Writing reaction.R in reactingFoam
Like Tree3Likes
  • 1 Post By Swagga5aur
  • 2 Post By Swagga5aur
Old   March 24, 2018, 15:04
Post Writing reaction.R in reactingFoam
Lasse Brams Vinther
Swagga5aur is on a distinguished road
Hello Foamers,
I am trying to make a chemical reactor solver, with both catalyst temperature and the thermal properties of the reacting fluid.
The issue is with the reaction.R(Yi) in YiEqn, as its solved as a function of the fluid temperature, however, it should be based upon the catalyst temperature and I'm unable to alter the reaction.R in the solver. Therefore, I'm trying to define a new fvMatrix based upon the reaction.R(Yi) which I then may alter to depend on catalyst temperature and remove its dependence on the reacting fluid temperature.
I tried to do this be adding the following code to the following directories.
Createfields:
PtrList<fvScalarMatrix> RrateReactor(reactorRegions.size());
    Info<< "    Adding to RrateReactor\n" << endl;
    RrateReactor.set
        i,
        new fvScalarMatrix
            IOobject
                "Rrate",
                runTime.timeName(),
                reactorRegions[i],
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            reactorRegions[i],
	    fvMatrix<>("Rrate", dimEnergy/dimVolume/dimTime,0)
SetRegionFields
    	    fvMatrix& Rrate = reaction.R(Y[i]);
YiEqn;
    fvScalarMatrix& Rrate=RrateReactor[i];
However, this results in fvMatrix typing issues with the fvMatrix<>, and was hoping anyone could help me with the fvMatrix typing or have another solution approach for the above issue.
Here is a link to the solver which I'm trying to add the above in the reactor domain for OpenFOAM v4: https://www.dropbox.com/s/affha5r5ht...am.tar.gz?dl=0
Regards Lasse.
Rochi likes this.
Swagga5aur is offline   Reply With Quote
Old   October 20, 2018, 06:16
Faezeh
faeze.d is on a distinguished road
have a look at this thread:
Species Reaction Rate RR()
I think this would be helpful
faeze.d is offline   Reply With Quote
Old   October 22, 2018, 16:11
Default reactingRateFoam
Lasse Brams Vinther
Hi Faezeh,
Thank you for the link that helped a lot
I have attached a reactingRateFoam solver to this post for others to look at (for ofv6).
https://www.dropbox.com/s/6si5ecxjzm...am.tar.xz?dl=0
Going to implement it in a multi region solver as well.
luonghungtruyen and Rochi like this.
reaction rate, temperature dependence
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
