Modify pointDisplacement within a solver
Like Tree1Likes
  • 1 Post By dariodario32
Old   August 19, 2017, 12:26
Default Modify pointDisplacement within a solver
dario
dariodario32 is on a distinguished road
I'm working on a modified version of pimpleDyMFoam, in which i can access the pointDisplacement field and assign value to a boundary patch according to data calculated inside the solver. (I'm using OF 4.1)
after declaring the IOobject and the pointPatchVectorField referred to the patch:
pointVectorField pointDisplacement_
IOobject
"pointDisplacement",
mesh.time().timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
pointMesh::New(mesh)
const pointPatchVectorField &pvf = pointDisplacement_.boundaryField()[patchI];
I would like to assign the value coming from displacements (a vectorField variable):
pvf = displacements;
when I compile the solver I have the following error:
error: passing ‘const pointPatchVectorField {aka const Foam:ointPatchField<Foam::Vector<double> >}’ as ‘this’ argument discards qualifiers [-fpermissive]
Does anybody know why?
Thanks
dariodario32 is offline   Reply With Quote
Old   August 22, 2017, 07:18
dario
the solution is to use boundaryFieldRef instead of boundaryField to write into the boundary patch:
pointVectorField& PointDisplacement = const_cast<pointVectorField&>
mesh.objectRegistry::lookupObject<pointVectorField >
"pointDisplacement"
PointDisplacement.boundaryFieldRef()[patchI] == displacements;
Lin Xiangfeng likes this.
Old   September 6, 2017, 13:10
Xiangfeng Lin
Lin Xiangfeng is on a distinguished road
i want to say thank you, your solution really do me a help~
Lin Xiangfeng is offline   Reply With Quote
Old   September 13, 2017, 04:30
ANKUR GARG
ankur_garg is on a distinguished road
Can Anyone help me, Where I am going wrong to write the below equation, where qem is the volScalarField and dfm is the class object:
error: passing ‘const volScalarField {aka const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ as ‘this’ argument discards qualifiers [-fpermissive]
scalarField& qem = dfm.qem().boundaryFieldRef()[patchi];
ankur_garg is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
CFX solver workspace properties: modify default values zboud CFX 2 March 8, 2010 09:10
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
To modify the interFoam solver for cavitating zjucfd OpenFOAM Running, Solving & CFD 5 August 26, 2007 09:03
