liquid/vapor mass flux boundary conditions
Like Tree2Likes
  • 1 Post By gaza
  • 1 Post By andrea
Old   October 17, 2017, 17:39
Default liquid/vapor mass flux boundary conditions
BarCFD is on a distinguished road
Hi Foamers,
A Simplified geometry for my problem is provided here. I have an evaporator where water comes in from inlet and steam goes out from outlet. I wonder if I can define boundary conditions in the way that mass flux of liquid in the inlet becomes same as mass flux of vapor in the outlet. Can I use groovyBC? How?
Thanks in advance,
File Type: png Screenshot from 2017-10-17 16-23-58.png (14.0 KB, 52 views)
BarCFD is offline   Reply With Quote
Old   October 19, 2017, 18:13
Przemek
gaza is on a distinguished road
Hi BarCFD
Of course you can, however it should result from void fraction equation rather from boundary condition (but I might be wrong)
BarCFD likes this.
best regards
pblasiak
gaza is offline   Reply With Quote
Old   October 23, 2017, 04:38
Andrea Petronio
andrea is on a distinguished road
we addressed this problem while ago. You can find the details in this paper:
P. Sosnowski, A. Petronio, V. Armenio, "Numerical model for thin liquid film with evaporation and condensation on solid surfaces in systems with conjugated heat transfer", International Journal of Heat and Mass Transfer 66 (2013) 382–395, in which a laminar case is discussed. Then we analyzed also a turbulent case with LES in:
Carlo Cintolesi, Andrea Petronio, Vincenzo Armenio
"Large-eddy simulation of thin film evaporation and condensation
from a hot plate in enclosure: First order statistics", International Journal of Heat and Mass Transfer 101 (2016) 1123–1137,
and in
Carlo Cintolesi, Andrea Petronio, Vincenzo Armenio, "Large-eddy simulation of thin film evaporation and condensation from a hot plate in enclosure: Second order statistics", International Journal of Heat and Mass Transfer 115 (2017) 410–423.
Hope you can get some usefull hints,
ciao
BarCFD likes this.
andrea is offline   Reply With Quote
Old   October 23, 2017, 13:55
Thanks a lot Andrea!
Old   October 24, 2017, 11:37
Charles
Marpole is on a distinguished road
You either specify inlet mass flow flux or specify outlet mass flow flux. But you don't specify inlet mass flow flux using outlet mass flow flux. This doesn't make sense that computation could diverge easily.
Marpole is offline   Reply With Quote
Old   October 25, 2017, 15:07
Thanks Charles,
In fact the idea here is to verify the solvent for boiling in steady state condition. Assume that all vapor exits from boiler (to a condenser ) returns to boiler in the liquid phase.
Old   October 25, 2017, 17:08
Charles
That's incorrect setting. The flow can be arbitrary which causes your problem as there is a driving force outside of your model. You can measure the flow rate though or, if you have pump, you should know the flow rate from the pump specification.
boundaries condition, groovybc, reactingtwophaseeulerfoam
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Algorithm for coupled pde with all flux boundary conditions benk Main CFD Forum 3 December 28, 2010 06:09
