophysical properties of the fluid like this:
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState Boussinesq;
    specie          specie;
    energy          sensibleEnthalpy;
I get FOAM FATAL ERROR: Unknown rhoTherm type, followed by listing of valid combinations. I can either use combination sutherland-janaf-Boussineq or polynomial-hPolynomial-icoPolynomial (for transport-thermo-equasionOfState respectively), however, I'd prefer not to.
Naive attempt to add another valid combination by adding
makeThermos
    rhoThermo,
    heRhoThermo,
    pureMixture,
    polynomialTransport,
    sensibleEnthalpy,
    hPolynomialThermo,
    Boussinesq,
    specie
to $FOAM_SRC/thermophysicalModels/basic/rhoThermo/rhoThermos.C did not help. Can someone explain why?
Is there a way to use combination of polynomial mu and Cp along with Boussinesq approximation?
parthigcar and Naaren like this.
TomasDenk is offline   Reply With Quote
Old   October 29, 2020, 08:41
Jan995 is on a distinguished road
Hi.
Did you find a proper solution to your problem?
Jan995 is offline   Reply With Quote
Old   October 29, 2020, 15:25
Default Re: polynomial
Charles
Marpole is on a distinguished road
You can use polynomial.
thermoType
    type            heRhoThermo;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleInternalEnergy;
For the equation of state, Boussinesq equation can be approximated by a polynomial. See Peric's book on page 15,
\rho = (\rho_0 + \rho_0 \beta T_0) - \rho_0 \beta T
TomasDenk, Jan995 and parthigcar like this.
Charles L.
Marpole is offline   Reply With Quote
Old   October 30, 2020, 04:16
Tomas Denk
Interesting, thanks for this tip, I haven't thought of that.
boussinesq approximation, thermophysical model
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
continuity equation was diverging in transient state stenber FLUENT 0 March 19, 2016 23:37
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
Lid-Driven-Cavity (thermodyn. equation of state)? Simonee Main CFD Forum 4 March 18, 2014 07:34
