Adding Properties to Lagrangian Particle - IOstream problems
Like Tree1Likes
  • 1 Post By ano
Old   October 16, 2017, 11:45
Default Adding Properties to Lagrangian Particle - IOstream problems
A_Pete is on a distinguished road
Hi everyone,
I am trying to add some properties to the KinematicParcel class. The constructor I am having problems with is the one in KinematicParcelIO.C:
template<class ParcelType>
Foam::KinematicParcel<ParcelType>::KinematicParcel
    const polyMesh& mesh,
    Istream& is,
    bool readFields
    ParcelType(mesh, is, readFields),
    active_(false),
    typeId_(0),
    nParticle_(0.0),
    d_(0.0),
    dTarget_(0.0),
    U_(Zero),
    rho_(0.0),
    age_(0.0),
    tTurb_(0.0),
    UTurb_(Zero),
    rhoc_(0.0),
    Uc_(Zero),
    muc_(0.0),
    newVar_(Zero)
    is.read(reinterpret_cast<char*>(&active_), sizeofFields_);
I added the global variable newVar_ to this class. My problem is that I do not fully understand the line with is.read, which I have written in the end. I suppose that I somehow need to give the amount of bytes to register for reading. It uses the sizeofFields_ variable, which is defined like this:
const std::size_t Foam::KinematicParcel<ParcelType>::sizeofFields_
    offsetof(KinematicParcel<ParcelType>, rhoc_)  // changing rhoc_ to newVar_ is not working
  - offsetof(KinematicParcel<ParcelType>, active_)
I think, that I need to change the sizeofFields function, but whatever I do the size I give, does not seem to be correct.
Does anybody have any ideas on how to cope with this?
Thanks in advance.
Best regards,
Andreas
A_Pete is offline   Reply With Quote
Old   October 16, 2017, 14:51
ano
ano
ano is on a distinguished road
Hello Andreas,
as far as I understand the sizeofFields gives the size of things you want to read. active_ is your first variable of your parcel properties, it ends before rhoc_ because it is the first cell based variable (and does not come from istream), so it just includes UTurb_ and not rhoc_ anymore.
So I would have guessed that adding a new variable to parcel properties should work. At which position did you add your newVar_ in the header file? Do you have to read and write the variable? Or do you calculate it from other variables?
Which error does your compiler throw?
A_Pete likes this.
ano is offline   Reply With Quote
Old   October 17, 2017, 05:00
Thanks for your answer!
Yes, that is also kind of my understanding of the sizeofFields_ variable. By using offsetof() you try to give the offset sizes until reaching the regarded variable.
I should actually give my full constructor, since I try to add multiple variables multiple variables, which need to be read and written as well. What I have is a combination of the KinematicParcel and the CollidingParcel. Since I had to modify the KinematicParcel and the KinematicCloud, I can not use the template polymorphism between the Colliding and Kinematic classes anymore. Therefore I wanted to put all the extra properties from the Colliding class into the Kinematic class.
This works perfectly in a serial run. But not in a parallel run. The error appears, once the described constructor is called, which only seems to be the case for a parallel run. My real constructor looks like this:
Foam::KinematicCollidingParcel<ParcelType>::KinematicCollidingParcel
    const Cloud<KinematicCollidingParcel<ParcelType> >& c,
    Istream& is,
    bool readFields
    oderp_(c),
active_(false),
typeId_(0),
    nParticle_(0.0),
    radius_(0.0),
    radiusGrowthRate_(0.0),
    d_(0.0),
    dTarget_(0.0),
    R0L_(0.0),
    U_(Zero),
    rho_(0.0),
    age_(0.0),
    tTurb_(0.0),
    UTurb_(Zero),
    pSap_(0.0),
    pB_(0.0),
    wallDist_(0.0),
    f_(Zero),
    angularMomentum_(Zero),
    torque_(Zero),
    collisionRecords_(),
    rhoc_(0.0),
    Uc_(Zero),
    muc_(0.0)
I left the sizeofFields_ variable as it is, since I added the new particle variables in front of rhoc_. I also tried to change rhoc_ to collisionRecords_ in sizeofFields_
The error looks like this:
[3] #1  Foam::sigFpe::sigHandler(int) at ??:?
[2] #1  Foam::sigFpe::sigHandler(int) at ??:?
