obtaining p from p_rgh
Like Tree2Likes
  • 2 Post By jherb
Old   June 21, 2017, 13:59
Default obtaining p from p_rgh
toboto
toboto is on a distinguished road
Dear All,
In almost all multiphase solvers we solve for p_rgh (static or thermodynamic pressure - hydrostatic pressure) instead of p.
Then, we can obtain p by using:
p = p_rgh + rho*gh;
In most multiphase solvers the density is variable along the depth. So, instead of that, we should do something like:
p=p\_rgh+g\int_{0}^{h}\rho(z).dz
So, is that some kind of simplification in OpenFOAM, a bug or am I missing something?
toboto is offline   Reply With Quote
Old   June 21, 2017, 16:36
Joachim Herb
jherb is on a distinguished road
This is just the way, p_rgh is defined/used within OpenFOAM. It is not a physical quantity, just used internally.
Tobi and toboto like this.
jherb is offline   Reply With Quote
Old   June 29, 2017, 04:40
toboto
Thanks Joachim for your help
Obtaining a clean post production contour plot Lapis1 ANSYS 2 June 22, 2017 06:46
Problem obtaining normal vectors on blade loading line francois louw CFX 10 April 26, 2016 05:47
Problems obtaining the correct contours for Lid driven cavity DSS Main CFD Forum 9 February 10, 2016 18:06
Obtaining results from simulation geod FLUENT 3 February 27, 2015 10:44
Failing to obtaining the shadow wall Bright ANSYS 0 September 26, 2013 04:50
