New output variable for source term in fvoptions - without changing the solver
Like Tree6Likes
  • 6 Post By vincent.clary
Old   February 23, 2018, 12:21
Default New output variable for source term in fvoptions - without changing the solver
Vincent Clary
vincent.clary is on a distinguished road
Hello everybody,
We are running simulations imposing force source terms in order to model roughly tidal turbines with Actuator Disk method or equivalent.
We added the code in fvoptions, calling an external .h file Vectorcodedsource.h (that we created) because the code was too long to be implemented directly in fvoptions.
Everything is running well but we now would like to create an output variable for this force source term (that is a vector). Is there a way to program this directly in fvoptions? Or another method without modifying the solver?
Thank you a lot for your help. Here are the fvoptions file and .h files.
fvOptions.txt
myLongCode.H
vincent.clary is offline   Reply With Quote
Old   February 24, 2018, 07:45
Anurag
anuragm is on a distinguished road
Originally Posted by vincent.clary View Post
Hello everybody,
You can try working with function objects in your controlDict. Here is a good documentation on how to implement and use this feature.
http://www.tfd.chalmers.se/~hani/kur...CFD_Report.pdf
You can create these objects either at runtime or after the simulation has completed using -postProcess flag
anuragm is offline   Reply With Quote
Old   June 26, 2018, 06:21
Vincent Clary
Thank you for your answer, I'm replying quite late!
Finally we solved the problem by creating a new field in fvOptions:
//creates object to be able to have the Termsource output in paraview
volVectorField Termsource
     IOobject
         "Termsource",
mesh_.time().timeName(),
                 mesh_,
                 IOobject::NO_READ,
                 IOobject::AUTO_WRITE
         mesh_,
         dimensionedVector
                 "Uvec",
                 dimVelocity,
                 vector::zero
Then we implement Termsource in the code.
And to have the output only at selected output times:
if(mesh_.time().outputTime())
    Termsource.write();
Sun, SHUBHAM9595, ruloz and 3 others like this.
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Variable value with time - from SOLVER FILE Tuks CFX 4 July 11, 2005 06:49
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