[3] #2  ? at ??:?
[2] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3   in "/lib/x86_64-linux-gnu/libc.so.6"[2] #3  ?? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/ODE/lnInclude/ODERPI.H:58
[3] #4  Foam::KinematicCollidingParcel<Foam::particle>::KinematicCollidingParcel(Foam::KinematicCollidingParcel<Foam::particle> const&) at /local/OpenFOAM/peters-4.x/src/lagrangianRP/ODE/lnInclude/ODERPI.H:58
[2] #4  Foam::KinematicCollidingParcel<Foam::particle>::KinematicCollidingParcel(Foam::KinematicCollidingParcel<Foam::particle> const&) at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingParcel.C:274 (discriminator 2)
[3] #5  Foam::KinematicCollidingParcel<Foam::particle>::clone() const at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingParcel.C:274 (discriminator 2)
[2] #5  Foam::KinematicCollidingParcel<Foam::particle>::clone() const at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingParcel.H:473 (discriminator 2)
[3] #6  Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> >::operator=(Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> > const&) at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingParcel.H:473 (discriminator 2)
[2] #6  Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> >::operator=(Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> > const&) at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/ILList.C:146
[3] #7  Foam::InteractionLists<Foam::KinematicCollidingParcel<Foam::particle> >::receiveReferredData(Foam::PstreamBuffers&, int) at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/ILList.C:146
[2] #7  Foam::InteractionLists<Foam::KinematicCollidingParcel<Foam::particle> >::receiveReferredData(Foam::PstreamBuffers&, int) at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/IDLList.H:48
[3] #8  Foam::PairCollision<Foam::KinematicCollidingCloud<Foam::Cloud<Foam::KinematicCollidingParcel<Foam::particle> > > >::parcelInteraction() at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/IDLList.H:48
[2] #8  Foam::PairCollision<Foam::KinematicCollidingCloud<Foam::Cloud<Foam::KinematicCollidingParcel<Foam::particle> > > >::parcelInteraction() at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/PairCollision.C:79
[3] #9  Foam::PairCollision<Foam::KinematicCollidingCloud<Foam::Cloud<Foam::KinematicCollidingParcel<Foam::particle> > > >::collide() at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/PairCollision.C:79
[2] #9  Foam::PairCollision<Foam::KinematicCollidingCloud<Foam::Cloud<Foam::KinematicCollidingParcel<Foam::particle> > > >::collide() at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/PairCollision.C:751
[3] #10  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:125
[3] #11  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/PairCollision.C:751
[2] #10  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:834
[3] #12  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:247
[3] #13   at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:125
[2] #11  ?? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:155
[3] #14  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:834
[2] #12  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:783
[3] #15  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingCloud.C:247
[2] #13  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/interPhaseChangeCollidingParcelFoam/interPhaseChangeCollidingParcelFoam.C:98
[3] #16  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #17  ? at ??:?
[prop-04:06264] *** Process received signal ***
[prop-04:06264] Signal: Floating point exception (8)
[prop-04:06264] Signal code:  (-6)
[prop-04:06264] Failing at address: 0x7f100001878
[prop-04:06264] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x350e0) [0x7fc60d2470e0]
[prop-04:06264] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7fc60d247067]
[prop-04:06264] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x350e0) [0x7fc60d2470e0]
[prop-04:06264] [ 3] interPhaseChangeCollidingParcelFoam() [0x4f6507]
