June 20, 2017, 11:11 |
Error trying to compile new solver.C
Rep Power: 9 |
I'm trying to control the Courrant number and my ajustTimeStep is not working. So I think i have to modify the icoFoam.C to be able to make it work. However, I'm facing some trouble. I'm following this tutorial http://www.tfd.chalmers.se/~hani/kur...tersReport.pdf to create a new solver "myIcoFoam". So I've done these steps: _____________________________________ Code:
sol cp -r incompressible/icoFoam/ $WM_PROJECT_USER_DIR/applications/solvers/ cd $WM_PROJECT_USER_DIR/applications/solvers mv icoFoam myIcoFoam cd myIcoFoam mv icoFoam.C myIcoFoam.C sed -i s/icoFoam/myIcoFoam/g myIcoFoam.C sed -i s/icoFoam/myIcoFoam/g Make/files change EXE = $(FOAM_APPBIN)/icoFoam to EXE = $(FOAM_USER_APPBIN)/myIcoFoam And also change in Make/options: -I../dieselEngineFoam \ to -I$(LIB_SRC)/../applications/solvers/combustion/dieselEngineFoam \ ____________________________________________ I did not understand this last step very well, so I wrote this: Code:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/applications/solvers/lnInclude \ -I$(LIB_SRC)/meshTools/applications/solvers/lnInclude EXE_LIBS = \ -lfiniteVolume \ -lmeshTools Code:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude EXE_LIBS = \ -lfiniteVolume \ -lmeshTools Code:
[ofuser@default myIcoFoam]$ wmake Making dependency list for source file myIcoFoam.C could not open file fvCFD.H for source file myIcoFoam.C due to No such file or directory could not open file pisoControl.H for source file myIcoFoam.C due to No such file or directory could not open file createPhi.H for source file myIcoFoam.C due to No such file or directory could not open file initContinuityErrs.H for source file myIcoFoam.C due to No such file or directory could not open file CourantNo.H for source file myIcoFoam.C due to No such file or directory could not open file continuityErrs.H for source file myIcoFoam.C due to No such file or directory g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1612 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/applications/solvers/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/meshTools/applications/solvers/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OSspecific/POSIX/lnInclude -fPIC -c myIcoFoam.C -o Make/linux64GccDPInt32Opt/myIcoFoam.o myIcoFoam.C:63:19: fatal error: fvCFD.H: No such file or directory #include "fvCFD.H" |
June 20, 2017, 11:31 |
#2 | ||
Kevin van As
Rep Power: 21 |
That's why it goes wrong there.
The -I option should link to the directory that contains some common OF headers... This should be exactly the same for both icoFoam and my_icoFoam, so it is very simple what you need to do there: don't touch anything. This replacement: Code:
-I../dieselEngineFoam \ to -I$(LIB_SRC)/../applications/solvers/combustion/dieselEngineFoam \ Clearly, this is a nicer thing to do (as you don't have to duplicate unnecessary things), but I recommend you don't do so, as you are not yet comfortable with making those judgment calls. Quote:
Whereas I like Windows for the "normal" things, Linux beats Windows by far when we talk about software development. |
June 21, 2017, 10:29 |
#3 | |
Rep Power: 9 |
floquation,
Thanks for your prompt reply. But if I don't touch anything in the "options", I have the following error: Code:
[ofuser@default myIcoFoam]$ wmake Making dependency list for source file myIcoFoam.C g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1612 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OSspecific/POSIX/lnInclude -fPIC -c myIcoFoam.C -o Make/linux64GccDPInt32Opt/myIcoFoam.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1612 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/myIcoFoam.o -L/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib \ -lfiniteVolume -lmeshTools -lOpenFOAM -ldl \ -lm -o /home/ofuser/OpenFOAM/ofuser-v1612+/platforms/linux64GccDPInt32Opt/bin/myIcoFoam Quote:
June 21, 2017, 11:16 |
Kevin van As
Rep Power: 21 |
That's not an error.
