rhoCentralFoam fvSchemes none
Like Tree2Likes
  • 2 Post By PicklER
Old   April 1, 2017, 08:14
Default rhoCentralFoam fvSchemes none
PicklER is on a distinguished road
Hi
In shockTube tutorial test case, the divSchemes looks like follows:
divSchemes
    default         none;
    div(tauMC)      Gauss linear;
And in solver rhoCentralFoam, solving for density:
solve(fvm::ddt(rho) + fvc::div(phi));
My question: what scheme is used to solve for phi? As I understand, if a scheme is not specified, OpenFOAM gives an error and suggests the possible schemes.
Thanks
PicklER is offline   Reply With Quote
Old   April 1, 2017, 09:16
elones is on a distinguished road
look into rhoCentralFoam.C, the solver is based on Kurganov and Tadmor central schemes, ie, Riemann-solver-free approach.
elones is offline   Reply With Quote
Old   April 1, 2017, 10:47
Hi
Thank you for the quick reply. I think I understand it now. phi is calculated by the interpolated variables of the cell faces and therefore solved. I noticed that for n number of cells in a straight line, like in the shocktube test case, phi has only n-1 values, which confirms that phi only exists on the faces. And the obvious definition of phi
surfaceScalarField phi("phi", mesh.Sf() & fvc::interpolate(rhoU));
The same is done for the momentum and energy equations. I found a good article on rhoCenralFoam and it explains how the convective terms in the conservation equations are handled:
here
I am busy writing up my understanding of it in a way I can better explain it.
Thanks again
Jiss and hogsonik like this.
fvschemes, rhocentralfoam
rhoCentralFoam transport equation JoaoDMiranda OpenFOAM Programming & Development 29 July 5, 2024 09:38
How to apply a turbulence model to the rhoCentralFoam solver? arussell92 OpenFOAM Pre-Processing 18 July 25, 2022 05:26
Modify rhoCentralFoam: other equations of state fivos OpenFOAM Programming & Development 5 July 29, 2020 14:17
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 09:00
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 22:08