[prop-04:06264] [ 4] interPhaseChangeCollidingParcelFoam(_ZN4Foam24KinematicCollidingParcelINS_8particleEEC2ERKS2_+0x51) [0x4ed25f]
[prop-04:06264] [ 5] interPhaseChangeCollidingParcelFoam(_ZNK4Foam24KinematicCollidingParcelINS_8particleEE5cloneEv+0x2f) [0x4e329f]
[prop-04:06264] [ 6] interPhaseChangeCollidingParcelFoam(_ZN4Foam6ILListINS_10DLListBaseENS_24KinematicCollidingParcelINS_8particleEEEEaSERKS5_+0x55) [0x4d7a6d]
[prop-04:06264] [ 7] /local/OpenFOAM/peters-4.x/platforms/linux64GccDPInt32Opt/lib/liblagrangianRPIntermediate.so(_ZN4Foam16InteractionListsINS_24KinematicCollidingParcelINS_8particleEEEE19receiveReferredDataERNS_14PstreamBuffersEi+0x265) [0x7fc615095395]
[prop-04:06264] [ 8] /local/OpenFOAM/peters-4.x/platforms/linux64GccDPInt32Opt/lib/liblagrangianRPIntermediate.so(_ZN4Foam13PairCollisionINS_23KinematicCollidingCloudINS_5CloudINS_24KinematicCollidingParcelINS_8particleEEEEEEEE17parcelInteractionEv+0xe7) [0x7fc615098bd7]
[prop-04:06264] [ 9] /local/OpenFOAM/peters-4.x/platforms/linux64GccDPInt32Opt/lib/liblagrangianRPIntermediate.so(_ZN4Foam13PairCollisionINS_23KinematicCollidingCloudINS_5CloudINS_24KinematicCollidingParcelINS_8particleEEEEEEEE7collideEv+0x38) [0x7fc615098ce8]
[prop-04:06264] [10] interPhaseChangeCollidingParcelFoam() [0x4c4138]
[prop-04:06264] [11] interPhaseChangeCollidingParcelFoam() [0x4af0b2]
[prop-04:06264] [12] interPhaseChangeCollidingParcelFoam() [0x49a3dc]
[prop-04:06264] [13] interPhaseChangeCollidingParcelFoam() [0x483b58]
[prop-04:06264] [14] interPhaseChangeCollidingParcelFoam() [0x46b9d6]
[prop-04:06264] [15] interPhaseChangeCollidingParcelFoam() [0x452b27]
[prop-04:06264] [16] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fc60d233b45]
[prop-04:06264] [17] interPhaseChangeCollidingParcelFoam() [0x44c569]
[prop-04:06264] *** End of error message ***
[2] #14  ?--------------------------------------------------------------------------
mpirun noticed that process rank 3 with PID 6264 on node prop-04 exited on signal 8 (Floating point exception).
I used print debugging as well and I can see that the last output messages are in the regarded constructor, but it does not get past the iNew call in InteractionList.C:
forAll(constructMap, i)
    //here I can see the Pout message on the aborting processor
    referredParticles_[constructMap[i]  = IDLList<ParticleType>
        str,
        typename ParticleType::iNew(cloud_, mesh_)
The iNew constructor was changed by me, but works as long as I do not use any collision. I am pretty sure that my size definition in read is the problem.
Thanks in advance!
Old   October 17, 2017, 06:52
ano
ano
What I am a little bit confused about is that it seems that the floating point exception happens as far as I can see in a copy constructor.
So my first uneducated guess would be: during parallel run parcels have to be copied and somehow that doesn't work, perhaps the copy constructor doesn't match the class anymore.
For floating point exception we either have a division by zero or an overflow when a variable cannot be represented by the data type. Both don't seem very likely in a copy constructor. And you write that the Info statements showed you that it happens in the istream constructor.
If it is due to sizeofFields, it wouldn't appear for an ASCII istream, is that correct?
You seem to have compiled the code in debugging mode. Did you try gdb to see which variable throws fpe?
Old   October 17, 2017, 08:25
Thanks for your answer again.
I do not really know how to get the istream as ASCII. It does not depend on the writeFormat, right? Because I have set this to ASCII for all my tests already.
Because of your explanation I had a look at the two different versions for sizeofFields_ now and they give different errors:
version 1:
const std::size_t Foam::KinematicCollidingParcel<ParcelType>::sizeofFields_
    offsetof(KinematicCollidingParcel<ParcelType>, rhoc_)
  - offsetof(KinematicCollidingParcel<ParcelType>, active_)
gives the error starting with
 at ??:?
 at ??:?
[2] #1  Foam::sigSegv::sigHandler(int)[3] #1  Foam::sigSegv::sigHandler(int) at ??:?
[3] #2  ? at ??:?
