Modified pointVectorField.boundaryField is not written to output file
Like Tree1Likes
  • 1 Post By elmo555
Old   January 17, 2018, 10:49
Default Modified pointVectorField.boundaryField is not written to output file
Lennart
elmo555 is on a distinguished road
Dear foamers,
I'm trying to interpolate a surfaceVectorField to pointVectorField and then write it to a output file with the following code, but nothing gets written:
pointVectorField sensPointVec
    IOobject
        "sensPointVec",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    pointMesh::New(mesh),
    dimensionedVector("(0,0,0)", dimless, vector::zero),
    "fixedValue"
            PrimitivePatchInterpolation<primitivePatch> patchInterpolator
                mesh.boundaryMesh()[bi]
            vectorField interpSensPointVec = patchInterpolator.faceToPointInterpolate(sensSurfaceVec.boundaryField()[bi]);
            Info << "interpSensPointVec " << interpSensPointVec << endl;
            sensPointVec.boundaryFieldRef()[bi] = interpSensPointVec;
The code compiles and runs and the new vectorField interpSensPointVec is filled with data (Info prints tons of data to the screen). But the output file sensPointVec contains just the initially set values and not the ones written into sensPointVec.boundaryFieldRef()[bi]:
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            fixedValue;
Any help is appreciated!
ancolli likes this.
elmo555 is offline   Reply With Quote
Old   January 18, 2018, 11:42
Lennart
I think I found the solution, you just need to replace the = in the assignment with ==
            sensPointVec.boundaryFieldRef()[bi] == interpSensPointVec;
An explanation for the difference between = and == in boundary condition assignment can be found in this thread.
boundaryfield, output, pointvectorfield
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
