Calcolation of spicies diffusivity
Like Tree9Likes
  • 1 Post By Zhiheng Wang
  • 2 Post By freuen
  • 1 Post By atulkjoy
  • 4 Post By atulkjoy
Old   January 6, 2017, 03:28
Default Calcolation of spicies diffusivity
Zhiheng Wang
Zhiheng Wang is on a distinguished road
I want to calculate the species diffusivity D (fick law) on basis of binary diffusivity I am knowing the formulation ,
My problem is how to extract the data.
As in creatFields.H spicies defined as
basicMultiComponentMixture& composition = thermo.composition();
PtrList<volScalarField>& Y = composition.Y();
every property kappa, mu, alpha,or rho for example is called as composition.rho(i,1e5,T)
How can I implement D (molecular diffusion in same form).
Or if any one suggest how to create PtrList<volScalrField>& D = some variable which can calculate this.
Saeng Kinley likes this.
Zhiheng Wang is offline   Reply With Quote
Old   March 1, 2017, 06:40
Zhiheng Wang
No body ????
Old   March 11, 2017, 14:32
Wentao Wang
freuen is on a distinguished road
For Openfoam 3.0, You can put this code in the createFields.H
PtrList<volScalarField> Diff;
forAll(Y, i)
word name("Diff_" + Y[i].name());
Diff.append(new volScalarField
IOobject
name,
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar(name, dimensionSet(0,2,-1,0,0,0,0), 0)
fields.add(Diff[i]);
Originally Posted by Zhiheng Wang View Post
atulkjoy and Kummi like this.
freuen is offline   Reply With Quote
Old   March 14, 2017, 05:42
Atul Kumar
Location: National Centre for Combustion Research and Development
atulkjoy is on a distinguished road
HI,
Sir Can you answer why line number 174 and 175 are commented in file. These are meant to be up-dation of species diffusivity with sutherland model.
It is about same thing but here the Diffusivity is varing with temperature.
https://github.com/OpenFOAM/OpenFOAM...andTransport.H
175 // Species diffusivity //inline scalar D(const scalar p, const scalar T) const;
atulkjoy is offline   Reply With Quote
Old   March 14, 2017, 15:46
Wentao Wang
I guess it's reserved for future development
Sent from my iPhone using CFD Online Forum mobile app
Old   April 28, 2017, 03:15
SH_Zhong is on a distinguished road
forAll(Y, i)
IOobject
name,
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh,
I write the code into my creatFields.H,
but I get this error.
'fields' was not declared in this scope.
So what can I do to get rid of the problems, many thanks in advance!
SH_Zhong is offline   Reply With Quote
Old   May 3, 2017, 02:21
Atul Kumar
Hi use the code I have sent you you would be able to find Diffusivity. use 2.3.x firefoam as solver. Copy $WM_PROJECT_DIR/fireFoam to $WM_PROJECT_USER_DIR/myfirefoam.
2. Rename createFields.H to old.createFields.H and download createFields.H I sent to you.
3. Add starting lines of sutherland.C to fireFoam.c rename it as MyfireFoam.
4. change make/file, edit this file from fireFoam.C to myFireFoam.C and $FOAM_APPBIN/fireFoam to $FOAM_USER_APPBIN/MyfireFoam.
compile and run the case with declaration of speciesdict file in constantFolder.
Kinematic Diffusivity - Problem with additional variable clau90 CFX 3 May 14, 2014 10:54
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 08:37
What is UDS diffusivity of a self-defined material? aleisia FLUENT 0 March 5, 2011 23:08
Motion diffusivity solver has problems with patches moving toward each other bfa OpenFOAM Running, Solving & CFD 2 July 8, 2009 22:35
Species diffusivity zhou1 FLUENT 0 November 4, 2003 18:23
