Simple loop in LaplacianFoam
Like Tree1Likes
  • 1 Post By tomf
Old   January 23, 2017, 10:29
Default Simple loop in LaplacianFoam
rik houthuys
Houthuys is on a distinguished road
Dear all,
I am bit confused about the function of the simple loop declared in the LaplacianFoam solver.
simpleControl simple(mesh);
    while (simple.loop()) {
I think it's not the SIMPLE algorithm procedure because this solver has nothing to do regarding the pressure-velocity coupling. Also this solver is transient solver while the SIMPLE algorithm is steady state solver.
I would appreciate if someone can elaborate on the difference between simple.loop, simpleControl and the SIMPLE algorithm
Thanks
Houthuys is offline   Reply With Quote
Old   January 24, 2017, 04:18
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I believe it has to do with the convergence checking functionality that is available within the simple loops. I would agree the name is a bit misleading, but I do no think you should worry about it too much.
Regards,
Tom
dasa likes this.
tomf is offline   Reply With Quote
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
getter/setter function for the velocity nodes in a simple Cartesian grid ooo OpenFOAM Programming & Development 1 December 6, 2013 08:45
Can someone help me with a UDF for a simple rotatory geometry?? Maralady Fluent UDF and Scheme Programming 14 August 12, 2013 09:23
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 02:04
[blockMesh] Setting temperature on a patch for laplacianFoam Bruce Hartley OpenFOAM Meshing & Mesh Conversion 4 June 16, 2011 21:58