When a compiler is called, it shows you the entire command. That's what the Makefile does. The three lines you see right there do the following:
June 22, 2017, 08:04 |
Rep Power: 9 |
Thank you so much. I'm so used to getting error messages, that I thought it was another one
June 22, 2017, 08:23 |
Anton Kidess
Rep Power: 30 |
Did you go through all these hoops just to control the time step? Why not use pimpleFoam?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 23, 2017, 07:24 |
Rep Power: 9 |
June 23, 2017, 11:24 |
Rep Power: 9 |
Hello again,
Now I'm trying to modify the myIcoFoam.C file to enable the ajustTimeStep. This is what I did: Code:
int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" pisoControl piso(mesh); #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; //while (runTime.loop()) // dropped while (runTime.run()) // added { #include "readTimeControls.H" // added #include "setDeltaT.H" // added runTime++; // added Info<< "Time = " << runTime.timeName() << nl << endl; #include "CourantNo.H" // Momentum predictor fvVectorMatrix UEqn ( . . . Code:
[ofuser@default myPisoFoam]$ wmake g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1612 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1612+/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/TurbulenceModels/incompressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/transportModels -I/opt/OpenFOAM/OpenFOAM-v1612+/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/sampling/lnInclude -IlnInclude -I[ofuser@default myIcoFoam]$ wmake Making dependency list for source file myIcoFoam.C g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1612 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1612+/src/OSspecific/POSIX/lnInclude -fPIC -c myIcoFoam.C -o Make/linux64GccDPInt32Opt/myIcoFoam.o In file included from myIcoFoam.C:79:0: /opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/readTimeControls.H: In function ‘int main(int, char**)’: /opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/readTimeControls.H:32:1: error: ‘adjustTimeStep’ was not declared in this scope adjustTimeStep = ^ /opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/readTimeControls.H:35:1: error: ‘maxCo’ was not declared in this scope maxCo = ^ /opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/readTimeControls.H:38:1: error: ‘maxDeltaT’ was not declared in this scope maxDeltaT = ^ In file included from myIcoFoam.C:90:0: /opt/OpenFOAM/OpenFOAM-v1612+/src/finiteVolume/lnInclude/setDeltaT.H:36:35: error: ‘CoNum’ was not declared in this scope scalar maxDeltaTFact = maxCo/(CoNum + SMALL); ^ make: *** [Make/linux64GccDPInt32Opt/myIcoFoam.o] Error 1 Code:
adjustTimeStep = runTime.controlDict().lookupOrDefault("adjustTimeStep", false); maxCo = runTime.controlDict().lookupOrDefault<scalar>("maxCo", 1.0); maxDeltaT = runTime.controlDict().lookupOrDefault<scalar>("maxDeltaT", GREAT); |
June 23, 2017, 11:29 |
#9 |
Kevin van As
Rep Power: 21 |
You are missing
#include "createTimeControls.H" You can easily figure that out by opening a solver that supports this, like pimpleFoam or interFoam. |
June 26, 2017, 09:44 |
#10 | |
Rep Power: 9 |
November 28, 2017, 10:54 |
wmake error for new solver
#11 | |
Saleh Abuhanieh
Rep Power: 9 |
Hi Kevin, Actually what LThomes did (modifying the Make/option file)is one of the solution posted in web to solve the errors which are related to compiling new solver. I almost tried all the ways! now, I am trying to compile new solver (first exercise only changing the name and the Make/file) and when I execute the wmake command, I receive the following error: make: *** No rule to make target '/opt/OpenFOAM-dev-debug/platforms/linux64GccDPInt32Debug/applications/solvers/incompressible/my_icoFoam/my_icoFoam.C.dep', needed by '/opt/OpenFOAM-dev-debug/platforms/linux64GccDPInt32Debug/applications/solvers/incompressible/my_icoFoam/my_icoFoam.o'. Stop." Thank you in advance |
