convert a "volScalarField" to an "fvScalarMatrix" |
A. Min
Rep Power: 12 ![]() |
Hi
How can I convert a "volScalarField" to an "fvScalarMatrix"? I want to add a volScalarField term to energy Eqn. Thanks |
Sergei
Rep Power: 21 ![]() |
Adding a volScalarField to a fvScalarMatrix is as simple as this:
volScalarField source = ...; fvScalarMatrix equation = ...; equation == source; |
#3 | |
A. Min
Yes, I did it by chance and it didn't give me any error😁 I thought that these kind of variables are different. Again thanks |
Sergei
Even though types of variables are different they can be operated that way just fine giving you the result that you might expect.
Rosario Arnau
Rep Power: 9 ![]() |
Hi Foamers,
I would like to save the values of the fvScalarMatrix after solving it. But the operator "==" doesn't work upside down, I mean, assigning the values of the fvScalarMatrix to a volScalarField. Do you know how to do it? Thanks, |
Agustín Villa
Rep Power: 15 ![]() |
you can't do this because a volScalarField is a scalar variable. fvScalarMatrix is an equation for a scalar variable. What do you want to save from it? |
Rosario Arnau
Hi agustinvo,
I would like to save the solution of the fvScalarMatrix and then, pass the solution as a volScalarField to another fvScalarMatrix something like: Code:
fvScalarMatrix equation0 (); equation0.solve(); fvScalarMatrix equation1 (blablablah=solution of equation0) |
Agustín Villa
Well, when you solve your fvScalarMatrix equation0 you compute the value of a certain variable var0. Then just add it as a source term into equation1.
#9 |
Rosario Arnau
The problem is that the dependent variable of equation0 is not the same as the one in equation1...
Thanks for your quick reply, |
#10 |
Agustín Villa
That is not a problem! Look:
fvScalarMatrix TEqn ( fvm::div(phi, T) - fvm::laplacian(alphaEff, T) == fvOptions(T) ); You can add later on T in a source term of any other equation, like Code:
tmp<fvVectorMatrix> tUEqn ( fvm::div(phi, U) + turbulence->divDevReff(U) == g*beta*(T-TRef) + fvOptions(U) ); Last edited by agustinvo; April 3, 2020 at 12:05. Reason: Code |
#11 |
Rosario Arnau
My code is something like:
fvScalarMatrix STransfer ( K*S2Sat - fvm::Sp(K,S2) ); STransfer.solve(); fvScalarMatrix S2Eqn ( fvm::ddt(alpha2, S2) + fvm::div(alphaPhi2, S2) == STransfer ); S2Eqn.solve(); fvScalarMatrix S1Eqn ( fvm::ddt(alpha1, S1) + fvm::div(alphaPhi1, S1) == -STransfer ); S1Eqn.solve(); That's one of the problems and probably I would face more after solving this one... Thanks in advance, PD: Do not hesitate to sent my a private message. |
#12 |
Sergei
You may want to use S2 field for which S2Eqn equation has been solved for
fvScalarMatrix S1Eqn ( fvm::ddt(alpha1, S1) + fvm::div(alphaPhi1, S1) == -(K*S2Sat - K*S2) ); S1Eqn.solve(); |
#13 |
Agustín Villa
Indeed, this is what it was planned to add.
#14 |
Rosario Arnau
Thanks for your help Zeppo and agustinvo.
I have compiled that code and I'm trying it at a simple case. |
openfoam, programing |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 44 | March 12, 2024 00:35 |
[snappyHexMesh] Convert stl files and multi region | abrunet | OpenFOAM Meshing & Mesh Conversion | 1 | July 1, 2014 10:15 |
convert a structured multiblock grid to an one unstructured: modification of cells | Mirage | ANSYS | 0 | July 18, 2012 09:14 |
ImageMagick will not convert jpg to mpg | musahossein | Main CFD Forum | 1 | December 2, 2011 10:44 |
