Vary stiffness over time - sixDoFRigidBodyMotion
Like Tree6Likes
  • 2 Post By Rodolfo Puraca
  • 4 Post By Rodolfo Puraca
Old   February 16, 2018, 18:06
Post Vary stiffness over time - sixDoFRigidBodyMotion
Rodolfo Puraca
Rodolfo Puraca is on a distinguished road
Hi all,
I have been trying to modify the LinearSpring restraint in the sixDoFRigidBodyMotion libary. I am trying to make the spring vary its stiffness over time, using a expression like this:
variable_stiffness(time) = stiffness + (percentage*stiffness*sin(frequency*time))
Where the inputs stiffness, percentage and frequency will come from dynamicMeshDict.
My code for the spring class:
MylinearSpring.H
#ifndef linearSpring_H
#define linearSpring_H
#include "sixDoFRigidBodyMotionRestraint.H"
#include "point.H"
namespace Foam
namespace sixDoFRigidBodyMotionRestraints
                          Class linearSpring Declaration
class linearSpring
    public sixDoFRigidBodyMotionRestraint
    // Private data
        //- Anchor point, where the spring is attached to an immovable
        //  object
        point anchor_;
        //- Reference point of attachment to the solid body
        point refAttachmentPt_;
        //- Spring stiffness coefficient (N/m)
        scalar stiffness_;
        //- Damping coefficient (Ns/m)
        scalar damping_;
        //- Rest length - length of spring when no forces are applied to it
        scalar restLength_;
	//- Percentage
	scalar porcentagem_;
	//- Frequência (rad/s)
	scalar freq_;
public:
    //- Runtime type information
    TypeName("linearSpring");
    // Constructors
        //- Construct from components
        linearSpring
            const word& name,
	    //const Time& runTime,
            const dictionary& sDoFRBMRDict
        //- Construct and return a clone
        virtual autoPtr<sixDoFRigidBodyMotionRestraint> clone() const
            return autoPtr<sixDoFRigidBodyMotionRestraint>
                new linearSpring(*this)
    //- Destructor
    virtual ~linearSpring();
    // Member Functions
        //- Calculate the restraint position, force and moment.
        //  Global reference frame vectors.
        virtual void restrain
            const sixDoFRigidBodyMotion& motion,
            vector& restraintPosition,
            vector& restraintForce,
            vector& restraintMoment
        ) const;
        //- Update properties from given dictionary
        virtual bool read(const dictionary& sDoFRBMRCoeff);
        //- Write
        virtual void write(Ostream&) const;
} // End namespace solidBodyMotionFunctions
} // End namespace Foam
#endif
MylinearSpring.C
#include "MylinearSpring.H"
#include "addToRunTimeSelectionTable.H"
#include "sixDoFRigidBodyMotion.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
    defineTypeNameAndDebug(linearSpring, 0);
        sixDoFRigidBodyMotionRestraint,
        linearSpring,
        dictionary
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::sixDoFRigidBodyMotionRestraints::linearSpring::linearSpring
    const word& name,
    sixDoFRigidBodyMotionRestraint(name, sDoFRBMRDict),
    anchor_(),
    refAttachmentPt_(),
    stiffness_(),
    damping_(),
    restLength_(),
    porcentagem_(),
    freq_()
    read(sDoFRBMRDict);
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::sixDoFRigidBodyMotionRestraints::linearSpring::~linearSpring()
// * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * * //
void Foam::sixDoFRigidBodyMotionRestraints::linearSpring::restrain
) const
    restraintPosition = motion.transform(refAttachmentPt_);
    vector r = restraintPosition - anchor_;
    scalar magR = mag(r);
    r /= (magR + VSMALL);
    vector v = motion.velocity(restraintPosition);
    scalar current_time = runTime.time().value();
    scalar variable_stiffness = (stiffness_+(porcentagem_*stiffness_*sin(freq_*current_time)));
