Minor issue compiling solver
Like Tree1Likes
  • 1 Post By Taataa
Old   March 30, 2018, 11:14
Default Minor issue compiling solver
sturgeon is on a distinguished road
Hi all
I'm having a minor issue compiling UEqn for a solver I'm working on. I want to add a force and I'm putting it in the momentum predictor, but I've run into a strange problem.
When my code is like this:
volVectorField F("F",Fx*vector(1,0,0)+Fy*vector(0,1,0)+Fz*vector(0,0,1));
surfaceScalarField Ff = fvc::interpolate(F) & mesh.Sf();
    if (pimple.momentumPredictor())
        solve(UEqn == fvc::reconstruct
                     fvc::interpolate(rhok-1)*(g & mesh.Sf())
					+ Ff
					 - fvc::snGrad(p)*mesh.magSf()
        fvOptions.correct(U);
It compiles fine. However, when it's like this:
					+ fvc::interpolate(F) & mesh.Sf()
I get a huge stream of errors in the console. But to me they should be functionally identical - however clearly they are not. The only difference is in the version that compiles, the force is interpolated to the faces and stored as a variable Ff, and in the second, this step is skipped in favour of just interpolating the faces within the code for UEqn==.
I know this is minor but I'm interested as to why this error happens to improve my knowledge of C++ and OF development.
Thanks
sturgeon is offline   Reply With Quote
Old   March 30, 2018, 11:37
Taher Chegini
Taataa is on a distinguished road
The "*" operator is outer product and "&" is inner product and you're adding output of these two operators. So I guess the difference could be because of mismatching of types. In the upper case you declared the type whereas in the lower one the compiler is taking care of that.
sturgeon likes this.
Taataa is offline   Reply With Quote
Old   March 30, 2018, 12:29
That makes sense so I guess that could be the issue. I better look into this and make sure the code is doing what I intend.
Thank you!
make: Clock skew detected. build may be incomplete. while compiling new solver. savee OpenFOAM Programming & Development 1 May 27, 2017 07:23
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 09:05
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Compiling meltFoam solver mick223 OpenFOAM Programming & Development 12 July 31, 2015 11:33
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
