Boundary condition
Like Tree7Likes
  • 1 Post By BarCFD
  • 1 Post By MSF
  • 1 Post By babakflame
  • 2 Post By babakflame
  • 2 Post By Zhiheng Wang
Old   September 20, 2017, 16:22
Default Boundary condition
BarCFD is on a distinguished road
Hello FOAMers,
I want to impose a boundary condition which is an exponential function of the Field. Lets assume that I want to solve Laplace equation for temperature (thermal diffusion in solid). How can I have following boundary conditions?
Kummi likes this.
BarCFD is offline   Reply With Quote
Old   September 21, 2017, 04:35
MSF
MSF is on a distinguished road
I think the easiest way would be groovyBC.
https://openfoamwiki.net/index.php/Contrib/groovyBC
Best,
Moritz
Kummi likes this.
MSF is offline   Reply With Quote
Old   September 21, 2017, 08:12
LeeRuns is on a distinguished road
Couldn't we just add this to the openfoam build
Sent from my SM-G930V using CFD Online Forum mobile app
LeeRuns is offline   Reply With Quote
Old   September 21, 2017, 20:59
Bobby
babakflame is on a distinguished road
This a robin type boundary condition in OpenFOAM.
Search a little bit before asking. Here is the link:
http://www.modlab.lv/docs/2011/OpenF...Vilums_pdf.pdf
How to write exponential in boundary condition plus laplace samples see these threads:
codedFixedValue boundary condition
source term modification in poisson equation does not affect results
Kummi likes this.
babakflame is offline   Reply With Quote
Old   September 25, 2017, 15:09
Originally Posted by MSF View Post
Best,
Moritz
Thanks Moritz,
I tired groovyBC. It works for easier robin type boundary condition such as :
k*grad(n,T)+alpha*(T-Tinf)=0;
However, for my case I have an exponential function and groovy cannot find the root.
Old   September 25, 2017, 15:17
Thanks bobi,
First example is an ordinary robin boundary condition which is possible by groovy. I have already tried this one.
Last link was about source term in Laplace equation. I could not find the application for my case as boundary condition.
However, I think I should try codedFixedValue to extract internalField and to find root of boundary equation -[ k*grad(n,T)+exp(alpha*(T-Tinf)) ]- iteratively. Thanks for your help.
Old   September 26, 2017, 14:25
Bobby
I have written another sample for Robin Type boundary condition without Groovy. Just using the basics of c++ and OpenFoam.
Find it here:
Snippet for redefining fixedGradient boundary condition for a patch inside solver
Zhiheng Wang and BarCFD like this.
Old   September 27, 2017, 18:26
Zhiheng Wang
Zhiheng Wang is on a distinguished road
Find it here:
[QUOTE=babakflame;665758]I have written another sample for Robin Type boundary condition without Groovy. Just using the basics of c++ and OpenFoam.
Wiith All regards to bobi aka babakFlame for excellent and nice explanation
i can Just add few lines
scalarField GradT = T.boundaryFieldRef()[patchID].snGrad();
scalarField Tpatch = T.boundaryFieldRef()[patchID];
forAll(GradT,I)
scalar CONV = kappa*GradT[I] - Foam::exp(alpha*(Tpatch - Tinf));
if it is iterative bc you can add scalar CONVERGE = kappa*GradT[I] - Foam::exp(alpha*(Tpatch - Tinf)); with convergence 10-4 or 10-3 some thing under while loop which will give you Tnew for equation
But what is need of k*dT/dn if delta T = 0 at upper domain ???? what you want to find out ????
Here kappa and alpha are assumed to be const for variable add
volScalarField& Kapp = thermo.kappa(); use Kappa.boundaryfieldRef()[patchID][faceI] in code or reference it in scalarField as previously done for GradT and Tpatch
with thermo as basicThermo or psiReactingThermo object.
But Here kdT/dn doent have units same as exp(alpha(T-Tinf)) what you want to find Heat Flux or Temperature satisfies the condition ??
Kummi and BarCFD like this.
Zhiheng Wang is offline   Reply With Quote
Old   September 29, 2017, 16:57
[QUOTE=Zhiheng Wang;665901][QUOTE=babakflame;665758]
Thanks a lot Zhiheng!
Actually I have made an example here. My goal was to find the way to impose boundary condition which is a function of Field (exponential func). My Field in fact is not Temperate. I as solving potential field and boundary condition is local current density which linked to potential by Bulter-Volmer equation.
Thanks again for your comments and your concern
boundaries condition, groovybc, laplacianfoam
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 19:34
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