May 16, 2018, 10:42 |
#12 | |
Rep Power: 8 |
i am facing a problem when trying to compile my own modified movingConeTopFvMesh which existed in openfoam4 and 5. I followed the steps to change the name of C and H file, their contents, as well as edit Make/file and run wmake. But it output errors: When I run wmake in openfoam4, Code:
wmakeLnInclude: linking include files to ./lnInclude make: *** No rule to make target '/opt/openfoam4/platforms/linux64GccDPInt32Opt/applications/topoChangerFvMesh/topoChangerFvMesh/topoChangerFvMesh2.C.dep', needed by '/opt/openfoam4/platforms/linux64GccDPInt32Opt/applications/topoChangerFvMesh/topoChangerFvMesh/topoChangerFvMesh2.o'. Stop. Code:
wmakeLnInclude: linking include files to ./lnInclude make: *** No rule to make target 'Make/linux64GccDPInt32Opt/topoChangerFvMesh/JH_topoChangerFvMesh.C.dep', needed by 'Make/linux64GccDPInt32Opt/topoChangerFvMesh/JH_topoChangerFvMesh.o'. Stop. Code:
/opt/openfoam4/src/parallel/decompose/scotchDecomp Making dependency list for source file scotchDecomp.C could not open file scotch.h for source file scotchDecomp.C due to No such file or directory g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread -I/include -I/opt/ThirdParty-4.1/platforms/linux64GccDPInt32/scotch_6.0.3/include -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c scotchDecomp.C -o /opt/openfoam4/platforms/linux64GccDPInt32Opt/src/parallel/decompose/scotchDecomp/scotchDecomp.o scotchDecomp.C:36:20: fatal error: scotch.h: No such file or directory compilation terminated. /opt/openfoam4/wmake/rules/General/transform:8: recipe for target '/opt/openfoam4/platforms/linux64GccDPInt32Opt/src/parallel/decompose/scotchDecomp/scotchDecomp.o' failed make: *** [/opt/openfoam4/platforms/linux64GccDPInt32Opt/src/parallel/decompose/scotchDecomp/scotchDecomp.o] Error 1 May i get some advice here on how to solve this? thanks a lot Last edited by jiahui_93; May 27, 2018 at 23:44. |
May 27, 2018, 00:55 |
#13 | |
Rep Power: 8 |
May 2, 2020, 16:34 |
#14 |
TX
Rep Power: 6 |
May 8, 2020, 05:44 |
Problem in linearSpring custom utility function
#15 |
sreekanth
Rep Power: 7 |
I tried to customise the linearSpring restrain to mylinearSpring and to make the source file readable by any solver I provided the path for executable in files
mylinearSpring.C LIB = $(FOAM_USER_LIBBIN)/libmylinearSpring Code:
-I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/dynamicMesh/lnInclude \ -I$(WM_PROJECT_DIR)/src/functionObjects/forces/lnInclude \ -I$(WM_PROJECT_DIR)/src/sixDoFRigidBodyMotion/lnInclude LIB_LIBS = \ -lfluidThermophysicalModels \ -lincompressibleTransportModels \ -lcompressibleTransportModels \ -lturbulenceModels \ -lincompressibleTurbulenceModels \ -lcompressibleTurbulenceModels \ -lspecie \ -lfileFormats \ -lfiniteVolume \ -lmeshTools \ Code:
sreekanth@sreekanth-VirtualBox:~/OpenFOAM/sreekanth-7/run/floatingObject$ interFoam /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : interFoam Date : May 06 2020 Time : 09:45:05 Host : "sreekanth-VirtualBox" PID : 2589 I/O : uncollated Case : /home/sreekanth/OpenFOAM/sreekanth-7/run/floatingObject nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function void* Foam::dlOpen(const Foam::fileName&, bool) in file POSIX.C at line 1251 dlopen error : /home/sreekanth/OpenFOAM/sreekanth-7/platforms/linux64GccDPInt32Opt/lib/libmylinearSpring.so: undefined symbol: _ZTIN4Foam30sixDoFRigidBodyMotionRestraintE --> FOAM Warning : From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105 could not load "libmylinearSpring.so" Create mesh for time = 0 Using #calcEntry at line 50 in file "/home/sreekanth/OpenFOAM/sreekanth-7/run/floatingObject/constant/dynamicMeshDict.rigidBodyMotionCoeffs.bodies.floatingObject" Using #codeStream with "/home/sreekanth/OpenFOAM/sreekanth-7/run/floatingObject/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_96bd56ab6d599ebbc648462330c624ef71f2258c.so" Selecting dynamicFvMesh dynamicMotionSolverFvMesh Using #calcEntry at line 50 in file "/home/sreekanth/OpenFOAM/sreekanth-7/run/floatingObject/constant/dynamicMeshDict.rigidBodyMotionCoeffs.bodies.floatingObject" Selecting motion solver: rigidBodyMotion --> FOAM FATAL ERROR: Unknown restraint type mylinearSpring Valid restraint types are : 4 ( linearAxialAngularSpring linearDamper linearSpring sphericalAngularDamper ) From function static Foam::autoPtr<Foam::RBD::restraint> Foam::RBD::restraint::New(const Foam::word&, const Foam::dictionary&, const Foam::RBD::rigidBodyModel&) in file restraints/restraint/rigidBodyRestraintNew.C at line 45. FOAM exiting Code:
ldd <library path> Code:
EXE_INC = \ -I$(LIB_SRC)/fileFormats/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/dynamicMesh/lnInclude \ -I$(WM_PROJECT_DIR)/src/functionObjects/forces/lnInclude \ -I$(WM_PROJECT_DIR)/src/sixDoFRigidBodyMotion/lnInclude LIB_LIBS = \ -lfluidThermophysicalModels \ -lincompressibleTransportModels \ -lcompressibleTransportModels \ -lturbulenceModels \ -lincompressibleTurbulenceModels \ -lcompressibleTurbulenceModels \ -lspecie \ -lfileFormats \ -lfiniteVolume \ -lmeshTools \ -lsixDoFRigidBodyMotion \ Code:
sreekanth@sreekanth-VirtualBox:~$ ldd /home/sreekanth/OpenFOAM/sreekanth-7/platforms/linux64GccDPInt32Opt/lib/libmylinearSpring.so linux-vdso.so.1 => (0x00007ffea23ef000) libfluidThermophysicalModels.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so (0x00007f45475ef000) libincompressibleTransportModels.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libincompressibleTransportModels.so (0x00007f454734d000) libcompressibleTransportModels.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libcompressibleTransportModels.so (0x00007f4547149000) libturbulenceModels.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libturbulenceModels.so (0x00007f4546d10000) libincompressibleTurbulenceModels.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so (0x00007f4546853000) libcompressibleTurbulenceModels.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so (0x00007f45463af000) libspecie.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libspecie.so (0x00007f4545caf000) libfileFormats.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfileFormats.so (0x00007f4545a24000) libfiniteVolume.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so (0x00007f4543d1a000) libmeshTools.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libmeshTools.so (0x00007f4543659000) libsixDoFRigidBodyMotion.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libsixDoFRigidBodyMotion.so (0x00007f45433cd000) libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f454304b000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f4542d42000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f4542b2c000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f4542762000) libOpenFOAM.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so (0x00007f4541bc1000) libthermophysicalProperties.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libthermophysicalProperties.so (0x00007f45418aa000) libPstream.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so (0x00007f454169a000) libtwoPhaseMixture.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libtwoPhaseMixture.so (0x00007f454147a000) libsolidThermo.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libsolidThermo.so (0x00007f4541198000) libsolidSpecie.