[3] #3  ?? at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/List.C:358 (discriminator 2)
[3] #4   at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/List.C:358 (discriminator 2)
[2] #4  Foam::List<Foam::PairCollisionRecord<Foam::Vector<double> > >::setSize(int)Foam::List<Foam::PairCollisionRecord<Foam::Vector<double> > >::setSize(int) at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/       lnInclude/List.C:334
[2] #5  Foam::Istream& Foam::operator>><Foam::PairCollisionRecord<Foam::Vector<double> > >(Foam::Istream&, Foam::List<Foam::PairCollisionRecord<Foam::Vector<double> > >&) at /local/OpenFOAM/OpenFOAM-4.x/src/    OpenFOAM/lnInclude/List.C:334
[3] #5  Foam::Istream& Foam::operator>><Foam::PairCollisionRecord<Foam::Vector<double> > >(Foam::Istream&, Foam::List<Foam::PairCollisionRecord<Foam::Vector<double> > >&) at /local/OpenFOAM/OpenFOAM-4.x/src/    OpenFOAM/lnInclude/ListIO.C:49
[2] #6  ? at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/ListIO.C:49
[3] #6  ? at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/DynamicList.C:59
[2] #7  ? at /local/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/DynamicList.C:59
[3] #7  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/CollisionRecordList.C:449
and version 2:
    offsetof(KinematicCollidingParcel<ParcelType>, collisionRecords_)
gives me the error starting with
at ??:?
[3] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3   at ??:?
[2] #2  ?? in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/ODE/lnInclude/ODERPI.H:58
[2] #4  Foam::KinematicCollidingParcel<Foam::particle>::KinematicCollidingParcel(Foam::KinematicCollidingParcel<Foam::particle> const&) at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/     KinematicCollidingParcel.C:274 (discriminator 2)
[3] #6  Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> >::operator=(Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> > const&) at /local/OpenFOAM/     peters-4.x/src/lagrangianRP/intermediate/lnInclude/KinematicCollidingParcel.H:473 (discriminator 2)
[2] #6  Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> >::operator=(Foam::ILList<Foam::DLListBase, Foam::KinematicCollidingParcel<Foam::particle> > const&) at /local/OpenFOAM/     OpenFOAM-4.x/src/OpenFOAM/lnInclude/ILList.C:146
[2] #8  Foam::PairCollision<Foam::KinematicCollidingCloud<Foam::Cloud<Foam::KinematicCollidingParcel<Foam::particle> > > >::parcelInteraction() at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/       lnInclude/PairCollision.C:79
[2] #9  Foam::PairCollision<Foam::KinematicCollidingCloud<Foam::Cloud<Foam::KinematicCollidingParcel<Foam::particle> > > >::collide() at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/       PairCollision.C:79
[3] #9  Foam::PairCollision<Foam::KinematicCollidingCloud<Foam::Cloud<Foam::KinematicCollidingParcel<Foam::particle> > > >::collide() at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/       PairCollision.C:751
[2] #10  ? at /local/OpenFOAM/peters-4.x/src/lagrangianRP/intermediate/lnInclude/PairCollision.C:751
This looks to me like one of them reserves the correct size for the istream and is crashing in another part of the code and one just gets the wrong size in here.
I tried to work with gdb, but since it is a parallel run I don't really know how to debug properly. I tried the mpirunDebug, but I don't get any error messages in the log files of the different processors.
Old   May 24, 2018, 14:53
Joaquín Neira
cojua8 is on a distinguished road
I had the same issue and I solved it by moving my new variable up in the constructor (new variables are vectorList and scalarList types
    active_(false),
    typeId_(0),
    nParticle_(0.0),
    d_(0.0),
    dTarget_(0.0),
    U_(Zero),
    rho_(0.0),
    age_(0.0),
    tTurb_(0.0),
    UTurb_(Zero),
    dtList_(),
    UrList_(),
    rhoc_(0.0),
    Uc_(Zero),
    muc_(0.0)
and
    offsetof(KinematicParcel<ParcelType>, dtList_)
cojua8 is offline   Reply With Quote
Post processing of Lagrangian particle field marialhm OpenFOAM Post-Processing 0 October 8, 2017 23:02
[swak4Foam] Validation of swak4Foam for lagrangian particle tracking nero235 OpenFOAM Community Contributions 13 March 28, 2017 06:45
OpenFOAM lagrangian particle tracking solver C++ developer needed hampycalc CFD Freelancers 1 May 18, 2016 09:46
Particle Reynolds number calculation in Lagrangian tracking? jiejie OpenFOAM Running, Solving & CFD 5 July 6, 2012 05:47
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
