January 5, 2017, 13:53 |
question on H operator
Przemek
Rep Power: 16 |
Hi Foamers,
According to Prof. Hrvoje Jasak's PhD thesis: "The H(U) term consists of two parts: the “transport part”, including the matrix coefficients for all neighbours multiplied by corresponding velocities and the “source part” including the source part of the transient term and all other source terms apart from the pressure gradient". My question is on implementation of .H() operator: If I change the basic momentum equation and add my source term and then I use the .H() function in the code, is it contain my source term also or I have to implement this by hand?
best regards pblasiak |
January 5, 2017, 14:10 |
Przemek
Rep Power: 16 |
more clearly:
If I add source term to the momentum equation, is it already included in the .H() function?
January 5, 2017, 15:13 |
Sergei
Rep Power: 21 |
Yes, when you add your (user-difined) source to the equation, you are actually modifying the source coefficients (source_) of fvMatrix object to be solved. All the modifications are incorporated into the matrix. The function fvMatrix<Type>::H() const does the following:
// "src/finiteVolume/fvMatrices/fvMatrix/fvMatrix.C" ... 788 Hphi.primitiveFieldRef() += lduMatrix::H(psi_.primitiveField()) + source_; ... |
January 5, 2017, 15:21 |
Przemek
Rep Power: 16 |
Hi Zeppo,
Thank you very much for your help
October 22, 2018, 14:54 |
#5 | |
Rep Power: 8 |
Is lduMatrix::H(psi_.primitiveField()) negative? There is a command that "negates" a couple lines above that. I just want to confirm that that makes the code consistent with other explanations, e.g., https://openfoamwiki.net/index.php/O...ide/H_operator Thanks. -Mimi |
December 10, 2018, 04:40 |
#6 | |
Michael Alletto
Rep Power: 16 |
1523 template<class Type> 1524 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1525 ( 1526 const fvMatrix<Type>& A, 1527 const DimensionedField<Type, volMesh>& su 1528 ) 1529 { 1530 checkMethod(A, su, "=="); 1531 tmp<fvMatrix<Type>> tC(new fvMatrix<Type>(A)); 1532 tC.ref().source() += su.mesh().V()*su.field(); 1533 return tC; 1534 } 1535 1536 template<class Type> 1537 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1538 ( 1539 const fvMatrix<Type>& A, 1540 const tmp<DimensionedField<Type, volMesh>>& tsu 1541 ) 1542 { 1543 checkMethod(A, tsu(), "=="); 1544 tmp<fvMatrix<Type>> tC(new fvMatrix<Type>(A)); 1545 tC.ref().source() += tsu().mesh().V()*tsu().field(); 1546 tsu.clear(); 1547 return tC; 1548 } 1549 1550 template<class Type> 1551 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1552 ( 1553 const fvMatrix<Type>& A, 1554 const tmp<GeometricField<Type, fvPatchField, volMesh>>& tsu 1555 ) 1556 { 1557 checkMethod(A, tsu(), "=="); 1558 tmp<fvMatrix<Type>> tC(new fvMatrix<Type>(A)); 1559 tC.ref().source() += tsu().mesh().V()*tsu().primitiveField(); 1560 tsu.clear(); 1561 return tC; 1562 } 1563 1564 template<class Type> 1565 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1566 ( 1567 const tmp<fvMatrix<Type>>& tA, 1568 const DimensionedField<Type, volMesh>& su 1569 ) 1570 { 1571 checkMethod(tA(), su, "=="); 1572 tmp<fvMatrix<Type>> tC(tA.ptr()); 1573 tC.ref().source() += su.mesh().V()*su.field(); 1574 return tC; 1575 } 1576 1577 template<class Type> 1578 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1579 ( 1580 const tmp<fvMatrix<Type>>& tA, 1581 const tmp<DimensionedField<Type, volMesh>>& tsu 1582 ) 1583 { 1584 checkMethod(tA(), tsu(), "=="); 1585 tmp<fvMatrix<Type>> tC(tA.ptr()); 1586 tC.ref().source() += tsu().mesh().V()*tsu().field(); 1587 tsu.clear(); 1588 return tC; 1589 } 1590 1591 template<class Type> 1592 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1593 ( 1594 const tmp<fvMatrix<Type>>& tA, 1595 const tmp<GeometricField<Type, fvPatchField, volMesh>>& tsu 1596 ) 1597 { 1598 checkMethod(tA(), tsu(), "=="); 1599 tmp<fvMatrix<Type>> tC(tA.ptr()); 1600 tC.ref().source() += tsu().mesh().V()*tsu().primitiveField(); 1601 tsu.clear(); 1602 return tC; 1603 } 1604 1605 template<class Type> 1606 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1607 ( 1608 const fvMatrix<Type>& A, 1609 const dimensioned<Type>& su 1610 ) 1611 { 1612 checkMethod(A, su, "=="); 1613 tmp<fvMatrix<Type>> tC(new fvMatrix<Type>(A)); 1614 tC.ref().source() += A.psi().mesh().V()*su.value(); 1615 return tC; 1616 } 1617 1618 template<class Type> 1619 Foam::tmp<Foam::fvMatrix<Type>> Foam::operator== 1620 ( 1621 const tmp<fvMatrix<Type>>& tA, 1622 const dimensioned<Type>& su 1623 ) 1624 { 1625 checkMethod(tA(), su, "=="); 1626 tmp<fvMatrix<Type>> tC(tA.ptr()); 1627 tC.ref().source() += tC().psi().mesh().V()*su.value(); 1628 return tC; 1629 } Code:
1 // Construct the Momentum equation 2 3 MRF.correctBoundaryVelocity(U); 4 5 tmp<fvVectorMatrix> tUEqn 6 ( 7 fvm::div(phi, U) 8 + MRF.DDt(U) 9 + turbulence->divDevReff(U) 10 == 11 fvOptions(U) 12 ); 13 fvVectorMatrix& UEqn = tUEqn.ref(); 14 15 UEqn.relax(); 16 17 // Include the porous media resistance and solve the momentum equation 18 // either implicit in the tensorial resistance or transport using by 19 // including the spherical part of the resistance in the momentum diagonal 20 21 tmp<volScalarField> trAU; 22 tmp<volTensorField> trTU; 23 24 if (pressureImplicitPorosity) 25 { 26 tmp<volTensorField> tTU = tensor(I)*UEqn.A(); 27 pZones.addResistance(UEqn, tTU.ref()); 28 trTU = inv(tTU()); 29 trTU.ref().rename("rAU"); 30 31 fvOptions.constrain(UEqn); 32 33 volVectorField gradp(fvc::grad(p)); 34 35 for (int UCorr=0; UCorr<nUCorr; UCorr++) 36 { 37 U = trTU() & (UEqn.H() - gradp); 38 } 39 U.correctBoundaryConditions(); 40 41 fvOptions.correct(U); 42 } 43 else 44 { 45 pZones.addResistance(UEqn); 46 47 fvOptions.constrain(UEqn); 48 49 solve(UEqn == -fvc::grad(p)); 50 51 fvOptions.correct(U); 52 53 trAU = 1.0/UEqn.A(); 54 trAU.ref().rename("rAU"); 55 } |
[3D Vortex Particle Method]The function in diffusion operator | wyj216 | Main CFD Forum | 5 | April 24, 2015 10:03 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