	Info<< "Variable Spring Value= " << variable_stiffness << endl;
    restraintForce = -variable_stiffness*(magR - restLength_)*r - damping_*(r & v)*r;
    restraintMoment = Zero;
    if (motion.report())
        Info<< " attachmentPt - anchor " << r*magR
            << " spring length " << magR
            << " force " << restraintForce
            << endl;
bool Foam::sixDoFRigidBodyMotionRestraints::linearSpring::read
    sixDoFRigidBodyMotionRestraint::read(sDoFRBMRDict);
    sDoFRBMRCoeffs_.lookup("anchor") >> anchor_;
    sDoFRBMRCoeffs_.lookup("refAttachmentPt") >> refAttachmentPt_;
    sDoFRBMRCoeffs_.lookup("stiffness") >> stiffness_;
    sDoFRBMRCoeffs_.lookup("damping") >> damping_;
    sDoFRBMRCoeffs_.lookup("restLength") >> restLength_;
    return true;
void Foam::sixDoFRigidBodyMotionRestraints::linearSpring::write
    Ostream& os
) const
    os.writeKeyword("anchor")
        << anchor_ << token::END_STATEMENT << nl;
    os.writeKeyword("refAttachmentPt")
        << refAttachmentPt_ << token::END_STATEMENT << nl;
    os.writeKeyword("stiffness")
        << stiffness_ << token::END_STATEMENT << nl;
    os.writeKeyword("damping")
        << damping_ << token::END_STATEMENT << nl;
    os.writeKeyword("restLength")
        << restLength_ << token::END_STATEMENT << nl;
When I compile the code I get this error:
In member function ‘virtual void Foam::sixDoFRigidBodyMotionRestraints::linearSpring::restrain(const Foam::sixDoFRigidBodyMotion&, Foam::vector&, Foam::vector&, Foam::vector&) const’:
sixDoFRigidBodyMotion/restraints/linearSpring/MylinearSpring.C:95:27: error: ‘runTime’ was not declared in this scope
It seems that the class MylinearSpring don't have the access to the time.
From the similars topics that I found in the forum, I think that I have to edit the sixDoFRigidBodyMotion.C and sixDoFRigidBodyMotion.H to make new functions to get the time, but I was not sucessful implementing theses solutions.
Topic #6
Access the Time object in sixDoFRigidBodyMotionRestraints
Topic #6
Check current time
Topic #2
How to access to the solid body motion state from a custom interDyMFoam.C ?
If anyone knows how to implement theses solutions or helps me to implement I would be very grateful.
Thanks,
Rodolfo Puraca
Tolga KURUMUS and AbdoMusaad like this.
Rodolfo Puraca is offline   Reply With Quote
Old   February 22, 2018, 20:51
Talking The Solution
Rodolfo Puraca
Hi all,
I am posting the solution that I have encountered. I don't know if is the best solution, but works The version of OpenFoam that I am using is 5.0.
After digging in the code a little more, I found a variable named deltaT in the function solve on the Sympletic class (sympletic.C / sympletic.H). The function solve calls the function updateAceleration located in the class sixDoFRigidMotion. What I did, was put the variable deltaT in the function updateAceleration.
void Foam::sixDoFRigidBodyMotion::updateAcceleration
    const vector& fGlobal,
    const vector& tauGlobal,
    const scalar deltaT
After that, the function applyRestrains() is called in the function updateAceleration, so I put again the variable deltaT in applyRestraints.
void Foam::sixDoFRigidBodyMotion::applyRestraints(const scalar deltaT)
Finally, the function restrains() is called, and this function was that I wanted to work.
    vector& restraintMoment,
    const scalar deltaT
) const
One thing bad, is that I needed to do theses modifications in all the classes where this functions appears, that includes the solvers and all restraints.
I attached the library that I modified, to help someone that needs to do something similar.
Regards,
Rodolfo Puraca
restraints, sixdofrigidbodymotion, spring, time
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 09:22
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
