Using volPointInterpolation in modified FvPatchVectorField BC |
Joseph Tyson
Rep Power: 0 ![]() |
Hello all,
I'm currently trying to model mesh motion for a rectangular slab due to strain induced from small chemical species (e.g. water) diffusion into a material. I've modified solidDisplacementFoam to include dynamic mesh motion (displacementLaplacianFvMotionSolver). The mesh moves when I put a uniform time varying boundary condition into the "top" patch in the 0/pointDisplacement file. However, I want pointDisplacement to be dependent on the calculated displacement during runtime. To accomplish this, I'm attempting to modify a copy of the tractionDisplacementFvPatchVectorField to use in the 0/pointDisplacement file similar to how the tractionDisplacement BC is used in 0/D. PROBLEM I need to change the volVectorField D into a pointVectorField for use in 0/pointDisplacement. I've read all that I could find about volPointInterpolation, but I'm still having trouble understanding how to use it. This is the portion of the code that I have placed the volPointInterpolation. Code:
void pDisplacementFvPatchVectorField::updateCoeffs() { if (updated()) { return; } const fvPatchField<vector>& Disp = patch().lookupPatchField<volVectorField, vector>("D"); volPointInterpolation interpolateVolPoint (mesh); pointVectorField DispP = interpolateVolPoint.interpolate(Disp); operator== ( DispP ); fixedGradientFvPatchVectorField::updateCoeffs(); } Code:
pointDisp2/pointDisplacement2FvPatchVectorField.C: In member function ‘virtual void Foam::pDisplacementFvPatchVectorField::updateCoeffs()’: pointDisp2/pointDisplacement2FvPatchVectorField.C:142:45: error: ‘mesh’ was not declared in this scope volPointInterpolation interpolateVolPoint (mesh); ^ pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: error: no matching function for call to ‘Foam::volPointInterpolation::interpolate(const Foam::fvPatchField<Foam::Vector<double> >&)’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:155:63: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<Type, Foam::pointPatchField, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const tmp<GeometricField<Type, pointPatchField, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:155:63: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:163:63: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<Type, Foam::pointPatchField, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >&) const tmp<GeometricField<Type, pointPatchField, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:163:63: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:173:63: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<Type, Foam::pointPatchField, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const wordList&) const tmp<GeometricField<Type, pointPatchField, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:173:63: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:184:63: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<Type, Foam::pointPatchField, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >&, const wordList&) const tmp<GeometricField<Type, pointPatchField, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:184:63: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:193:48: note: candidate: template<class Type> Foam::tmp<Foam::DimensionedField<Type, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::DimensionedField<Type, Foam::volMesh>&) const tmp<DimensionedField<Type, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:193:48: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::DimensionedField<Type, Foam::volMesh>’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:201:48: note: candidate: template<class Type> Foam::tmp<Foam::DimensionedField<Type, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::tmp<Foam::DimensionedField<Type, Foam::volMesh> >&) const tmp<DimensionedField<Type, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:201:48: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::tmp<Foam::DimensionedField<Type, Foam::volMesh> >’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:239:18: note: candidate: template<class Type> void Foam::volPointInterpolation::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<Type, Foam::pointPatchField, Foam::pointMesh>&) const void interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:239:18: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:248:67: note: candidate: template<class Type> Foam::tmp<Foam::GeometricField<Type, Foam::pointPatchField, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&, bool) const tmp<GeometricField<Type, pointPatchField, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:248:67: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ In file included from pointDisp2/pointDisplacement2FvPatchVectorField.C:29:0: /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:267:52: note: candidate: template<class Type> Foam::tmp<Foam::DimensionedField<Type, Foam::pointMesh> > Foam::volPointInterpolation::interpolate(const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::word&, bool) const tmp<DimensionedField<Type, pointMesh>> interpolate ^ /home/joey/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/volPointInterpolation.H:267:52: note: template argument deduction/substitution failed: pointDisp2/pointDisplacement2FvPatchVectorField.C:143:63: note: ‘const Foam::fvPatchField<Foam::Vector<double> >’ is not derived from ‘const Foam::DimensionedField<Type, Foam::volMesh>’ pointVectorField DispP = interpolateVolPoint.interpolate(Disp); ^ Thank you, Joey |
dynamicmesh, fvpatchvectorfield, pointdisplacement, volpointinterpolation |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
Modified simpleFOAM using given Reynolds stress field | K62 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2017 03:41 |
reconstructPar for modified lagrangian libraries | oswald | OpenFOAM Programming & Development | 0 | October 20, 2014 05:23 |
Modified rhoCentralFoam slip boundary fails in parallel | ChrisA | OpenFOAM Programming & Development | 0 | June 25, 2014 20:28 |
Modified Equation for CFX algorithm | Craig Johansen | CFX | 0 | August 27, 2004 23:02 |
