Code compiling in OF240 but not in OF4X
Like Tree3Likes
  • 1 Post By Lisandro Maders
  • 2 Post By Zeppo
Old   March 20, 2017, 13:48
Default Code compiling in OF240 but not in OF4X
Lisandro Maders
Lisandro Maders is on a distinguished road
I programmed a code that is compiling fine in OpenFOAM 2.4.0. However, I tried to compile it in blue-cfd , which is based on OpenFOAM 4.x and I got an error, which is described as follows. I compiled the native OpenFOAM 4.x in my Ubuntu in order to test and I got the same error, so the error is not related to blue-cfd or Windows.
The line which the error occurs is in bold red. Here is only a piece of the code:
Foam::tmp<Foam::volVectorField> Foam::readSourceData::assignSourceValues
    const fvMesh& mesh
    tmp<volVectorField> tsource
        new volVectorField
            IOobject
                "source",
                mesh.time().timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            mesh,
            dimensionedVector("zero", dimensionSet(1,-2,-2,0,0,0,0),Foam::vector(0,0,0))
    volVectorField& source = tsource();
    forAll(source,celli)
....    Lot of stuff    .....
        source[celli] = Foam::vector(sourceData_[a][4],sourceData_[a][5],sourceData_[a][6]);
The error which is shown in the terminal is:
readSourceData/readSourceData.C: In member function ‘Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::readSourceData::assignSourceValues(const Foam::fvMesh&)’:
readSourceData/readSourceData.C:180:38: error: invalid initialization of reference of type ‘Foam::volVectorField& {aka Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&}’ from expression of type ‘const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>’
make: *** [Make/linux64GccDPInt64Opt/./readSourceData/readSourceData.o] Error 1
I thought that the
 tsource();
was returning a const reference and the
was not constant, but apparently it is not this.
Any one that have any idea I would appreciate this.
ykanani likes this.
Lisandro Maders is offline   Reply With Quote
Old   March 20, 2017, 17:17
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
volVectorField& source = tsource.ref();
Tobi and Lisandro Maders like this.
Zeppo is offline   Reply With Quote
Old   March 21, 2017, 14:04
Lisandro Maders
I am struggling to download OF4.x in another machine.. As soon as I do this I will check your suggestion and see if it works.
But anyway, my C++ is not the best in the world, but as far as I have read, and I quote now, "for tmp objects, non-const access uses a ref() function rather than the () dereferencing operator.".
This was changed from OpenFOAM 4.0 version on, that's why it was compiling fine in OpenFOAM 2.4 version and not in OF4.X versions..
It will probably work now.. I let you know as soon as I verify it.
Edit: Yes, it worked!!
Thanks a lot!
Lisandro Maders
Last edited by Lisandro Maders; March 21, 2017 at 16:41. Reason: Tried the suggestion and it worked!
blue-cfd, compilation error, of4x
[Other] Comparing OpenFOAM to another code: advice on dealing with meshes? SFr OpenFOAM Meshing & Mesh Conversion 1 June 11, 2016 13:02
something wrong when compiling udf, however the code is correct when interpreting richard ben Fluent UDF and Scheme Programming 7 May 11, 2013 08:36
problem with compiling the source code michel1988 OpenFOAM Installation 1 April 17, 2013 18:19
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 11:11
