Mesh morphing in parallel: procBoundary faces don't match after many iterations
Like Tree1Likes
  • 1 Post By jmf
Old   February 4, 2017, 14:22
Default Mesh morphing in parallel: procBoundary faces don't match after many iterations
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Dear all
I'm using fvMesh::movePoints() for moving a dynamic mesh. The morphing scaling and other components come from sixDOFRigidBodyMotion.
The case is a simple floating box, meshed with snappyHexMesh, nothing special. According checkMesh, the mesh is OK.
Everything works fine on a single processor. But in parallel (8 procs), the solver stops after roughly 70 morphing iterations with this message :
[0] processorPolyPatch::calcGeometry : Writing my 141 faces to OBJ file "/home/nous/OpenFOAM/nous-dev/tutorials/multiphase/bodyWave/testFloatingBox/processor0/procBoundary0to1_faces.obj"
[1] processorPolyPatch::calcGeometry : Writing my 141 faces to OBJ file "/home/nous/OpenFOAM/nous-dev/tutorials/multiphase/bodyWave/testFloatingBox/processor1/procBoundary1to0_faces.obj"
[2] processorPolyPatch::calcGeometry : Writing my 141 faces to OBJ file "/home/nous/OpenFOAM/nous-dev/tutorials/multiphase/bodyWave/testFloatingBox/processor2/procBoundary2to0_faces.obj"
[0] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/home/nous/OpenFOAM/nous-dev/tutorials/multiphase/bodyWave/testFloatingBox/processor0/procBoundary0to1_faceCentresConnections.obj"
[2] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/home/nous/OpenFOAM/nous-dev/tutorials/multiphase/bodyWave/testFloatingBox/processor2/procBoundary2to0_faceCentresConnections.obj"
[1] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/home/nous/OpenFOAM/nous-dev/tutorials/multiphase/bodyWave/testFloatingBox/processor1/procBoundary1to0_faceCentresConnections.obj"
[0] [2]
[0]
[0] --> FOAM FATAL ERROR:
[0] face 14 area does not match neighbour by 0.00556450469057% -- possible face ordering problem.
patch:procBoundary0to1 my area:0.248848415159 neighbour area:0.248834568363 matching tolerance:1.36641209403e-05
Mesh face:8647 vertices:5((2.29891922335e-07 -0.401730229978 -1.16728607597) (-3.71220352615e-07 2.59544341986e-07 -1.16652025771) (-8.609616315e-07 -3.77768751261e-07 -0.547727379825) (-3.04170602284e-07 -0.20229502984 -0.548709812717) (-1.96712958549e-07 -0.404060089841 -0.551903587152))
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with processor debug flag set for more information.
[0]
[0]     From function virtual void Foam::processorPolyPatch::calcGeometry(Foam::PstreamBuffers&)
[0]     in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 284.
FOAM parallel run exiting
[2]
[2] --> FOAM FATAL ERROR:
[2] face 14 area does not match neighbour by 0.00556450510688% -- possible face ordering problem.
patch:procBoundary2to0 my area:0.248953795093 neighbour area:0.248967648526 matching tolerance:1.36663291959e-05
Mesh face:7755 vertices:5((-0.401888239985 2.44719181695e-07 -1.16729052031) (-3.71220343883e-07 2.59544353419e-07 -1.16652564526) (-8.6096156693e-07 -3.77768666727e-07 -0.547767214909) (-0.202414009888 -2.04817231172e-07 -0.548748574775) (-0.404287879889 -3.22308157959e-07 -0.551940166394))
[2]
[2]     From function virtual void Foam::processorPolyPatch::calcGeometry(Foam::PstreamBuffers&)
[2]     in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 284.
[2]
[2]
[1] --> FOAM FATAL ERROR:
[1] face 14 area does not match neighbour by 0.00556450469057% -- possible face ordering problem.
patch:procBoundary1to0 my area:0.248834568363 neighbour area:0.248848415159 matching tolerance:1.36630506152e-05
Mesh face:7758 vertices:5((2.29891931019e-07 -0.401730229978 -1.16729143327) (-1.96712894399e-07 -0.404060089841 -0.551943163643) (-3.04170537813e-07 -0.20229502984 -0.548749587058) (-8.6096156693e-07 -3.77768666727e-07 -0.547767214909) (-3.71220343883e-07 2.59544353419e-07 -1.16652564526))
[1]
[1]     From function virtual void Foam::processorPolyPatch::calcGeometry(Foam::PstreamBuffers&)
[1]     in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 284.
[1]
[1]
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[linux0:04198] 2 more processes have sent help message help-mpi-api.txt / mpi-abort
[linux0:04198] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
I tried to increase the matching tolerance in the boundary file. This avoids the face matching error, but the solver freezes a few seconds later.
In Paraview, the faulty processor boundary faces show very tiny mismatches, see the attached image.
It may be due to machine precision errors, isn't it ? Is there in OF a build-in function to resynchronize the processor boundary points position ?
I found these classes : /OpenFOAM/meshes/polyMesh/syncTools/syncTools.C
I also found this aplication : /applications/test/syncTools/Test-syncTools.C
I added in the solver something like this, without any results :
    // Synchonize the points
    pointField syncedPoints(mesh.points());
    syncTools::syncPointPositions
        mesh,
        syncedPoints,
        minMagSqrEqOp<point>(),
        point(GREAT, GREAT, GREAT)
Could anybody give me suggestions ?
Best wishes
Jean-Michel
OF version : 1612+
blue8803 likes this.
jmf is offline   Reply With Quote
match faces, parallel error, processor boundary, synchronization
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
