Access to field which is evaluated at the moment
Like Tree3Likes
  • 1 Post By Tobi
  • 1 Post By Tobi
  • 1 Post By Tobi
Old   April 12, 2017, 18:51
Default Access to field which is evaluated at the moment
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hey everybody,
after a lot of suggestions from Philip Cardiff, I implement non-orthogonal corrections to the symmetry patches. In foam-extend it is straight forward and it is already implemented. However in FOAM-4.x it was not as straight forward than in extend or maybe I did it in an complex way. However, I build my own solidSymmetric boundary condition. Based on the fact that the class is a template one, I have to make some checks:
  • Displacement field -> do non-ortho corrections
  • Temperature field -> don't do non-ortho corrections (or differently)
Example given. The surface normal gradient function is given as:
template<class Type>
Foam::tmp<Foam::Field<Type>>
Foam::solidSymmetryFvPatchField<Type>::snGrad() const
    const vectorField nHat(this->patch().nf());
    Field<Type> iF(this->patchInternalField());
    //- Non-orthogonal correctors
    if ("Displacement field")
        vectorField delta(this->patch().delta());
        vectorField k = delta - nHat * (nHat & delta);
        const fvPatchTensorField& gradD =
        this->patch().template lookupPatchField<volTensorField, tensor>
            "grad(D)"
        //- Correct iF
        iF ...
    return
        (transform(I - 2.0*sqr(nHat), iF) - iF)
       *(this->patch().deltaCoeffs()/2.0);
As you can see, I need some check if the actual field is the displacement field but I could not figure out how I can check the field name from the patch here. I went through Doxygen to figure out which class could have access to the field name (T, D, ...) but could not find anything till now. Does anyone does know how to get access which volField is calling the function at the moment?
Any feedback would be warmly welcomed and I hope I pointed out what I want to do.
Lisandro Maders likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   April 12, 2017, 19:07
Tobi's Avatar
Tobias Holzmann
Okay solved in an easy way. I added a boolean for switching on and off the nonOrthoCorrection in the boundary of each field (default = false). So the solution is:
    if (nonOrthoCorrection_)
                "gradD"
        const vectorField corrector = (k & gradD.patchInternalField());
        //- PROBLEM
        iF += corrector;
However, the last problem is to cast the corrector into a <Type> form. The corrector loop is always done for a vector loop but based on the template I have to cast it somehow. Any idea, - tomorrow I will hopefully figure it out (maybe with some input of you).
Good night.
Keep foaming,
Tobias Holzmann
Old   April 13, 2017, 07:59
Tobi's Avatar
Tobias Holzmann
Hey all,
solved in the way that I derived a new class without using a template. Finally, now it is like in foam-extend but you have to take a bit more care (things are not 100% similar, as we would expect). Everything is working now
Keep foaming,
Tobias Holzmann
Old   April 19, 2017, 04:16
chriss85 will become famous soon enough
Have you done any tests to check for the influence of this correction at the boundary?
chriss85 is offline   Reply With Quote
Old   April 19, 2017, 04:33
Tobi's Avatar
Tobias Holzmann
Of course...
Sent from my HTC One mini using CFD Online Forum mobile app
Keep foaming,
Tobias Holzmann
Old   April 19, 2017, 05:15
So, are there any relevant differences or is this a minor effect? I'm wondering if it's important to consider this when nonorthogonal meshes with symmetries are used.
Old   April 19, 2017, 14:09
Tobi's Avatar
Tobias Holzmann
To keep everything clear. I consider only solid stress calculation. And yes it accelerates the convergence. In fluid dynamics I would say, that you can not see the difference but I did not checked that.
Keep foaming,
Tobias Holzmann
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem cico0815 OpenFOAM Community Contributions 36 February 3, 2022 12:54
Access field from different region in chtMultiRegionFoam JoeFriend OpenFOAM Programming & Development 0 March 21, 2017 11:35
How to access the field of weighting factor of interpolations fumiya OpenFOAM 2 November 16, 2012 08:33
Access to field data sepp OpenFOAM 2 February 10, 2011 12:45
