stream failure while reading header on line
Like Tree1Likes
  • 1 Post By alexeym
Old   January 23, 2017, 03:15
Default stream failure while reading header on line
A. Min
alimea is on a distinguished road
Hi
I made some changes on "laplacian solver" and I wanted to solve a simple problem. but I saw this error:
stream failure while reading header on line 55 of file "/home/drnili/Desktop/laplacianFoam/example/laplacianFoam/test/0/sai" for essential objectsai
Of course the file "sai" in "0" folder doesn't have 55 lines!!
Could you please help me?
alimea is offline   Reply With Quote
Old   January 23, 2017, 04:51
floquation's Avatar
Kevin van As
floquation will become famous soon enough
If you open any of OpenFoam's case files (e.g. constant/transportProperties, but any file will do), you'll find a header that looks somewhat like:
|  \\    /   O peration     | Version:  4.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
As you can see, there is information in this header. OpenFoam needs that information to read the file.
Therefore, you should include the above header (but then adapted for your file, of course). Also mind the OpenFoam version, so do not simply copy my header above, but rather take a header from one of your other case files.
floquation is offline   Reply With Quote
Old   January 23, 2017, 05:17
A. Min
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
Dear Kevin
Thanks for your answer.
But I copy a similar header (e.g. the header of T in "0" folder) for the "sai" parameter. so what is the problem?
Old   January 23, 2017, 05:31
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Surely game called "Guess what I have done wrong!" is fascinating and people here like to play it VERY much. Yet, it would be MUCH easier if:
1. You tell a little bit more about `some changes on "laplacian solver"`.
2. Post your sai file.
floquation likes this.
alexeym is offline   Reply With Quote
Old   January 23, 2017, 05:35
A. Min
Originally Posted by alexeym View Post
I sent it to you on other question.
Regards
Old   January 23, 2017, 05:43
Alexey Matveichev
In other question you have posted your modifications. This question is about problem with sai file. And there is no sai file in this thread.
Old   January 23, 2017, 06:20
A. Min
This is the file of mylaplacian.C :
\\ / O peration |
\\ / A nd | Copyright (C) 2011 OpenFOAM Foundation
\\/ M anipulation |
#include "fvCFD.H"
#include "simpleControl.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
simpleControl simple(mesh);
Info<< "\nCalculating temperature distribution\n" << endl;
while (simple.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
while (simple.correctNonOrthogonal())
solve(fvm::laplacian(sai) == omega);
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
This is the "createFields.H" :
Info<< "Reading field sai\n" << endl;
volScalarField sai
IOobject
"sai",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Info<< "Reading field omega\n" << endl;
volScalarField omega
IOobject
"omega",
runTime.timeName(),
mesh,
mesh
Info<< "Reading field gradU\n" << endl;
volTensorField gradU
IOobject
"gradU",
runTime.timeName(),
mesh,
mesh
forAll(omega, counter)
omega[counter] = gradU[counter].component(tensor::XY) - gradU[counter].component(tensor::YX);
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
Info<< "Reading diffusivity DT\n" << endl;
dimensionedScalar DT
transportProperties.lookup("DT")
Old   January 23, 2017, 07:57
A. Min
The last problem is solved.
Thank you.
I got the "gradU" file from the "100" folder of other solution (it means the results of that solution at 100 second) and paste it in the "0" folder of present problem as an initial condition. The problem was run but no result folder is written in the folder of problem!!
why?
Regards
Old   January 23, 2017, 09:37
Alexey Matveichev
Cause you do not call runTime.write(). And it seems, you are playing another game called "Randomly put curly brackets and see if your code can be compiled".
Old   January 24, 2017, 08:50
A. Min
yes. Thank you
header, stream failure
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger benru OpenFOAM Meshing & Mesh Conversion 3 June 29, 2008 22:24
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