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libsolidSpecie.so (0x00007f4540f6e000) libtriSurface.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libtriSurface.so (0x00007f4540ccd000) libsurfMesh.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libsurfMesh.so (0x00007f45409c0000) libforces.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libforces.so (0x00007f454074e000) libdynamicMesh.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so (0x00007f453ffe8000) /lib64/ld-linux-x86-64.so.2 (0x00007f4547d8a000) libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f453fdce000) libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f453fbb1000) libmpi.so.12 => /usr/lib/libmpi.so.12 (0x00007f453f8db000) libreactionThermophysicalModels.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libreactionThermophysicalModels.so (0x00007f453ed2c000) libextrudeModel.so => /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libextrudeModel.so (0x00007f453eb0c000) libibverbs.so.1 => /usr/lib/libibverbs.so.1 (0x00007f453e8fd000) libopen-rte.so.12 => /usr/lib/libopen-rte.so.12 (0x00007f453e683000) libopen-pal.so.13 => /usr/lib/libopen-pal.so.13 (0x00007f453e3e6000) libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f453e1e2000) libhwloc.so.5 => /usr/lib/x86_64-linux-gnu/libhwloc.so.5 (0x00007f453dfa8000) librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f453dda0000) libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f453db9d000) libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007f453d992000) libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7 (0x00007f453d788000) Code:
sreekanth@sreekanth-VirtualBox:~/OpenFOAM/sreekanth-7/run/floatingObject$ !block blockMesh /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : blockMesh Date : May 07 2020 Time : 13:47:33 Host : "sreekanth-VirtualBox" PID : 19301 I/O : uncollated Case : /home/sreekanth/OpenFOAM/sreekanth-7/run/floatingObject nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::Hasher(void const*, unsigned long, unsigned int) at ??:? #4 Foam::HashTable<Foam::autoPtr<Foam::sixDoFRigidBodyMotionRestraint> (*)(Foam::word const&, Foam::dictionary const&), Foam::word, Foam::string::hash>::set(Foam::word const&, Foam::autoPtr<Foam::sixDoFRigidBodyMotionRestraint> (* const&)(Foam::word const&, Foam::dictionary const&), bool) at ??:? #5 Foam::sixDoFRigidBodyMotionRestraint::adddictionaryConstructorToTable<Foam::sixDoFRigidBodyMotionRestraints::linearAxialAngularSpring>::adddictionaryConstructorToTable(Foam::word const&) at ??:? #6 ? at linearAxialAngularSpring.C:? #7 ? in "/lib64/ld-linux-x86-64.so.2" #8 ? in "/lib64/ld-linux-x86-64.so.2" #9 ? in "/lib64/ld-linux-x86-64.so.2" #10 ? in "/lib64/ld-linux-x86-64.so.2" #11 ? in "/lib64/ld-linux-x86-64.so.2" #12 ? in "/lib/x86_64-linux-gnu/libdl.so.2" #13 ? in "/lib64/ld-linux-x86-64.so.2" #14 ? in "/lib/x86_64-linux-gnu/libdl.so.2" #15 dlopen in "/lib/x86_64-linux-gnu/libdl.so.2" #16 Foam::dlOpen(Foam::fileName const&, bool) at ??:? #17 Foam::dlLibraryTable::open(Foam::fileName const&, bool) at ??:? #18 Foam::dlLibraryTable::open(Foam::dictionary const&, Foam::word const&) at ??:? #19 Foam::Time::Time(Foam::word const&, Foam::argList const&, Foam::word const&, Foam::word const&) at ??:? #20 ? at ??:? #21 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #22 ? at ??:? Segmentation fault (core dumped) |
compile, error, openfoam, solver, windows |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 | gwierink | OpenFOAM Installation | 0 | April 5, 2011 05:38 |
PV3FoamReader compile error.... | PEM_GUY | OpenFOAM Installation | 6 | April 5, 2010 18:22 |
Error compile file udf | czfluent | Fluent UDF and Scheme Programming | 24 | September 26, 2009 14:24 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 22:51 |
