Check if volumetric scalar field exists or is declared
Like Tree5Likes
  • 5 Post By mAlletto
Old   December 3, 2017, 05:50
Default Check if volumetric scalar field exists or is declared
RGS
Rohit George Sebastian
RGS is on a distinguished road
Hello all!
Is there a way to check if a volumetric scalar field has already been declared?
I have the following code for a function:
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::tempPowerLaw::calcNu() const
    const volScalarField& T = U_.mesh().lookupObject<volScalarField>("T");
    return a_*exp(b_*T) + c_*exp(d_*T);
And I want to lookup the value of T only if T has already been defined.
Any suggestions?
Thanks in advance!!
RGS is offline   Reply With Quote
Old   November 12, 2020, 06:34
Michael Alletto
mAlletto will become famous soon enough
just in case someone looks at this thread:
U_.mesh().foundObject<volScalarField>("T")
returns true if T is found in the database and false if not
salehi144, Kojote, Pagoda and 2 others like this.
mAlletto is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
issue compiling new turbulence model perplexed user OpenFOAM Programming & Development 1 January 13, 2012 04:40
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
